Patrick Georgi (pgeorgi@google.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/11136
commit b1d4a9c200a6d315e4b1f274e2b13c46d3e859dd Author: Patrick Georgi patrick@georgi-clan.de Date: Sat Sep 6 17:23:30 2014 +0200
getac/p470: use native VGA init
Change-Id: I6c5a2324d1a9e21f4e052678be8f0e0dbfed6494 Signed-off-by: Patrick Georgi patrick@georgi-clan.de --- src/mainboard/getac/p470/Kconfig | 7 +++++++ src/mainboard/getac/p470/mainboard.c | 2 ++ 2 files changed, 9 insertions(+)
diff --git a/src/mainboard/getac/p470/Kconfig b/src/mainboard/getac/p470/Kconfig index 3fdc67c..2bb7aeb 100644 --- a/src/mainboard/getac/p470/Kconfig +++ b/src/mainboard/getac/p470/Kconfig @@ -38,6 +38,13 @@ config BOARD_SPECIFIC_OPTIONS # dummy select UDELAY_LAPIC select BOARD_ROMSIZE_KB_1024 select CHANNEL_XOR_RANDOMIZATION + select EARLY_CBMEM_INIT + select VGA + select MAINBOARD_HAS_NATIVE_VGA_INIT + select MAINBOARD_HAS_NATIVE_VGA_INIT_TEXTMODECFG + select MAINBOARD_DO_EDID + select INTEL_EDID + select INTEL_INT15
config MAINBOARD_DIR string diff --git a/src/mainboard/getac/p470/mainboard.c b/src/mainboard/getac/p470/mainboard.c index 6ee17a0..226b9c0 100644 --- a/src/mainboard/getac/p470/mainboard.c +++ b/src/mainboard/getac/p470/mainboard.c @@ -23,6 +23,7 @@ #include <device/pci_def.h> #include <arch/io.h> #include <delay.h> +#include <drivers/intel/gma/int15.h>
#include "ec_oem.c" @@ -81,6 +82,7 @@ static void pcie_limit_power(void) static void mainboard_init(device_t dev) { ec_enable(); + install_intel_vga_int15_handler(GMA_INT15_ACTIVE_LFP_INT_LVDS, GMA_INT15_PANEL_FIT_TXT_STRETCH, 0, 3); }
// mainboard_enable is executed as first thing after
