Subrata Banik has submitted this change. ( https://review.coreboot.org/c/coreboot/+/62907 )
Change subject: Revert "Revert "drivers/intel/fsp2_0: Allow `mp_startup_all_cpus()` to run serially"" ......................................................................
This reverts a change that was causing hangs and exceptions during boot on an ADL brya4es.
The hang (or APIC exception) occurs at what appears to be the FSP MP initialization sequence, prior to the "Display FSP Version Info HOB" log being displayed :
[DEBUG] Detected 10 core, 12 thread CPU. [DEBUG] Display FSP Version Info HOB
This reverts commit 40ca79714ad7d5f2aa201d83db4d97f21260d924.
BUG=b:224873032 TEST=`emerge-brya coreboot chromeos-bootimage`, flash and verify brya4es is able to successfully reboot 200 times without any issues.
Change-Id: I88c15a51c5d27fbd243478c923e75962d3f8d67d Signed-off-by: Nick Vaccaro nvaccaro@google.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/62907 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Subrata Banik subratabanik@google.com Reviewed-by: Ronak Kanabar ronak.kanabar@intel.com Reviewed-by: Tim Wawrzynczak twawrzynczak@chromium.org --- M src/drivers/intel/fsp2_0/ppi/mp_service_ppi.c 1 file changed, 17 insertions(+), 4 deletions(-)
Approvals: build bot (Jenkins): Verified Ronak Kanabar: Looks good to me, approved Tim Wawrzynczak: Looks good to me, approved Subrata Banik: Looks good to me, approved
diff --git a/src/drivers/intel/fsp2_0/ppi/mp_service_ppi.c b/src/drivers/intel/fsp2_0/ppi/mp_service_ppi.c index 50e35b0..9aef1b6 100644 --- a/src/drivers/intel/fsp2_0/ppi/mp_service_ppi.c +++ b/src/drivers/intel/fsp2_0/ppi/mp_service_ppi.c @@ -94,10 +94,23 @@ /* Run on BSP */ procedure(argument);
- /* Run on APs */ - if (mp_run_on_aps((void *)procedure, argument, - MP_RUN_ON_ALL_CPUS, timeout_usec) != CB_SUCCESS) { - printk(BIOS_ERR, "%s: Exit with Failure\n", __func__); + /* + * Run on APs Serially + * + * FIXME: As per MP service specification, EDK2 is allowed to specify the mode + * in which a 'func' routine should be executed on APs (i.e. execute serially + * or concurrently). + * + * MP service API `StartupAllCPUs` doesn't specify such requirement. + * Hence, running the `CpuCacheInfoCollectCoreAndCacheData` + * (UefiCpuPkg/Library/CpuCacheInfoLib/CpuCacheInfoLib.c#194) + * simultaneously on APs results in a coherency issue (hang while executing `func`) + * due to lack of acquiring a spin lock while accessing common data structure in + * multiprocessor environment. + */ + if (mp_run_on_all_aps((void *)procedure, argument, timeout_usec, false) != + CB_SUCCESS) { + printk(BIOS_DEBUG, "%s: Exit with Failure\n", __func__); return FSP_NOT_STARTED; }
