Felix Held has submitted this change. ( https://review.coreboot.org/c/coreboot/+/61663 )
Change subject: mb/google/var/banshee: Add gpios to lock ......................................................................
Variant should honor locked gpios from baseboard, but not the last. Variant can add more gpios to lock if needed.
BUG=b:216583542 TEST='emerge-brya coreboot chromeos-bootimage'
Signed-off-by: Eric Lai ericr_lai@compal.corp-partner.google.com Change-Id: Id5a2136e57e842fbd0b2c2836833106e7344afee Reviewed-on: https://review.coreboot.org/c/coreboot/+/61663 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Nick Vaccaro nvaccaro@google.com Reviewed-by: Ivy Jian ivy_jian@compal.corp-partner.google.com Reviewed-by: Subrata Banik subratabanik@google.com --- M src/mainboard/google/brya/variants/banshee/gpio.c 1 file changed, 29 insertions(+), 29 deletions(-)
Approvals: build bot (Jenkins): Verified Nick Vaccaro: Looks good to me, approved Ivy Jian: Looks good to me, but someone else must approve Subrata Banik: Looks good to me, approved
diff --git a/src/mainboard/google/brya/variants/banshee/gpio.c b/src/mainboard/google/brya/variants/banshee/gpio.c index 8ea51d8..9bf6518 100644 --- a/src/mainboard/google/brya/variants/banshee/gpio.c +++ b/src/mainboard/google/brya/variants/banshee/gpio.c @@ -45,12 +45,12 @@ /* B1 : SOC_VID1 */ /* B2 : VRALERT# ==> M2_SSD_PLA_L */ /* B3 : PROC_GP2 ==> NC */ - PAD_NC(GPP_B3, NONE), + PAD_NC_LOCK(GPP_B3, NONE, LOCK_CONFIG), /* B4 : PROC_GP3 ==> SSD_PERST_L */ /* B5 : ISH_I2C0_SDA ==> NC */ - PAD_NC(GPP_B5, NONE), + PAD_NC_LOCK(GPP_B5, NONE, LOCK_CONFIG), /* B6 : ISH_I2C0_SCL ==> NC */ - PAD_NC(GPP_B6, NONE), + PAD_NC_LOCK(GPP_B6, NONE, LOCK_CONFIG), /* B9 : NC */ /* B10 : NC */ /* B11 : PMCALERT# ==> EN_PP3300_WLAN */ @@ -58,7 +58,7 @@ /* B13 : PLTRST# ==> PLT_RST_L */ /* B14 : SPKR ==> GPP_B14_STRAP */ /* B15 : TIME_SYNC0 ==> NC */ - PAD_NC(GPP_B15, NONE), + PAD_NC_LOCK(GPP_B15, NONE, LOCK_CONFIG), /* B16 : I2C5_SDA ==> PCH_I2C_TCHPAD_SDA */ /* B17 : I2C5_SCL ==> PCH_I2C_TCHPAD_SCL */ /* B18 : ADR_COMPLETE ==> GPP_B18_STRAP */ @@ -82,13 +82,13 @@ /* C7 : SML1DATA ==> USI_INT */
/* D0 : ISH_GP0 ==> NC */ - PAD_NC(GPP_D0, NONE), + PAD_NC_LOCK(GPP_D0, NONE, LOCK_CONFIG), /* D1 : ISH_GP1 ==> NC */ - PAD_NC(GPP_D1, NONE), + PAD_NC_LOCK(GPP_D1, NONE, LOCK_CONFIG), /* D2 : ISH_GP2 ==> NC */ - PAD_NC(GPP_D2, NONE), + PAD_NC_LOCK(GPP_D2, NONE, LOCK_CONFIG), /* D3 : ISH_GP3 ==> NC */ - PAD_NC(GPP_D3, NONE), + PAD_NC_LOCK(GPP_D3, NONE, LOCK_CONFIG), /* D4 : IMGCLKOUT0 ==> BT_DISABLE_L */ /* D5 : SRCCLKREQ0# ==> SSD_CLKREQ_ODL */ PAD_CFG_NF(GPP_D5, NONE, DEEP, NF1), @@ -100,28 +100,28 @@ /* D9 : ISH_SPI_CS# ==> USB_C2_LSX_TX */ /* D10 : ISH_SPI_CLK ==> USB_C2_LSX_RX_STRAP */ /* D11 : ISH_SPI_MISO ==> USB_C3_LSX_TX */ - PAD_CFG_NF(GPP_D11, NONE, DEEP, NF4), + PAD_CFG_NF_LOCK(GPP_D11, NONE, NF4, LOCK_CONFIG), /* D12 : ISH_SPI_MOSI ==> GPP_D12_STRAP */ /* D13 : ISH_UART0_RXD ==> NC */ - PAD_NC(GPP_D13, NONE), + PAD_NC_LOCK(GPP_D13, NONE, LOCK_CONFIG), /* D14 : ISH_UART0_TXD ==> NC */ - PAD_NC(GPP_D14, NONE), + PAD_NC_LOCK(GPP_D14, NONE, LOCK_CONFIG), /* D15 : ISH_UART0_RTS# ==> NC */ - PAD_NC(GPP_D15, NONE), + PAD_NC_LOCK(GPP_D15, NONE, LOCK_CONFIG), /* D16 : ISH_UART0_CTS# ==> NC */ - PAD_NC(GPP_D16, NONE), + PAD_NC_LOCK(GPP_D16, NONE, LOCK_CONFIG), /* D17 : UART1_RXD ==> NC */ - PAD_NC(GPP_D17, NONE), + PAD_NC_LOCK(GPP_D17, NONE, LOCK_CONFIG), /* D18 : UART1_TXD ==> USI_RST_L */ - PAD_CFG_GPO(GPP_D18, 0, DEEP), + PAD_CFG_GPO_LOCK(GPP_D18, 0, LOCK_CONFIG), /* D19 : I2S_MCLK1_OUT ==> I2S_MCLK_R */
/* E0 : SATAXPCIE0 ==> NC */ PAD_NC(GPP_E0, NONE), /* E1 : THC0_SPI1_IO2 ==> NC */ - PAD_NC(GPP_E1, NONE), + PAD_NC_LOCK(GPP_E1, NONE, LOCK_CONFIG), /* E2 : THC0_SPI1_IO3 ==> NC */ - PAD_NC(GPP_E2, NONE), + PAD_NC_LOCK(GPP_E2, NONE, LOCK_CONFIG), /* E3 : PROC_GP0 ==> NC */ PAD_NC(GPP_E3, NONE), /* E4 : SATA_DEVSLP0 ==> USB4_BB_RT_FORCE_PWR */ @@ -133,19 +133,19 @@ /* E8 : SLP_DRAM# ==> WIFI_DISABLE_L */ /* E9 : USB_OC0# ==> USB_C0_OC_ODL */ /* E10 : THC0_SPI1_CS# ==> NC */ - PAD_NC(GPP_E10, NONE), + PAD_NC_LOCK(GPP_E10, NONE, LOCK_CONFIG), /* E11 : THC0_SPI1_CLK ==> NC */ - PAD_NC(GPP_E11, NONE), + PAD_NC_LOCK(GPP_E11, NONE, LOCK_CONFIG), /* E12 : THC0_SPI1_IO1 ==> NC */ - PAD_NC(GPP_E12, NONE), + PAD_NC_LOCK(GPP_E12, NONE, LOCK_CONFIG), /* E13 : THC0_SPI1_IO2 ==> NC */ - PAD_NC(GPP_E13, NONE), + PAD_NC_LOCK(GPP_E13, NONE, LOCK_CONFIG), /* E14 : DDSP_HPDA ==> SOC_EDP_HPD */ /* E15 : RSVD_TP ==> PCH_WP_OD */ /* E16 : RSVD_TP ==> NC */ PAD_NC(GPP_E16, NONE), /* E17 : THC0_SPI1_INT# ==> NC */ - PAD_NC(GPP_E17, NONE), + PAD_NC_LOCK(GPP_E17, NONE, LOCK_CONFIG), /* E18 : DDP1_CTRLCLK ==> USB_C0_LSX_SOC_TX */ /* E19 : DDP1_CTRLDATA ==> USB0_C0_LSX_SOC_RX_STRAP */ /* E20 : DDP2_CTRLCLK ==> USB_C1_LSX_SOC_TX */ @@ -168,16 +168,16 @@ /* F9 : BOOTMPC ==> SLP_S0_GATE_R */ /* F10 : GPPF10_STRAP */ /* F11 : THC1_SPI2_CLK ==> NC */ - PAD_NC(GPP_F11, NONE), + PAD_NC_LOCK(GPP_F11, NONE, LOCK_CONFIG), /* F12 : GSXDOUT ==> NC */ - PAD_NC(GPP_F12, NONE), + PAD_NC_LOCK(GPP_F12, NONE, LOCK_CONFIG), /* F13 : GSXDOUT ==> NC */ - PAD_NC(GPP_F13, NONE), + PAD_NC_LOCK(GPP_F13, NONE, LOCK_CONFIG), /* F14 : GSXDIN ==> TCHPAD_INT_ODL */ /* F15 : GSXSRESET# ==> NC */ - PAD_NC(GPP_F15, NONE), + PAD_NC_LOCK(GPP_F15, NONE, LOCK_CONFIG), /* F16 : GSXCLK ==> NC */ - PAD_NC(GPP_F16, NONE), + PAD_NC_LOCK(GPP_F16, NONE, LOCK_CONFIG), /* F17 : THC1_SPI2_RST# ==> EC_PCH_INT_ODL */ /* F18 : THC1_SPI2_INT# ==> EC_IN_RW_OD */ /* F19 : SRCCLKREQ6# ==> NC */ @@ -205,9 +205,9 @@ PAD_NC(GPP_H9, NONE), /* H10 : UART0_RXD ==> UART_PCH_RX_DBG_TX */ /* H12 : I2C7_SDA ==> NC */ - PAD_NC(GPP_H12, NONE), + PAD_NC_LOCK(GPP_H12, NONE, LOCK_CONFIG), /* H13 : I2C7_SCL ==> EN_PP3300_TCHSCR */ - PAD_CFG_GPO(GPP_H13, 1, DEEP), + PAD_CFG_GPO_LOCK(GPP_H13, 1, LOCK_CONFIG), /* H14 : NC */ /* H15 : DDPB_CTRLCLK ==> NC */ PAD_NC(GPP_H15, NONE),
