Edward O'Callaghan (eocallaghan@alterapraxis.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/6041
commit d2d0695db51ad879c9213f24341eec5df27418a7 Author: Edward O'Callaghan eocallaghan@alterapraxis.com Date: Mon Jun 16 14:13:06 2014 +1000
src/superio/ite/it8772f: Separate mainboard from SIO at obj level
Remove #include early_serial.c and rename to early_init.c as no actual UART configuration is done here. Note that this SIO component still hard codes its base address to 0x2e.
Change-Id: Icc817e6f31007f90ff326a36e9c3cc824cae4fa4 Signed-off-by: Edward O'Callaghan eocallaghan@alterapraxis.com --- src/mainboard/samsung/stumpy/romstage.c | 17 +++--- src/mainboard/samsung/stumpy/smihandler.c | 18 +++---- src/superio/ite/it8772f/Makefile.inc | 1 + src/superio/ite/it8772f/early_init.c | 87 ++++++++++++++++++++++++++++++ src/superio/ite/it8772f/early_serial.c | 88 ------------------------------- src/superio/ite/it8772f/it8772f.h | 21 ++++++-- 6 files changed, 121 insertions(+), 111 deletions(-)
diff --git a/src/mainboard/samsung/stumpy/romstage.c b/src/mainboard/samsung/stumpy/romstage.c index 6ab7007..153ce5c 100644 --- a/src/mainboard/samsung/stumpy/romstage.c +++ b/src/mainboard/samsung/stumpy/romstage.c @@ -34,8 +34,6 @@ #include <bootmode.h> #include <superio/ite/common/ite.h> #include <superio/ite/it8772f/it8772f.h> -/* FIXME: SUPERIO include.c */ -#include "superio/ite/it8772f/early_serial.c" #include "northbridge/intel/sandybridge/sandybridge.h" #include "northbridge/intel/sandybridge/raminit.h" #include "southbridge/intel/bd82x6x/pch.h" @@ -61,6 +59,7 @@ #endif #define USB_RESET_DISABLE_MAGIC (0xdd) /* Disable if set to this */
+#define DUMMY_DEV PNP_DEV(0x2e, 0) #define SERIAL_DEV PNP_DEV(0x2e, IT8772F_SP1) #define GPIO_DEV PNP_DEV(0x2e, IT8772F_GPIO)
@@ -148,29 +147,29 @@ static void setup_sio_gpios(void) * GPIO10 as USBPWRON12# * GPIO12 as USBPWRON13# */ - it8772f_gpio_setup(1, 0x05, 0x05, 0x00, 0x05, 0x05); + it8772f_gpio_setup(DUMMY_DEV, 1, 0x05, 0x05, 0x00, 0x05, 0x05);
/* * GPIO22 as wake SCI# */ - it8772f_gpio_setup(2, 0x04, 0x04, 0x00, 0x04, 0x04); + it8772f_gpio_setup(DUMMY_DEV, 2, 0x04, 0x04, 0x00, 0x04, 0x04);
/* * GPIO32 as EXTSMI# */ - it8772f_gpio_setup(3, 0x04, 0x04, 0x00, 0x04, 0x04); + it8772f_gpio_setup(DUMMY_DEV, 3, 0x04, 0x04, 0x00, 0x04, 0x04);
/* * GPIO45 as LED_POWER# */ - it8772f_gpio_setup(4, 0x20, 0x20, 0x20, 0x20, 0x20); + it8772f_gpio_setup(DUMMY_DEV, 4, 0x20, 0x20, 0x20, 0x20, 0x20);
/* * GPIO51 as USBPWRON8# * GPIO52 as USBPWRON1# */ - it8772f_gpio_setup(5, 0x06, 0x06, 0x00, 0x06, 0x06); - it8772f_gpio_setup(6, 0x00, 0x00, 0x00, 0x00, 0x00); + it8772f_gpio_setup(DUMMY_DEV, 5, 0x06, 0x06, 0x00, 0x06, 0x06); + it8772f_gpio_setup(DUMMY_DEV, 6, 0x00, 0x00, 0x00, 0x00, 0x00); }
void main(unsigned long bist) @@ -239,7 +238,7 @@ void main(unsigned long bist) setup_sio_gpios();
/* Early SuperIO setup */ - it8772f_ac_resume_southbridge(); + it8772f_ac_resume_southbridge(DUMMY_DEV); ite_kill_watchdog(GPIO_DEV); ite_enable_serial(SERIAL_DEV, CONFIG_TTYS0_BASE); console_init(); diff --git a/src/mainboard/samsung/stumpy/smihandler.c b/src/mainboard/samsung/stumpy/smihandler.c index 5c3e1b3..b7a4ce3 100644 --- a/src/mainboard/samsung/stumpy/smihandler.c +++ b/src/mainboard/samsung/stumpy/smihandler.c @@ -23,11 +23,11 @@ #include <southbridge/intel/bd82x6x/nvs.h> #include <southbridge/intel/bd82x6x/pch.h> #include <southbridge/intel/bd82x6x/me.h> +#include <superio/ite/it8772f/it8772f.h> #include <northbridge/intel/sandybridge/sandybridge.h> #include <cpu/intel/model_206ax/model_206ax.h>
