Attention is currently required from: Tarun Tuli, Subrata Banik, Kapil Porwal.
Hello Tarun Tuli, Subrata Banik, Kapil Porwal,
https://review.coreboot.org/c/coreboot/+/74572
Change subject: soc/intel/meteorlake: support Power Limits and Voltage Regulator ......................................................................
Power Limits and Voltage Regulator settings are the result of at least the following combination of factors: - The voltage regular itself - The TDP/SoC used - The board design (extra chips, cooling system, ...) - The Operating System and the use-cases - Power and performance measurements and tuning
Those settings being board design and use-case specific, they cannot be reduced to simple database indexed on a SoC ID and TDP. They must factor in the board itself.
Therefor, this patch adds support to apply Power Limits and Voltage Regulator settings supplied by a board specific database.
Note that the FSP includes default Power Limits and Voltage Regulator settings. These settings may be good enough for basic board bring-up but should be refined per board design.
BRANCH=None BUG=b:262499722 TEST=TBD
Change-Id: Ia1a6d4872718730951591cde6677557eebe3a944 Signed-off-by: Jeremy Compostella jeremy.compostella@intel.com --- M src/soc/intel/meteorlake/chip.h M src/soc/intel/meteorlake/chipset.cb M src/soc/intel/meteorlake/romstage/fsp_params.c M src/soc/intel/meteorlake/systemagent.c 4 files changed, 135 insertions(+), 44 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/72/74572/2
