Furquan Shaikh has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/42738 )
Change subject: mb/google/zork: Add support for WiFi power sequencing ......................................................................
This change replaces variant_wifi_romstage_gpio_table() with variant_pcie_power_reset_configure() to handle the reset and power sequencing for WiFi devices pre- and post- v3 version of schematics.
These are the requirements that need to be satisfied: 1. As per PCI Express M.2 Specification Revision 3.0, Version 1.2, Section 3.1.4 "Power-up Timing", PERST# should stay disabled until `TPVPGL` time duration after device power has stabilized. Value of TPVPGL is implementation specific. 2. For Intel WiFi chip, it is known to get into a bad state if the above requirement is violated and hence requires a power cycle. 3. On pre-v3 schematics: - For both dalboz and trembyle references, GPIO42 drives WIFI_AUX_RESET_L which is pulled up to PP3300_WIFI. - For both dalboz and trembyle references, PP3300_WIFI is controlled using GPIO29. This pad gets pulled high by default on PWRGOOD because of internal pull-up. But, at RESET# it is known to have a glitch. When GPIO29 gets pulled high, it causes WIFI_AUX_RESET_L to be pulled high as well. This violates the PCIe power sequencing requirements. Hence, for pre-v3 schematics on both dalboz and trembyle, following sequence needs to be followed: a. Assert WIFI_AUX_RESET_L. b. Disable power to WiFi. c. Wait 10ms to allow WiFi power to go low. d. Enable power to WiFi. e. Wait 50ms as per PCIe specification. f. Deassert WIFI_AUX_RESET_L. 4. On v3 schematics: - For trembyle: WIFI_AUX_RESET_L is driven by GPIO86 which has an internal PU as well as an external PU to PP3300_WIFI. - For dalboz: WIFI_AUX_RESET is driven by GPIO29. This is active high and has an internal PU. It also has an external 1K PD to overcome internal PU. - For both dalboz and trembyle references, PP3300_WIFI is controlled by GPIO42 which has an internal PU and external PD. Trembyle schematics have a comment saying strong PD of 2.2K but the stuffed resistor is a weak one (499K). ON dalboz, it uses a weak PD (which doesn't look correct and instead should be a strong PD just like trembyle). Having a strong PD ensures that the WiFi power is kept disabled when coming out of G3 until coreboot configures GPIO42 as high. - Thus, for v3 schematics, following sequence needs to be followed: a. Assert WIFI_AUX_RESET{_L} signal. b. Enable power to WiFi. c. Wait 50ms as per PCIe specification. d. Deassert WIFI_AUX_RESET{_L} signal.
BUG=b:157686402, b:158257076 TEST=Verified that QCA and AX200 cards both continue working. Tested QCA on Dalboz and Trembyle. Tested AX200 on morphius.
Signed-off-by: Furquan Shaikh furquan@google.com Change-Id: I532131ee911d5efb5130d8710f3e01578f6c9627 --- M src/mainboard/google/zork/romstage.c M src/mainboard/google/zork/variants/baseboard/gpio_baseboard_dalboz.c M src/mainboard/google/zork/variants/baseboard/gpio_baseboard_trembyle.c M src/mainboard/google/zork/variants/baseboard/include/baseboard/variants.h M src/mainboard/google/zork/variants/berknip/Makefile.inc D src/mainboard/google/zork/variants/berknip/romstage.c M src/mainboard/google/zork/variants/morphius/Makefile.inc D src/mainboard/google/zork/variants/morphius/romstage.c 8 files changed, 123 insertions(+), 134 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/38/42738/1
