Keith Hui has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/82756?usp=email )
Change subject: mb/asus/p8z77-m: Update USB current map to match vendor ......................................................................
This board has used the USB current map from asus/p8z77-m_pro since it first landed in coreboot, which actually doesn't match vendor firmware. Apply values obtained from hardware while running vendor firmware to both native and MRC config.
Change-Id: I7ce13493c3ecac8154460c1fedf05e2d70a8e394 Signed-off-by: Keith Hui buurin@gmail.com --- M src/mainboard/asus/p8x7x-series/variants/p8z77-m/early_init.c M src/mainboard/asus/p8x7x-series/variants/p8z77-m/overridetree.cb 2 files changed, 23 insertions(+), 7 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/56/82756/1
diff --git a/src/mainboard/asus/p8x7x-series/variants/p8z77-m/early_init.c b/src/mainboard/asus/p8x7x-series/variants/p8z77-m/early_init.c index 47c5cb3..4656617 100644 --- a/src/mainboard/asus/p8x7x-series/variants/p8z77-m/early_init.c +++ b/src/mainboard/asus/p8x7x-series/variants/p8z77-m/early_init.c @@ -14,16 +14,16 @@
const struct southbridge_usb_port mainboard_usb_ports[] = { /* {enable, current, oc_pin} */ - {1, 2, 0}, /* Port 0: USB3 front internal header, top */ - {1, 2, 0}, /* Port 1: USB3 front internal header, bottom */ + {1, 8, 0}, /* Port 0: USB3 front internal header, top */ + {1, 8, 0}, /* Port 1: USB3 front internal header, bottom */ {1, 2, 1}, /* Port 2: USB3 rear, top */ {1, 2, 1}, /* Port 3: USB3 rear, bottom */ {1, 2, 2}, /* Port 4: USB2 rear, PS2 top */ {1, 2, 2}, /* Port 5: USB2 rear, PS2 bottom */ {1, 2, 3}, /* Port 6: USB2 rear, ETH, top */ {1, 2, 3}, /* Port 7: USB2 rear, ETH, bottom */ - {1, 2, 4}, /* Port 8: USB2 internal header USB910, top */ - {1, 2, 4}, /* Port 9: USB2 internal header USB910, bottom */ + {1, 9, 4}, /* Port 8: USB2 internal header USB910, top */ + {1, 9, 4}, /* Port 9: USB2 internal header USB910, bottom */ {1, 2, 6}, /* Port 10: USB2 internal header USB1112, top */ {1, 2, 5}, /* Port 11: USB2 internal header USB1112, bottom */ {1, 2, 5}, /* Port 12: USB2 internal header USB1314, top */ diff --git a/src/mainboard/asus/p8x7x-series/variants/p8z77-m/overridetree.cb b/src/mainboard/asus/p8x7x-series/variants/p8z77-m/overridetree.cb index b3d05fe..45ad0e1 100644 --- a/src/mainboard/asus/p8x7x-series/variants/p8z77-m/overridetree.cb +++ b/src/mainboard/asus/p8x7x-series/variants/p8z77-m/overridetree.cb @@ -2,14 +2,30 @@
chip northbridge/intel/sandybridge register "usb_port_config" = "{ - {1, 0, 0x0080}, {1, 0, 0x0080}, {1, 1, 0x0080}, {1, 1, 0x0080}, {1, 2, 0x0080}, - {1, 2, 0x0080}, {1, 3, 0x0080}, {1, 3, 0x0080}, {1, 4, 0x0080}, {1, 4, 0x0080}, - {1, 6, 0x0080}, {1, 5, 0x0080}, {1, 5, 0x0080}, {1, 6, 0x0080} + {1, 0, 0x0040}, {1, 0, 0x0040}, {1, 1, 0x0130}, {1, 1, 0x0130}, {1, 2, 0x0130}, + {1, 2, 0x0130}, {1, 3, 0x0130}, {1, 3, 0x0130}, {1, 4, 0x0080}, {1, 4, 0x0080}, + {1, 6, 0x0130}, {1, 5, 0x0130}, {1, 5, 0x0130}, {1, 6, 0x0130} }" device domain 0 on subsystemid 0x1043 0x84ca inherit chip southbridge/intel/bd82x6x # Intel Series 7 Panther Point PCH register "gen1_dec" = "0x000c0291" + register "usb_port_config" = "{ + {1, 8, 0}, /* Port 0: USB3 front internal header, top */ + {1, 8, 0}, /* Port 1: USB3 front internal header, bottom */ + {1, 2, 1}, /* Port 2: USB3 rear, top */ + {1, 2, 1}, /* Port 3: USB3 rear, bottom */ + {1, 2, 2}, /* Port 4: USB2 rear PS2, top */ + {1, 2, 2}, /* Port 5: USB2 rear PS2, bottom */ + {1, 2, 3}, /* Port 6: USB2 rear LAN, top */ + {1, 2, 3}, /* Port 7: USB2 rear LAN, bottom */ + {1, 9, 4}, /* Port 8: USB2 internal header USB910, top */ + {1, 9, 4}, /* Port 9: USB2 internal header USB910, bottom */ + {1, 2, 6}, /* Port 10: USB2 internal header USB1112, top */ + {1, 2, 5}, /* Port 11: USB2 internal header USB1112, bottom */ + {1, 2, 5}, /* Port 12: USB2 internal header USB1314, top */ + {1, 2, 6} /* Port 13: USB2 internal header USB1314, bottom */ + }"
device ref pcie_rp1 on end # PCIe x4 slot device ref pcie_rp2 off end
