Duncan Laurie (dlaurie@chromium.org) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/16673
commit 6ddf23cdd920603df6b9b68de3f4b51ef4dafa85 Author: Duncan Laurie dlaurie@chromium.org Date: Mon Sep 19 17:24:55 2016 -0700
mainboard/google/reef: Enable cr50 TPM interrupt
Enable the cr50 TPM and interrupt as GPE0_DW1_28 for use during verstage. The interrupt is left in APIC mode as the GPE is still latched when the GPIO is pulled low.
BUG=chrome-os-partner:53336
Change-Id: Ib0247653bdcbaccb645cd16b81d7ec3c38f669af Signed-off-by: Duncan Laurie dlaurie@chromium.org --- src/mainboard/google/reef/Kconfig | 4 ++++ src/mainboard/google/reef/variants/baseboard/gpio.c | 1 + 2 files changed, 5 insertions(+)
diff --git a/src/mainboard/google/reef/Kconfig b/src/mainboard/google/reef/Kconfig index 0013ffd..5039725 100644 --- a/src/mainboard/google/reef/Kconfig +++ b/src/mainboard/google/reef/Kconfig @@ -10,6 +10,7 @@ config BOARD_GOOGLE_BASEBOARD_REEF select I2C_TPM select MAINBOARD_HAS_CHROMEOS select MAINBOARD_HAS_TPM2 + select MAINBOARD_HAS_I2C_TPM_CR50 select TPM2
if BOARD_GOOGLE_BASEBOARD_REEF @@ -24,6 +25,9 @@ config DRIVER_TPM_I2C_BUS config DRIVER_TPM_I2C_ADDR hex "0x50"
+config DRIVER_TPM_I2C_IRQ + int "60" # GPE0_DW1_28 + config CHROMEOS select LID_SWITCH if BASEBOARD_REEF_LAPTOP
diff --git a/src/mainboard/google/reef/variants/baseboard/gpio.c b/src/mainboard/google/reef/variants/baseboard/gpio.c index 7d74140c..976a504 100644 --- a/src/mainboard/google/reef/variants/baseboard/gpio.c +++ b/src/mainboard/google/reef/variants/baseboard/gpio.c @@ -353,6 +353,7 @@ static const struct pad_config early_gpio_table[] = { /* I2C2 - TPM */ PAD_CFG_NF(GPIO_128, UP_2K, DEEP, NF1), /* LPSS_I2C2_SDA */ PAD_CFG_NF(GPIO_129, UP_2K, DEEP, NF1), /* LPSS_I2C2_SCL */ + PAD_CFG_GPI_APIC_LOW(GPIO_28, NONE, DEEP), /* TPM IRQ */ /* WLAN_PE_RST - default to deasserted just in case FSP misbehaves. */ PAD_CFG_GPO(GPIO_122, 0, DEEP), /* SIO_SPI_2_RXD */ };
