Eric Lai has submitted this change. ( https://review.coreboot.org/c/coreboot/+/76125?usp=email )
2 is the latest approved patch-set. No files were changed between the latest approved patch-set and the submitted one. )Change subject: mb/google/dedede/var/taranza: Disable EXT_VR ......................................................................
The taranza removed the APW8738BQBI and "disable_external_bypass_vr" should be set to "1" to disable.
BUG=b:288978340 TEST=emerge-dedede coreboot
Signed-off-by: Sheng-Liang Pan sheng-liang.pan@quanta.corp-partner.google.com Change-Id: I0a849fbfacba1d200c969c66bb058863d7ab3085 Reviewed-on: https://review.coreboot.org/c/coreboot/+/76125 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Eric Lai eric_lai@quanta.corp-partner.google.com --- M src/mainboard/google/dedede/variants/taranza/overridetree.cb 1 file changed, 3 insertions(+), 0 deletions(-)
Approvals: Sheng-Liang Pan: Looks good to me, but someone else must approve Eric Lai: Looks good to me, approved build bot (Jenkins): Verified
diff --git a/src/mainboard/google/dedede/variants/taranza/overridetree.cb b/src/mainboard/google/dedede/variants/taranza/overridetree.cb index e3df1f2..fa8d409 100644 --- a/src/mainboard/google/dedede/variants/taranza/overridetree.cb +++ b/src/mainboard/google/dedede/variants/taranza/overridetree.cb @@ -53,6 +53,9 @@ register "DdiPortAHpd" = "1" register "DdiPortADdc" = "1"
+ # Does not support external vnn power rail + register "disable_external_bypass_vr" = "1" + # USB Port Configuration register "usb2_ports[0]" = "{ .enable = 1,