-/* Include romstage serial for SIO helper functions */ -#include <superio/ite/it8772f/early_serial.c> +#define DUMMY_DEV PNP_DEV(0x2e, 0)
int mainboard_io_trap_handler(int smif) { @@ -64,18 +64,18 @@ void mainboard_smi_sleep(u8 slp_typ) case 3: case 4: /* Blink LED */ - it8772f_enter_conf(); - it8772f_sio_write(IT8772F_CONFIG_REG_LDN, IT8772F_GPIO); + it8772f_enter_conf(DUMMY_DEV); + it8772f_sio_write(DUMMY_DEV, IT8772F_CONFIG_REG_LDN, IT8772F_GPIO); /* Enable blink pin map */ - it8772f_sio_write(IT8772F_GPIO_LED_BLINK1_PINMAP, + it8772f_sio_write(DUMMY_DEV, IT8772F_GPIO_LED_BLINK1_PINMAP, SIO_GPIO_BLINK_GPIO45); /* Enable 4HZ blink */ - it8772f_sio_write(IT8772F_GPIO_LED_BLINK1_CONTROL, 0x02); + it8772f_sio_write(DUMMY_DEV, IT8772F_GPIO_LED_BLINK1_CONTROL, 0x02); /* Set GPIO to alternate function */ - reg8 = it8772f_sio_read(GPIO_REG_ENABLE(3)); + reg8 = it8772f_sio_read(DUMMY_DEV, GPIO_REG_ENABLE(3)); reg8 &= ~(1 << 5); - it8772f_sio_write(GPIO_REG_ENABLE(3), reg8); - it8772f_exit_conf(); + it8772f_sio_write(DUMMY_DEV, GPIO_REG_ENABLE(3), reg8); + it8772f_exit_conf(DUMMY_DEV); break;
case 5: diff --git a/src/superio/ite/it8772f/Makefile.inc b/src/superio/ite/it8772f/Makefile.inc index 7b6be2c..438ba84 100644 --- a/src/superio/ite/it8772f/Makefile.inc +++ b/src/superio/ite/it8772f/Makefile.inc @@ -18,4 +18,5 @@ ## Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA ##
+romstage-$(CONFIG_SUPERIO_ITE_IT8772F) += early_init.c ramstage-$(CONFIG_SUPERIO_ITE_IT8772F) += superio.c diff --git a/src/superio/ite/it8772f/early_init.c b/src/superio/ite/it8772f/early_init.c new file mode 100644 index 0000000..1ae80c8 --- /dev/null +++ b/src/superio/ite/it8772f/early_init.c @@ -0,0 +1,87 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2011 The ChromiumOS Authors. All rights reserved. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + */ + +#include <arch/io.h> +#include <device/pnp_def.h> + +#include "it8772f.h" + +/* NOTICE: This file is deprecated, use ite/common instead */ + +/* RAMstage equiv */ +/* u8 pnp_read_config(device_t dev, u8 reg) */ +u8 it8772f_sio_read(device_t dev, u8 reg) +{ + u16 port = dev >> 8; + + outb(reg, port); + return inb(port + 1); +} + +/* RAMstage equiv */ +/* void pnp_write_config(device_t dev, u8 reg, u8 value) */ +void it8772f_sio_write(device_t dev, u8 reg, u8 value) +{ + u16 port = dev >> 8; + + outb(reg, port); + outb(value, port + 1); +} + +void it8772f_enter_conf(device_t dev) +{ + u16 port = dev >> 8; + + outb(0x87, port); + outb(0x01, port); + outb(0x55, port); + outb((port == 0x4e) ? 0xaa : 0x55, port); +} + +void it8772f_exit_conf(device_t dev) +{ + it8772f_sio_write(dev, IT8772F_CONFIG_REG_CC, 0x02); +} + +/* Set AC resume to be up to the Southbridge */ +void it8772f_ac_resume_southbridge(device_t dev) +{ + it8772f_enter_conf(dev); + it8772f_sio_write(dev, IT8772F_CONFIG_REG_LDN, IT8772F_EC); + it8772f_sio_write(dev, 0xf4, 0x60); + it8772f_exit_conf(dev); +} + +/* Configure a set of GPIOs */ +void it8772f_gpio_setup(device_t dev, int set, u8 select, u8 polarity, + u8 pullup, u8 output, u8 enable) +{ + set--; /* Set 1 is offset 0 */ + it8772f_enter_conf(dev); + it8772f_sio_write(dev, IT8772F_CONFIG_REG_LDN, IT8772F_GPIO); + if (set < 5) { + it8772f_sio_write(dev, GPIO_REG_SELECT(set), select); + it8772f_sio_write(dev, GPIO_REG_ENABLE(set), enable); + it8772f_sio_write(dev, GPIO_REG_POLARITY(set), polarity); + } + it8772f_sio_write(dev, GPIO_REG_OUTPUT(set), output); + it8772f_sio_write(dev, GPIO_REG_PULLUP(set), pullup); + it8772f_exit_conf(dev); +} diff --git a/src/superio/ite/it8772f/early_serial.c b/src/superio/ite/it8772f/early_serial.c deleted file mode 100644 index ee9dbc5..0000000 --- a/src/superio/ite/it8772f/early_serial.c +++ /dev/null @@ -1,88 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * Copyright (C) 2011 The ChromiumOS Authors. All rights reserved. