Subrata Banik (subrata.banik@intel.com) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/18226
commit a94a4f5cc0b56f13f66b2b0be601e71bfe650656 Author: Andrey Petrov andrey.petrov@intel.com Date: Tue Jan 24 21:56:36 2017 -0800
soc/intel/apollolake: Move XDCI in its own file
Split out dual-port switching functionality into dedicated xdci.c.
Change-Id: Ia58fc3fb6d017dd0c19cc450d1caba307fc89a7b Signed-off-by: Andrey Petrov andrey.petrov@intel.com --- src/soc/intel/apollolake/Makefile.inc | 1 + src/soc/intel/apollolake/include/soc/pci_ids.h | 1 + src/soc/intel/apollolake/xdci.c | 105 +++++++++++++++++++++++++ src/soc/intel/apollolake/xhci.c | 72 ----------------- 4 files changed, 107 insertions(+), 72 deletions(-)
diff --git a/src/soc/intel/apollolake/Makefile.inc b/src/soc/intel/apollolake/Makefile.inc index df93f0b..5e1cf73 100644 --- a/src/soc/intel/apollolake/Makefile.inc +++ b/src/soc/intel/apollolake/Makefile.inc @@ -83,6 +83,7 @@ ramstage-y += reset.c ramstage-y += smi.c ramstage-y += sram.c ramstage-y += spi.c +ramstage-y += xdci.c ramstage-y += xhci.c
postcar-y += flash_ctrlr.c diff --git a/src/soc/intel/apollolake/include/soc/pci_ids.h b/src/soc/intel/apollolake/include/soc/pci_ids.h index 130263b..4c2956f 100644 --- a/src/soc/intel/apollolake/include/soc/pci_ids.h +++ b/src/soc/intel/apollolake/include/soc/pci_ids.h @@ -28,6 +28,7 @@ #define PCI_DEVICE_ID_APOLLOLAKE_AUDIO 0x5a98 /* 00:0e.0 */ #define PCI_DEVICE_ID_APOLLOLAKE_SATA 0x5ae0 /* 00:12.0 */ #define PCI_DEVICE_ID_APOLLOLAKE_XHCI 0x5aa8 /* 00:15.0 */ +#define PCI_DEVICE_ID_APOLLOLAKE_XDCI 0x5aaa /* 00:15.1 */ #define PCI_DEVICE_ID_APOLLOLAKE_I2C0 0x5aac /* 00:16.0 */ #define PCI_DEVICE_ID_APOLLOLAKE_I2C1 0x5aae /* 00:16.1 */ #define PCI_DEVICE_ID_APOLLOLAKE_I2C2 0x5ab0 /* 00:16.2 */ diff --git a/src/soc/intel/apollolake/xdci.c b/src/soc/intel/apollolake/xdci.c new file mode 100644 index 0000000..2812957 --- /dev/null +++ b/src/soc/intel/apollolake/xdci.c @@ -0,0 +1,105 @@ +/* + * This file is part of the coreboot project. + * + * Copyright 2016 Google Inc. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#include <arch/io.h> +#include <console/console.h> +#include <device/device.h> +#include <device/pci.h> +#include <device/pci_ids.h> +#include <soc/pci_devs.h> +#include <soc/pci_ids.h> +#include <timer.h> + +#define DUAL_ROLE_CFG0 0x80d8 +# define DRD_CONFIG_MASK (0x3 << 0) +# define DRD_CONFIG_DYNAMIC (0x0 << 0) +# define DRD_CONFIG_HOST (0x1 << 0) +# define DRD_CONFIG_DEVICE (0x2 << 0) +# define SW_VBUS_VALID_MASK (1 << 24) +# define SW_VBUS_DEASSERT_VALID (0 << 24) +# define SW_VBUS_ASSERT_VALID (1 << 24) +# define SW_IDPIN_EN_MASK (1 << 21) +# define SW_IDPIN_DIS (0 << 21) +# define SW_IDPIN_EN (1 << 21) +# define SW_IDPIN_MASK (1 << 20) +# define SW_IDPIN_HOST (0 << 20) +# define SW_IDPIN_DEVICE (1 << 20) +#define DUAL_ROLE_CFG1 0x80dc +# define DRD_MODE_MASK (1 << 29) +# define DRD_MODE_DEVICE (0 << 29) +# define DRD_MODE_HOST (1 << 29) + +static void configure_host_mode_port0(struct device *dev) +{ + uint32_t *cfg0; + uint32_t *cfg1; + const struct resource *res; + uint32_t reg; + struct stopwatch sw; + struct device *xhci_dev = XHCI_DEV; + + /* + * Only default to host mode if the xdci device is present and + * enabled. If it's disabled assume the switch was already done + * in FSP. + */ + if (!dev->enabled || !xhci_dev->enabled) + return; + + printk(BIOS_INFO, "Putting port 0 into host mode.