Edward O'Callaghan (eocallaghan@alterapraxis.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/6136
commit d4d3d3d8d863694873290d65dc4b9a7d49c43f5f Author: Edward O'Callaghan eocallaghan@alterapraxis.com Date: Fri Jun 27 12:13:30 2014 +1000
intel: Make monotonic timer a first class citizen
NOTFORMERGE
Change-Id: I9df6d209e512f187c061adb7ebceffd424c6a4f7 Signed-off-by: Edward O'Callaghan eocallaghan@alterapraxis.com --- src/cpu/intel/fsp_model_206ax/Kconfig | 2 ++ src/cpu/intel/haswell/Kconfig | 1 + src/cpu/intel/model_2065x/Kconfig | 2 ++ src/cpu/intel/model_206ax/Kconfig | 2 ++ src/mainboard/intel/baskingridge/Kconfig | 2 +- 5 files changed, 8 insertions(+), 1 deletion(-)
diff --git a/src/cpu/intel/fsp_model_206ax/Kconfig b/src/cpu/intel/fsp_model_206ax/Kconfig index 0fb4437..01eda1b 100644 --- a/src/cpu/intel/fsp_model_206ax/Kconfig +++ b/src/cpu/intel/fsp_model_206ax/Kconfig @@ -39,6 +39,8 @@ config CPU_SPECIFIC_OPTIONS select SUPPORT_CPU_UCODE_IN_CBFS if HAVE_FSP_BIN select PARALLEL_CPU_INIT select TSC_SYNC_MFENCE + select HAVE_MONOTONIC_TIMER + select LAPIC_MONOTONIC_TIMER
config BOOTBLOCK_CPU_INIT string diff --git a/src/cpu/intel/haswell/Kconfig b/src/cpu/intel/haswell/Kconfig index fa02cba..9cda140 100644 --- a/src/cpu/intel/haswell/Kconfig +++ b/src/cpu/intel/haswell/Kconfig @@ -24,6 +24,7 @@ config CPU_SPECIFIC_OPTIONS select CPU_INTEL_FIRMWARE_INTERFACE_TABLE select PARALLEL_CPU_INIT select PARALLEL_MP + select LAPIC_MONOTONIC_TIMER
config BOOTBLOCK_CPU_INIT string diff --git a/src/cpu/intel/model_2065x/Kconfig b/src/cpu/intel/model_2065x/Kconfig index 3ef314d..4030df5 100644 --- a/src/cpu/intel/model_2065x/Kconfig +++ b/src/cpu/intel/model_2065x/Kconfig @@ -18,6 +18,8 @@ config CPU_SPECIFIC_OPTIONS select PARALLEL_CPU_INIT #select AP_IN_SIPI_WAIT select TSC_SYNC_MFENCE + select HAVE_MONOTONIC_TIMER + select LAPIC_MONOTONIC_TIMER
config BOOTBLOCK_CPU_INIT string diff --git a/src/cpu/intel/model_206ax/Kconfig b/src/cpu/intel/model_206ax/Kconfig index a679e00..1456f94 100644 --- a/src/cpu/intel/model_206ax/Kconfig +++ b/src/cpu/intel/model_206ax/Kconfig @@ -19,6 +19,8 @@ config CPU_SPECIFIC_OPTIONS select PARALLEL_CPU_INIT #select AP_IN_SIPI_WAIT select TSC_SYNC_MFENCE + select HAVE_MONOTONIC_TIMER + select LAPIC_MONOTONIC_TIMER
config BOOTBLOCK_CPU_INIT string diff --git a/src/mainboard/intel/baskingridge/Kconfig b/src/mainboard/intel/baskingridge/Kconfig index b52df97..acf4a75 100644 --- a/src/mainboard/intel/baskingridge/Kconfig +++ b/src/mainboard/intel/baskingridge/Kconfig @@ -11,7 +11,7 @@ config BOARD_SPECIFIC_OPTIONS # dummy select HAVE_ACPI_RESUME select HAVE_SMI_HANDLER select MAINBOARD_HAS_CHROMEOS - select LAPIC_MONOTONIC_TIMER + select MONOTONIC_TIMER_MSR
config MAINBOARD_DIR string
