Werner Zeh has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/62889 )
Change subject: soc/intel/apollolake: Correct enum for PrimaryVideoAdaptor FSP parameter ......................................................................
Commit 1a4496e79f21 (soc/{apl,glk}: Allow to select the primary graphics device) adds code to set the FSP parameter 'PrimaryVideoAdaptor' based on the enum description of the FspmUpd.h for Apollo Lake.
Unfortunately, the comment in the header file does not match the implementation in the FSP and hence setting PrimaryVideoAdaptor to 'GPU_PRIMARY_IGD' will be treated as if the selection was 'GPU_PRIMARY_PCI'. This in turn leads to Linux gfx driver issues for earlier driver implementations.
This commit corrects the enum values for the FSP parameter to match the implementation.
Change-Id: Iedbc144fa809f6d4587f5223b235ee95579c48f7 Signed-off-by: Werner Zeh werner.zeh@siemens.com --- M src/soc/intel/apollolake/romstage.c 1 file changed, 2 insertions(+), 2 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/89/62889/1
diff --git a/src/soc/intel/apollolake/romstage.c b/src/soc/intel/apollolake/romstage.c index 08543b1..1d8752f 100644 --- a/src/soc/intel/apollolake/romstage.c +++ b/src/soc/intel/apollolake/romstage.c @@ -232,8 +232,8 @@ static void soc_gpu_init_params(FSPM_UPD *mupd) { enum { - GPU_PRIMARY_IGD = 2, - GPU_PRIMARY_PCI = 3, + GPU_PRIMARY_IGD = 0, + GPU_PRIMARY_PCI = 1, }; /* Select primary GPU device */ if (CONFIG(ONBOARD_VGA_IS_PRIMARY) && is_devfn_enabled(SA_DEVFN_IGD))