\n"); + + res = find_resource(xhci_dev, PCI_BASE_ADDRESS_0); + + cfg0 = (void *)(uintptr_t)(res->base + DUAL_ROLE_CFG0); + cfg1 = (void *)(uintptr_t)(res->base + DUAL_ROLE_CFG1); + + reg = read32(cfg0); + reg &= ~(DRD_CONFIG_MASK | SW_IDPIN_EN_MASK | SW_IDPIN_MASK); + reg &= ~(SW_VBUS_VALID_MASK); + reg |= DRD_CONFIG_DYNAMIC | SW_IDPIN_EN | SW_IDPIN_HOST; + reg |= SW_VBUS_DEASSERT_VALID; + write32(cfg0, reg); + + stopwatch_init_msecs_expire(&sw, 10); + + /* Wait for the host mode status bit. */ + while ((read32(cfg1) & DRD_MODE_MASK) != DRD_MODE_HOST) { + if (stopwatch_expired(&sw)) { + printk(BIOS_INFO, "Timed out waiting for host mode.\n"); + break; + } + } + + printk(BIOS_INFO, "XHCI port 0 host switch over took %lu ms\n", + stopwatch_duration_msecs(&sw)); +} + +static void xdci_init(struct device *dev) +{ + configure_host_mode_port0(dev); +} + +static const struct device_operations device_ops = { + .read_resources = pci_dev_read_resources, + .set_resources = pci_dev_set_resources, + .enable_resources = pci_dev_enable_resources, + .init = xdci_init, +}; + +static const struct pci_driver pmc __pci_driver = { + .ops = &device_ops, + .vendor = PCI_VENDOR_ID_INTEL, + .device = PCI_DEVICE_ID_APOLLOLAKE_XDCI, +}; diff --git a/src/soc/intel/apollolake/xhci.c b/src/soc/intel/apollolake/xhci.c index 7b3cb46..3dd4f7d 100644 --- a/src/soc/intel/apollolake/xhci.c +++ b/src/soc/intel/apollolake/xhci.c @@ -14,88 +14,16 @@ */
#include <arch/io.h> -#include <console/console.h> #include <device/device.h> #include <device/pci.h> #include <device/pci_ids.h> #include <soc/pci_devs.h> #include <soc/pci_ids.h> -#include <timer.h> - -#define DUAL_ROLE_CFG0 0x80d8 -# define DRD_CONFIG_MASK (0x3 << 0) -# define DRD_CONFIG_DYNAMIC (0x0 << 0) -# define DRD_CONFIG_HOST (0x1 << 0) -# define DRD_CONFIG_DEVICE (0x2 << 0) -# define SW_VBUS_VALID_MASK (1 << 24) -# define SW_VBUS_DEASSERT_VALID (0 << 24) -# define SW_VBUS_ASSERT_VALID (1 << 24) -# define SW_IDPIN_EN_MASK (1 << 21) -# define SW_IDPIN_DIS (0 << 21) -# define SW_IDPIN_EN (1 << 21) -# define SW_IDPIN_MASK (1 << 20) -# define SW_IDPIN_HOST (0 << 20) -# define SW_IDPIN_DEVICE (1 << 20) -#define DUAL_ROLE_CFG1 0x80dc -# define DRD_MODE_MASK (1 << 29) -# define DRD_MODE_DEVICE (0 << 29) -# define DRD_MODE_HOST (1 << 29) - -static void configure_host_mode_port0(struct device *dev) -{ - uint32_t *cfg0; - uint32_t *cfg1; - const struct resource *res; - uint32_t reg; - struct device *xdci_dev = XDCI_DEV; - struct stopwatch sw; - - /* - * Only default to host mode if the xdci device is present and - * enabled. If it's disabled assume the switch was already done - * in FSP. - */ - if (xdci_dev == NULL || !xdci_dev->enabled) - return; - - printk(BIOS_INFO, "Putting port 0 into host mode.\n"); - - res = find_resource(dev, PCI_BASE_ADDRESS_0); - - cfg0 = (void *)(uintptr_t)(res->base + DUAL_ROLE_CFG0); - cfg1 = (void *)(uintptr_t)(res->base + DUAL_ROLE_CFG1); - - reg = read32(cfg0); - reg &= ~(DRD_CONFIG_MASK | SW_IDPIN_EN_MASK | SW_IDPIN_MASK); - reg &= ~(SW_VBUS_VALID_MASK); - reg |= DRD_CONFIG_DYNAMIC | SW_IDPIN_EN | SW_IDPIN_HOST; - reg |= SW_VBUS_DEASSERT_VALID; - write32(cfg0, reg); - - stopwatch_init_msecs_expire(&sw, 10); - - /* Wait for the host mode status bit. */ - while ((read32(cfg1) & DRD_MODE_MASK) != DRD_MODE_HOST) { - if (stopwatch_expired(&sw)) { - printk(BIOS_INFO, "Timed out waiting for host mode.\n"); - break; - } - } - - printk(BIOS_INFO, "XHCI port 0 host switch over took %lu ms\n", - stopwatch_duration_msecs(&sw)); -} - -static void xhci_init(struct device *dev) -{ - configure_host_mode_port0(dev); -}
static const struct device_operations device_ops = { .read_resources = pci_dev_read_resources, .set_resources = pci_dev_set_resources, .enable_resources = pci_dev_enable_resources, - .init = xhci_init, };