diff --git a/src/mainboard/google/zork/romstage.c b/src/mainboard/google/zork/romstage.c index 0e3b2da..9d7b850 100644 --- a/src/mainboard/google/zork/romstage.c +++ b/src/mainboard/google/zork/romstage.c @@ -20,8 +20,7 @@
gpios = variant_romstage_gpio_table(&num_gpios); program_gpios(gpios, num_gpios); - gpios = variant_wifi_romstage_gpio_table(&num_gpios); - program_gpios(gpios, num_gpios); + variant_pcie_power_reset_configure();
mainboard_ec_init();
diff --git a/src/mainboard/google/zork/variants/baseboard/gpio_baseboard_dalboz.c b/src/mainboard/google/zork/variants/baseboard/gpio_baseboard_dalboz.c index d8a3714..d4ed86e 100644 --- a/src/mainboard/google/zork/variants/baseboard/gpio_baseboard_dalboz.c +++ b/src/mainboard/google/zork/variants/baseboard/gpio_baseboard_dalboz.c @@ -1,6 +1,8 @@ /* SPDX-License-Identifier: GPL-2.0-or-later */
#include <baseboard/variants.h> +#include <delay.h> +#include <gpio.h> #include <soc/gpio.h> #include <soc/smi.h> #include <stdlib.h> @@ -20,8 +22,6 @@ PAD_NF(GPIO_27, PCIE_RST1_L, PULL_NONE), /* NVME_AUX_RESET_L */ PAD_GPO(GPIO_40, HIGH), - /* WIFI_AUX_RESET_L */ - PAD_GPO(GPIO_42, HIGH), /* EN_PWR_TOUCHPAD_PS2 - reset */ PAD_GPO(GPIO_67, LOW), /* EMMC_RESET - reset (default stuffing unused)*/ @@ -44,11 +44,6 @@ PAD_GPO(GPIO_142, HIGH), };
-static const struct soc_amd_gpio gpio_set_wifi_pre_v3[] = { - /* EN_PWR_WIFI */ - PAD_GPO(GPIO_29, HIGH), -}; - static const struct soc_amd_gpio gpio_set_stage_rom_v3[] = { /* PEN_POWER_EN - reset */ PAD_GPO(GPIO_5, LOW), @@ -62,8 +57,6 @@ PAD_NF(GPIO_26, PCIE_RST_L, PULL_NONE), /* PCIE_RST1_L - Variable timings (May remove) */ PAD_NF(GPIO_27, PCIE_RST1_L, PULL_NONE), - /* WIFI_AUX_RESET */ - PAD_GPO(GPIO_29, LOW), /* NVME_AUX_RESET_L */ PAD_GPO(GPIO_40, HIGH), /* EMMC_RESET - reset (default stuffing unused)*/ @@ -86,11 +79,6 @@ PAD_GPO(GPIO_142, HIGH), };
-static const struct soc_amd_gpio gpio_set_wifi_v3[] = { - /* EN_PWR_WIFI */ - PAD_GPO(GPIO_42, HIGH), -}; - static const struct soc_amd_gpio gpio_set_stage_ram[] = {
/* PWR_BTN_L */ @@ -220,21 +208,6 @@ }
const __weak -struct soc_amd_gpio *variant_wifi_romstage_gpio_table(size_t *size) -{ - uint32_t board_version; - - if (!google_chromeec_cbi_get_board_version(&board_version) && - (board_version >= CONFIG_VARIANT_MIN_BOARD_ID_V3_SCHEMATICS)) { - *size = ARRAY_SIZE(gpio_set_wifi_v3); - return gpio_set_wifi_v3; - } - - *size = ARRAY_SIZE(gpio_set_wifi_pre_v3); - return gpio_set_wifi_pre_v3; -} - -const __weak struct soc_amd_gpio *variant_base_gpio_table(size_t *size) { *size = ARRAY_SIZE(gpio_set_stage_ram); @@ -252,3 +225,61 @@ { return NULL; } + +static void wifi_power_reset_configure_v3(void) +{ + /* + * Configure WiFi GPIOs such that: + * - WIFI_AUX_RESET is configured first to assert PERST# to WiFi device. + * - Enable power to WiFi using EN_PWR_WIFI. + * - Wait for 50ms after power to WiFi is enabled. + * - Deassert PERST# to WiFi device by driving WIFI_AUX_RESET low. + */ + static const struct soc_amd_gpio v3_wifi_table[] = { + /* WIFI_AUX_RESET */ + PAD_GPO(GPIO_29, HIGH), + /* EN_PWR_WIFI */ + PAD_GPO(GPIO_42, HIGH), + }; + program_gpios(v3_wifi_table, ARRAY_SIZE(v3_wifi_table)); + + mdelay(50); + gpio_set(GPIO_29, 