Aaron Durbin (adurbin@chromium.org) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/13669
commit f45b72bd7a4196523d22a0236eb10f3165bbe981 Author: Aaron Durbin adurbin@chromium.org Date: Wed Feb 10 10:52:47 2016 -0600
lib/coreboot_table: add function to allow arch code to add records
Add lb_arch_add_records() To allow the architecture code to generically hook into the coreboot table generation.
BUG=chrome-os-partner:50214 BRANCH=glados TEST=With all subsequent patches confirmed lb_arch_add_records() is called when a strong symbol is provided.
Change-Id: I7c69c0ff0801392bbcf5aef586a48388b624afd4 Signed-off-by: Aaron Durbin adurbin@chromium.org --- src/include/boot/coreboot_tables.h | 3 +++ src/lib/coreboot_table.c | 5 +++++ 2 files changed, 8 insertions(+)
diff --git a/src/include/boot/coreboot_tables.h b/src/include/boot/coreboot_tables.h index ff942f1..34183a0 100644 --- a/src/include/boot/coreboot_tables.h +++ b/src/include/boot/coreboot_tables.h @@ -22,6 +22,9 @@ void lb_board(struct lb_header *header); /* Define this in soc or fsp driver to add specific table entries. */ void lb_framebuffer(struct lb_header *header);
+/* Allow arch to add records. */ +void lb_arch_add_records(struct lb_header *header); + /* * Function to retrieve MAC address(es) from the VPD and store them in the * coreboot table. diff --git a/src/lib/coreboot_table.c b/src/lib/coreboot_table.c index 86f22c9..cc336c2 100644 --- a/src/lib/coreboot_table.c +++ b/src/lib/coreboot_table.c @@ -389,6 +389,8 @@ static void lb_record_version_timestamp(struct lb_header *header)
void __attribute__((weak)) lb_board(struct lb_header *header) { /* NOOP */ }
+void __attribute__((weak)) lb_arch_add_records(struct lb_header *header) { } + static struct lb_forward *lb_forward(struct lb_header *header, struct lb_header *next_header) { struct lb_record *rec; @@ -540,6 +542,9 @@ unsigned long write_coreboot_table(
lb_boot_media_params(head);
+ /* Add architecture records. */ + lb_arch_add_records(head); + /* Add all cbmem entries into the coreboot tables. */ cbmem_add_records_to_cbtable(head);
