Aaron Durbin has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/42734 )
Change subject: soc/amd/picasso: fix host bridge bus numbers ......................................................................
The host bridge's resources covering bus numbers assumed 256 buses were being decoded. However, MMCONFIG was only covering 64 buses. This results in Linux complaining:
acpi PNP0A08:00: [Firmware Info]: MMCONFIG for domain 0000 [bus 00-3f] only partially covers this bridge
When retrieving the host bridge's resources fix up the bus numbers to utilize MMCONF_BUS_NUMBER Kconfig. I couldn't keep IASL from complaining when trying to do this statically.
BUG=b:158874061
Signed-off-by: Aaron Durbin adurbin@chromium.org Change-Id: Ief1901743e2c99f583ef0181490d493d23734f64 --- M src/soc/amd/picasso/acpi/sb_pci0_fch.asl 1 file changed, 5 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/34/42734/1
diff --git a/src/soc/amd/picasso/acpi/sb_pci0_fch.asl b/src/soc/amd/picasso/acpi/sb_pci0_fch.asl index 27c4661..7488b55 100644 --- a/src/soc/amd/picasso/acpi/sb_pci0_fch.asl +++ b/src/soc/amd/picasso/acpi/sb_pci0_fch.asl @@ -101,6 +101,11 @@ Subtract(Local0, TOM1, Local0) Store(Local0, MM1L)
+ CreateWordField(CRES, ^PSB0._MAX, BMAX) + CreateWordField(CRES, ^PSB0._LEN, BLEN) + Store(CONFIG_MMCONF_BUS_NUMBER - 1, BMAX) + Store(CONFIG_MMCONF_BUS_NUMBER, BLEN) + Return(CRES) /* note to change the Name buffer */ } /* end of Method(_SB.PCI0._CRS) */
Furquan Shaikh has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/42734 )
Patch Set 1: Code-Review+2
Felix Held has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/42734 )
Aaron Durbin has submitted this change. ( https://review.coreboot.org/c/coreboot/+/42734 )
BUG=b:158874061
Signed-off-by: Aaron Durbin adurbin@chromium.org Change-Id: Ief1901743e2c99f583ef0181490d493d23734f64 Reviewed-on: https://review.coreboot.org/c/coreboot/+/42734 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Furquan Shaikh furquan@google.com Reviewed-by: Felix Held felix-coreboot@felixheld.de --- M src/soc/amd/picasso/acpi/sb_pci0_fch.asl 1 file changed, 5 insertions(+), 0 deletions(-)
Approvals: build bot (Jenkins): Verified Felix Held: Looks good to me, approved Furquan Shaikh: Looks good to me, approved