0); +} + +static void wifi_power_reset_configure_pre_v3(void) +{ + /* + * Configure WiFi GPIOs such that: + * - WIFI_AUX_RESET_L is configured first to assert PERST# to WiFi device. + * - Disable power to WiFi since GPIO_29 goes high on PWRGOOD but has a glitch on RESET# + * deassertion causing WiFi to enter a bad state. + * - Wait 10ms for WiFi power to go low. + * - Enable power to WiFi using EN_PWR_WIFI. + * - Wait for 50ms after power to WiFi is enabled. + * - Deassert WIFI_AUX_RESET_L. + */ + static const struct soc_amd_gpio pre_v3_wifi_table[] = { + /* WIFI_AUX_RESET_L */ + PAD_GPO(GPIO_42, LOW), + /* EN_PWR_WIFI */ + PAD_GPO(GPIO_29, LOW), + }; + program_gpios(pre_v3_wifi_table, ARRAY_SIZE(pre_v3_wifi_table)); + + mdelay(10); + gpio_set(GPIO_29, 1); + mdelay(50); + gpio_set(GPIO_42, 1); +} + +__weak void variant_pcie_power_reset_configure(void) +{ + uint32_t board_version; + + if (!google_chromeec_cbi_get_board_version(&board_version) && + (board_version >= CONFIG_VARIANT_MIN_BOARD_ID_V3_SCHEMATICS)) + wifi_power_reset_configure_v3(); + else + wifi_power_reset_configure_pre_v3(); +} diff --git a/src/mainboard/google/zork/variants/baseboard/gpio_baseboard_trembyle.c b/src/mainboard/google/zork/variants/baseboard/gpio_baseboard_trembyle.c index bac5333..abee520 100644 --- a/src/mainboard/google/zork/variants/baseboard/gpio_baseboard_trembyle.c +++ b/src/mainboard/google/zork/variants/baseboard/gpio_baseboard_trembyle.c @@ -1,6 +1,8 @@ /* SPDX-License-Identifier: GPL-2.0-or-later */
#include <baseboard/variants.h> +#include <delay.h> +#include <gpio.h> #include <soc/gpio.h> #include <soc/smi.h> #include <stdlib.h> @@ -20,8 +22,6 @@ PAD_NF(GPIO_27, PCIE_RST1_L, PULL_NONE), /* NVME_AUX_RESET_L */ PAD_GPO(GPIO_40, HIGH), - /* WIFI_AUX_RESET_L */ - PAD_GPO(GPIO_42, HIGH), /* EN_PWR_TOUCHPAD_PS2 - reset */ PAD_GPO(GPIO_67, LOW), /* EMMC_RESET - reset (default stuffing unused)*/ @@ -42,11 +42,6 @@ PAD_GPO(GPIO_142, HIGH), };
-static const struct soc_amd_gpio gpio_set_wifi_pre_v3[] = { - /* EN_PWR_WIFI */ - PAD_GPO(GPIO_29, HIGH), -}; - static const struct soc_amd_gpio gpio_set_stage_rom_v3[] = { /* PEN_POWER_EN - reset */ PAD_GPO(GPIO_5, LOW), @@ -66,8 +61,6 @@ PAD_GPO(GPIO_68, HIGH), /* EN_PWR_CAMERA - reset */ PAD_GPO(GPIO_76, LOW), - /* WIFI_AUX_RESET_L */ - PAD_GPO(GPIO_86, HIGH), /* CLK_REQ0_L - WIFI */ PAD_NF(GPIO_92, CLK_REQ0_L, PULL_UP), /* CLK_REQ1_L - SD Card */ @@ -82,11 +75,6 @@ PAD_GPO(GPIO_142, HIGH), };
/* PWR_BTN_L */ @@ -215,21 +203,6 @@ }
const __weak -struct soc_amd_gpio *variant_wifi_romstage_gpio_table(size_t *size) -{ - uint32_t board_version; - - if (!google_chromeec_cbi_get_board_version(&board_version) && - (board_version >= CONFIG_VARIANT_MIN_BOARD_ID_V3_SCHEMATICS)) { - *size = ARRAY_SIZE(gpio_set_wifi_v3); - return gpio_set_wifi_v3; - } - - *size = ARRAY_SIZE(gpio_set_wifi_pre_v3); - return gpio_set_wifi_pre_v3; -} - -const __weak struct soc_amd_gpio *variant_base_gpio_table(size_t *size) { *size = ARRAY_SIZE(gpio_set_stage_ram); @@ -247,3 +220,61 @@ { return NULL; } + +static void wifi_power_reset_configure_v3(void) +{ + /* + * Configure WiFi GPIOs such that: + * - WIFI_AUX_RESET_L is configured first to assert PERST# to WiFi device. + * - Enable