Attention is currently required from: Christian Walter, Martin L Roth, Marvin Drees, Stefan Reinauer.
Hello Christian Walter, Martin L Roth, Marvin Drees, Stefan Reinauer,
https://review.coreboot.org/c/coreboot/+/76150?usp=email
Change subject: payloads/external/LinuxBoot: Clean up ......................................................................
There were some issues with the current Linuxboot Makefiles. - multithreaded compilation didn't work, because some prerequisites were missing - initramfs wasn't added for x86 qemu boot. - riscv support was incomplete
It began with separate patches, but resulted in a clean up patch, that is hard to separate. The most important changes are the following: - Instead of phony targets, actual files are now used as prerequisites - riscv can now be used as target - initramfs works now also for x86 - instead of querying the most recent version from the internet, I set a known working version (because I tested it) that can be customized and/or upgraded in the future. - I removed as much ifeq statements as possible and moved that responsibility to Kconfig, because they tend to make the Makefile less readable.
Signed-off-by: Maximilian Brune maximilian.brune@9elements.com Change-Id: I25e757108e0dd473969fe5a192ad0733f1fe6286 --- M payloads/external/LinuxBoot/Kconfig M payloads/external/LinuxBoot/Makefile M payloads/external/LinuxBoot/arm64/kernel_fdt_lzma.its M payloads/external/LinuxBoot/targets/linux.mk M payloads/external/LinuxBoot/targets/u-root.mk M payloads/external/Makefile.inc 6 files changed, 104 insertions(+), 215 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/50/76150/3