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; either version 2 of the License, or - * (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA - */ - -#include <arch/io.h> -#include <device/pnp_def.h> -#include "it8772f.h" - -/* NOTICE: This file is deprecated, use ite/common instead */ - -/* The base address is 0x2e or 0x4e, depending on config bytes. */ -/* FIXME: SUPERIO include.c */ -#define SIO_BASE 0x2e -#define SIO_INDEX SIO_BASE -#define SIO_DATA (SIO_BASE + 1) - -/* Global configuration registers. */ -#define IT8772F_CONFIG_REG_CC 0x02 /* Configure Control (write-only). */ -#define IT8772F_CONFIG_REG_LDN 0x07 /* Logical Device Number. */ - -u8 it8772f_sio_read(u8 index) -{ - outb(index, SIO_BASE); - return inb(SIO_DATA); -} - -void it8772f_sio_write(u8 index, u8 value) -{ - outb(index, SIO_BASE); - outb(value, SIO_DATA); -} - -static void it8772f_enter_conf(void) -{ - u16 port = SIO_BASE; - - outb(0x87, port); - outb(0x01, port); - outb(0x55, port); - outb((port == 0x4e) ? 0xaa : 0x55, port); -} - -static void it8772f_exit_conf(void) -{ - it8772f_sio_write(IT8772F_CONFIG_REG_CC, 0x02); -} - -/* Set AC resume to be up to the Southbridge */ -void it8772f_ac_resume_southbridge(void) -{ - it8772f_enter_conf(); - it8772f_sio_write(IT8772F_CONFIG_REG_LDN, IT8772F_EC); - it8772f_sio_write(0xf4, 0x60); - it8772f_exit_conf(); -} - -/* Configure a set of GPIOs */ -void it8772f_gpio_setup(int set, u8 select, u8 polarity, u8 pullup, - u8 output, u8 enable) -{ - set--; /* Set 1 is offset 0 */ - it8772f_enter_conf(); - it8772f_sio_write(IT8772F_CONFIG_REG_LDN, IT8772F_GPIO); - if (set < 5) { - it8772f_sio_write(GPIO_REG_SELECT(set), select); - it8772f_sio_write(GPIO_REG_ENABLE(set), enable); - it8772f_sio_write(GPIO_REG_POLARITY(set), polarity); - } - it8772f_sio_write(GPIO_REG_OUTPUT(set), output); - it8772f_sio_write(GPIO_REG_PULLUP(set), pullup); - it8772f_exit_conf(); -} diff --git a/src/superio/ite/it8772f/it8772f.h b/src/superio/ite/it8772f/it8772f.h index 221a932..09eeb8f 100644 --- a/src/superio/ite/it8772f/it8772f.h +++ b/src/superio/ite/it8772f/it8772f.h @@ -103,10 +103,21 @@ #define GPIO_REG_ENABLE(x) (0xc0 + (x)) #define GPIO_REG_OUTPUT(x) (0xc8 + (x))
-u8 it8772f_sio_read(u8 index); -void it8772f_sio_write(u8 index, u8 value); -void it8772f_ac_resume_southbridge(void); -void it8772f_gpio_setup(int set, u8 func_select, u8 polarity, u8 pullup, - u8 output, u8 enable); +#include <arch/io.h> +#include <stdint.h> + +u8 it8772f_sio_read(device_t dev, u8 reg); +void it8772f_sio_write(device_t dev, u8 reg, u8 value); +void it8772f_ac_resume_southbridge(device_t dev); +void it8772f_gpio_setup(device_t dev, int set, u8 select, u8 polarity, + u8 pullup, u8 output, u8 enable); + +/* FIXME: should be static so will be removed later.. */ +/* Global configuration registers. */ +#define IT8772F_CONFIG_REG_CC 0x02 /* Configure Control (write-only). */ +#define IT8772F_CONFIG_REG_LDN 0x07 /* Logical Device Number. */ + +void it8772f_enter_conf(device_t dev); +void it8772f_exit_conf(device_t dev);
#endif /* SUPERIO_ITE_IT8772F_H */