power to WiFi using EN_PWR_WIFI. + * - Wait for 50ms after power to WiFi is enabled. + * - Deassert WIFI_AUX_RESET_L. + */ + static const struct soc_amd_gpio v3_wifi_table[] = { + /* WIFI_AUX_RESET_L */ + PAD_GPO(GPIO_86, LOW), + /* EN_PWR_WIFI */ + PAD_GPO(GPIO_42, HIGH), + }; + program_gpios(v3_wifi_table, ARRAY_SIZE(v3_wifi_table)); + + mdelay(50); + gpio_set(GPIO_86, 1); +} + +static void wifi_power_reset_configure_pre_v3(void) +{ + /* + * Configure WiFi GPIOs such that: + * - WIFI_AUX_RESET_L is configured first to assert PERST# to WiFi device. + * - Disable power to WiFi since GPIO_29 goes high on PWRGOOD but has a glitch on RESET# + * deassertion causing WiFi to enter a bad state. + * - Wait 10ms for WiFi power to go low. + * - Enable power to WiFi using EN_PWR_WIFI. + * - Wait for 50ms after power to WiFi is enabled. + * - Deassert WIFI_AUX_RESET_L. + */ + static const struct soc_amd_gpio pre_v3_wifi_table[] = { + /* WIFI_AUX_RESET_L */ + PAD_GPO(GPIO_42, LOW), + /* EN_PWR_WIFI */ + PAD_GPO(GPIO_29, LOW), + }; + program_gpios(pre_v3_wifi_table, ARRAY_SIZE(pre_v3_wifi_table)); + + mdelay(10); + gpio_set(GPIO_29, 1); + mdelay(50); + gpio_set(GPIO_42, 1); +} + +__weak void variant_pcie_power_reset_configure(void) +{ + uint32_t board_version; + + if (!google_chromeec_cbi_get_board_version(&board_version) && + (board_version >= CONFIG_VARIANT_MIN_BOARD_ID_V3_SCHEMATICS)) + wifi_power_reset_configure_v3(); + else + wifi_power_reset_configure_pre_v3(); +} diff --git a/src/mainboard/google/zork/variants/baseboard/include/baseboard/variants.h b/src/mainboard/google/zork/variants/baseboard/include/baseboard/variants.h index 84a9e9c..4f8f225 100644 --- a/src/mainboard/google/zork/variants/baseboard/include/baseboard/variants.h +++ b/src/mainboard/google/zork/variants/baseboard/include/baseboard/variants.h @@ -13,7 +13,6 @@ const struct sci_source *get_gpe_table(size_t *num); const struct soc_amd_gpio *variant_early_gpio_table(size_t *size); const struct soc_amd_gpio *variant_romstage_gpio_table(size_t *size); -const struct soc_amd_gpio *variant_wifi_romstage_gpio_table(size_t *size); /* * This function provides base GPIO configuration table. It is typically provided by * baseboard using a weak implementation. If GPIO configuration for a variant differs @@ -29,6 +28,8 @@ void variant_romstage_entry(void); /* Modify devictree settings during ramstage. */ void variant_devtree_update(void); +/* Configure PCIe power and reset lines as per variant sequencing requirements. */ +void variant_pcie_power_reset_configure(void);
/* Per variant FSP-S initialization, default implementation in baseboard and * overrideable by the variant. */ diff --git a/src/mainboard/google/zork/variants/berknip/Makefile.inc b/src/mainboard/google/zork/variants/berknip/Makefile.inc index b1212bc..57e7136 100644 --- a/src/mainboard/google/zork/variants/berknip/Makefile.inc +++ b/src/mainboard/google/zork/variants/berknip/Makefile.inc @@ -2,6 +2,4 @@
subdirs-y += ./spd
