Attention is currently required from: Martin Roth, Furquan Shaikh, Chiranjeevi Rapolu, Tim Wawrzynczak, John Zhao, Duncan Laurie, Patrick Rudolph. Hello build bot (Jenkins), Furquan Shaikh, Chiranjeevi Rapolu, Tim Wawrzynczak, John Zhao, Duncan Laurie, Patrick Rudolph,
https://review.coreboot.org/c/coreboot/+/51194
Change subject: soc/intel/tigerlake: Enable TCSS Muxes to disconnect mode during boot ......................................................................
TCSS muxes being left uninitialized during boot is causing some USB3 devices to downgrade to USB2 speed. To properly configure the Type C ports the muxes should be set to disconnected state during boot so that the port mapping of USB2/3 devices is properly setup prior to Kernel initializing devices.
BUG=b:180426950 BRANCH=firmware-volteer-13672.B TEST= Connected USB3 storage device and rebooted the system multiple times to verify that the devices were no longer downgrading to USB2 speed.
Change-Id: I4352072a4a7d6ccb1364b38377831f3c22ae8fb4 Signed-off-by: Brandon Breitenstein brandon.breitenstein@intel.com --- M src/soc/intel/tigerlake/Kconfig M src/soc/intel/tigerlake/Makefile.inc M src/soc/intel/tigerlake/early_tcss.c M src/soc/intel/tigerlake/fsp_params.c M src/soc/intel/tigerlake/include/soc/early_tcss.h 5 files changed, 79 insertions(+), 16 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/94/51194/4
