Martin Roth has uploaded this change for review. ( https://review.coreboot.org/21585
Change subject: Makefile: Don't rebuild when generating tags or file list ......................................................................
Generating a project file list used to do a rebuild of the project. Instead, just make sure there's a coreboot.rom file present and if it is, generate the list.
Change-Id: I9cc12ef3d1990c3422625630451b2a7b8d77829c Signed-off-by: Martin Roth martinroth@google.com --- M Makefile 1 file changed, 6 insertions(+), 3 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/85/21585/1
diff --git a/Makefile b/Makefile index 383d583..4ad0177 100644 --- a/Makefile +++ b/Makefile @@ -369,13 +369,16 @@ $(shell mkdir -p $(KCONFIG_SPLITCONFIG) $(objk)/lxdialog $(additional-dirs) $(alldirs)) endif
-$(obj)/project_filelist.txt: all +$(obj)/project_filelist.txt: + if [ -z "$(wildcard $(obj)/coreboot.rom)" ]; then \ + echo "*** Error: Project must be built before generating file list ***"; \ + exit 1; \ + fi find $(obj) -name "*.d" -exec cat {} ; | \ sed 's/[:\]/ /g' | sed 's/ /\n/g' | sort | uniq | \ grep -v '.o$$' > $(obj)/project_filelist.txt
-filelist: clean - $(MAKE) $(obj)/project_filelist.txt +filelist: $(obj)/project_filelist.txt printf "\nFiles used in build:\n" cat $(obj)/project_filelist.txt