-romstage-y += ./romstage.c - ramstage-y += gpio.c diff --git a/src/mainboard/google/zork/variants/berknip/romstage.c b/src/mainboard/google/zork/variants/berknip/romstage.c deleted file mode 100644 index 67ad31c..0000000 --- a/src/mainboard/google/zork/variants/berknip/romstage.c +++ /dev/null @@ -1,27 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0-only */ - -#include <stddef.h> -#include <soc/romstage.h> -#include <baseboard/variants.h> -#include <ec/google/chromeec/ec.h> - -#include <gpio.h> -#include <soc/gpio.h> -#include <variant/gpio.h> - -void variant_romstage_entry(void) -{ - /* Power the wifi card */ - gpio_set(EN_PWR_WIFI, 1); -} - -static const struct soc_amd_gpio berknip_gpio_set_wifi[] = { - /* EN_PWR_WIFI - Power off. Pull high in romstage.c */ - PAD_GPO(GPIO_29, LOW), -}; - -const struct soc_amd_gpio *variant_wifi_romstage_gpio_table(size_t *size) -{ - *size = ARRAY_SIZE(berknip_gpio_set_wifi); - return berknip_gpio_set_wifi; -} diff --git a/src/mainboard/google/zork/variants/morphius/Makefile.inc b/src/mainboard/google/zork/variants/morphius/Makefile.inc index b1212bc..57e7136 100644 --- a/src/mainboard/google/zork/variants/morphius/Makefile.inc +++ b/src/mainboard/google/zork/variants/morphius/Makefile.inc @@ -2,6 +2,4 @@
subdirs-y += ./spd
-romstage-y += ./romstage.c - ramstage-y += gpio.c diff --git a/src/mainboard/google/zork/variants/morphius/romstage.c b/src/mainboard/google/zork/variants/morphius/romstage.c deleted file mode 100644 index 876b836..0000000 --- a/src/mainboard/google/zork/variants/morphius/romstage.c +++ /dev/null @@ -1,42 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0-or-later */ - -#include <stddef.h> -#include <soc/romstage.h> -#include <baseboard/variants.h> -#include <ec/google/chromeec/ec.h> - -#include <gpio.h> -#include <soc/gpio.h> -#include <variant/gpio.h> -#include <delay.h> - -void variant_romstage_entry(void) -{ - //SET WIFI_PCIE_RESET_L HIGH - gpio_set(WIFI_PCIE_RESET_L, 1); - - /* Power the wifi card */ - /* wait 10ms to discharge EN_PWR_WIFI to 0V */ - mdelay(10); - gpio_set(EN_PWR_WIFI, 1); - - /* SET WIFI_PCIE_RESET_L LOW */ - gpio_set(WIFI_PCIE_RESET_L, 0); - - /* Qualcomm Atheros NFA344A needs at least 10ms delay */ - mdelay(10); - - /* SET WIFI_PCIE_RESET_L HIGH */ - gpio_set(WIFI_PCIE_RESET_L, 1); -} - -static const struct soc_amd_gpio morphius_gpio_set_wifi[] = { - /* EN_PWR_WIFI - Power off. Pull high in romstage.c */ - PAD_GPO(GPIO_29, LOW), -}; - -const struct soc_amd_gpio *variant_wifi_romstage_gpio_table(size_t *size) -{ - *size = ARRAY_SIZE(morphius_gpio_set_wifi); - return morphius_gpio_set_wifi; -}
Aaron Durbin has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/42738 )
Patch Set 2: Code-Review+2
Furquan Shaikh has submitted this change. ( https://review.coreboot.org/c/coreboot/+/42738 )
Signed-off-by: Furquan Shaikh furquan@google.com Change-Id: I532131ee911d5efb5130d8710f3e01578f6c9627 Reviewed-on: https://review.coreboot.org/c/coreboot/+/42738 Reviewed-by: Aaron Durbin adurbin@chromium.org Tested-by: build bot (Jenkins) no-reply@coreboot.org --- M src/mainboard/google/zork/romstage.c M src/mainboard/google/zork/variants/baseboard/gpio_baseboard_dalboz.c M src/mainboard/google/zork/variants/baseboard/gpio_baseboard_trembyle.c M src/mainboard/google/zork/variants/baseboard/include/baseboard/variants.h M src/mainboard/google/zork/variants/berknip/Makefile.inc D src/mainboard/google/zork/variants/berknip/romstage.c M src/mainboard/google/zork/variants/morphius/Makefile.inc D src/mainboard/google/zork/variants/morphius/romstage.c 8 files changed, 123 insertions(+), 134 deletions(-)
Approvals: build bot (Jenkins): Verified Aaron Durbin: Looks good to me, approved
diff --git a/src/mainboard/google/zork/variants/baseboard/gpio_baseboard_dalboz.c b/src/mainboard/google/zork/variants/baseboard/gpio_baseboard_dalboz.c index 50c842b..35e1829 100644 --- a/src/mainboard/google/zork/variants/baseboard/gpio_baseboard_dalboz.c +++ b/src/mainboard/google/zork/variants/baseboard/gpio_baseboard_dalboz.c @@ -1,6 +1,8 @@ /* SPDX-License-Identifier: GPL-2.0-or-later */
/* PWR_BTN_L */ @@ -219,21 +207,6 @@ }
const __weak -struct soc_amd_gpio *variant_wifi_romstage_gpio_table(size_t *size) -{ - uint32_t board_version; - - if (!google_chromeec_cbi_get_board_version(&board_version) && - (board_version >= CONFIG_VARIANT_MIN_BOARD_ID_V3_SCHEMATICS)) { - *size = ARRAY_SIZE(gpio_set_wifi_v3); - return gpio_set_wifi_v3; - } - - *size = ARRAY_SIZE(gpio_set_wifi_pre_v3); - return gpio_set_wifi_pre_v3; -} - -const __weak struct soc_amd_gpio *variant_base_gpio_table(size_t *size) { *size = ARRAY_SIZE(gpio_set_stage_ram); @@ -251,3 +224,61 @@ { return NULL; } + +static void wifi_power_reset_configure_v3(void) +{ + /* + * Configure WiFi GPIOs such that: + * - WIFI_AUX_RESET is configured first to assert PERST# to WiFi device. + * - Enable power to WiFi using EN_PWR_WIFI. + * - Wait for 50ms after power to WiFi is enabled. + * - Deassert PERST# to WiFi device by driving WIFI_AUX_RESET low. + */ + static const struct soc_amd_gpio v3_wifi_table[] = { + /* WIFI_AUX_RESET */ + PAD_GPO(GPIO_29, HIGH), + /* EN_PWR_WIFI */ + PAD_GPO(GPIO_42, HIGH), + }; + program_gpios(v3_wifi_table, ARRAY_SIZE(v3_wifi_table)); + + mdelay(50); + gpio_set(GPIO_29, 0); +} + +static void wifi_power_reset_configure_pre_v3(void) +{ + /* + * Configure WiFi GPIOs such that: + * - WIFI_AUX_RESET_L is configured first to assert PERST# to WiFi device. + * - Disable power to WiFi since GPIO_29 goes high on PWRGOOD but has a glitch on RESET# + * deassertion causing WiFi to enter a bad state. + * - Wait 10ms for WiFi power to go low. + * - Enable power to WiFi using EN_PWR_WIFI. + * - Wait for 50ms after power to WiFi is enabled. + * - Deassert WIFI_AUX_RESET_L. + */ + static const struct soc_amd_gpio pre_v3_wifi_table[] = { + /* WIFI_AUX_RESET_L */ + PAD_GPO(GPIO_42, LOW), + /* EN_PWR_WIFI */ + PAD_GPO(GPIO_29, LOW), + }; + program_gpios(pre_v3_wifi_table, ARRAY_SIZE(pre_v3_wifi_table)); + + mdelay(10); + gpio_set(GPIO_29, 1); + mdelay(50); + gpio_set(GPIO_42, 1); +} + +__weak void variant_pcie_power_reset_configure(void) +{ + uint32_t board_version; + + if (!google_chromeec_cbi_get_board_version(&board_version) && + (board_version >= CONFIG_VARIANT_MIN_BOARD_ID_V3_SCHEMATICS)) + wifi_power_reset_configure_v3(); + else + wifi_power_reset_configure_pre_v3(); +} diff --git a/src/mainboard/google/zork/variants/baseboard/gpio_baseboard_trembyle.c b/src/mainboard/google/zork/variants/baseboard/gpio_baseboard_trembyle.c index d3f7ae3..3f02f00 100644 --- a/src/mainboard/google/zork/variants/baseboard/gpio_baseboard_trembyle.c +++ b/src/mainboard/google/zork/variants/baseboard/gpio_baseboard_trembyle.c @@ -1,6 +1,8 @@ /* SPDX-License-Identifier: GPL-2.0-or-later */
/* PWR_BTN_L */ @@ -214,21 +202,6 @@ }
const __weak -struct soc_amd_gpio *variant_wifi_romstage_gpio_table(size_t *size) -{ - uint32_t board_version; - - if (!google_chromeec_cbi_get_board_version(&board_version) && - (board_version >= CONFIG_VARIANT_MIN_BOARD_ID_V3_SCHEMATICS)) { - *size = ARRAY_SIZE(gpio_set_wifi_v3); - return gpio_set_wifi_v3; - } - - *size = ARRAY_SIZE(gpio_set_wifi_pre_v3); - return gpio_set_wifi_pre_v3; -} - -const __weak struct soc_amd_gpio *variant_base_gpio_table(size_t *size) { *size = ARRAY_SIZE(gpio_set_stage_ram); @@ -246,3 +219,61 @@ { return NULL; } + +static void wifi_power_reset_configure_v3(void) +{ + /* + * Configure WiFi GPIOs such that: + * - WIFI_AUX_RESET_L is configured first to assert PERST# to WiFi device. + * - Enable power to WiFi using EN_PWR_WIFI. + * - Wait for 50ms after power to WiFi is enabled. + * - Deassert WIFI_AUX_RESET_L. + */ + static const struct soc_amd_gpio v3_wifi_table[] = { + /* WIFI_AUX_RESET_L */ + PAD_GPO(GPIO_86, LOW), + /* EN_PWR_WIFI */ + PAD_GPO(GPIO_42, HIGH), + }; + program_gpios(v3_wifi_table, ARRAY_SIZE(v3_wifi_table)); + + mdelay(50); + gpio_set(GPIO_86, 1); +} + +static void wifi_power_reset_configure_pre_v3(void) +{ + /* + * Configure WiFi GPIOs such that: + * - WIFI_AUX_RESET_L is configured first to assert PERST# to WiFi device. + * - Disable power to WiFi since GPIO_29 goes high on PWRGOOD but has a glitch on RESET# + * deassertion causing WiFi to enter a bad state. + * - Wait 10ms for WiFi power to go low. + * - Enable power to WiFi using EN_PWR_WIFI. + * - Wait for 50ms after power to WiFi is enabled. + * - Deassert WIFI_AUX_RESET_L. + */ + static const struct soc_amd_gpio pre_v3_wifi_table[] = { + /* WIFI_AUX_RESET_L */ + PAD_GPO(GPIO_42, LOW), + /* EN_PWR_WIFI */ + PAD_GPO(GPIO_29, LOW), + }; + program_gpios(pre_v3_wifi_table, ARRAY_SIZE(pre_v3_wifi_table)); + + mdelay(10); + gpio_set(GPIO_29, 1); + mdelay(50); + gpio_set(GPIO_42, 1); +} + +__weak void variant_pcie_power_reset_configure(void) +{ + uint32_t board_version; + + if (!google_chromeec_cbi_get_board_version(&board_version) && + (board_version >= CONFIG_VARIANT_MIN_BOARD_ID_V3_SCHEMATICS)) + wifi_power_reset_configure_v3(); + else + wifi_power_reset_configure_pre_v3(); +} diff --git a/src/mainboard/google/zork/variants/baseboard/include/baseboard/variants.h b/src/mainboard/google/zork/variants/baseboard/include/baseboard/variants.h index 84a9e9c..4f8f225 100644 --- a/src/mainboard/google/zork/variants/baseboard/include/baseboard/variants.h +++ b/src/mainboard/google/zork/variants/baseboard/include/baseboard/variants.h @@ -13,7 +13,6 @@ const struct sci_source *get_gpe_table(size_t *num); const struct soc_amd_gpio *variant_early_gpio_table(size_t *size); const struct soc_amd_gpio *variant_romstage_gpio_table(size_t *size); -const struct soc_amd_gpio *variant_wifi_romstage_gpio_table(size_t *size); /* * This function provides base GPIO configuration table. It is typically provided by * baseboard using a weak implementation. If GPIO configuration for a variant differs @@ -29,6 +28,8 @@ void variant_romstage_entry(void); /* Modify devictree settings during ramstage. */ void variant_devtree_update(void); +/* Configure PCIe power and reset lines as per variant sequencing requirements. */ +void variant_pcie_power_reset_configure(void);
subdirs-y += ./spd
subdirs-y += ./spd
