Stefan Reinauer (stefan.reinauer@coreboot.org) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/9504
commit 7993184a19bfb547f059cc1f50fec87496bb4519 Author: Lee Leahy leroy.p.leahy@intel.com Date: Mon Feb 9 21:09:49 2015 -0800
x86: Support reset routines in bootblock
Expand the boot block include file to allow for a file containing reset routines to be added. Prevent breaking existing platforms by using a Kconfig value to specify the path to this file, and have the code include this file only if the Kconfig value is set.
BRANCH=none BUG=None TEST=Build and run on Glados
Change-Id: I604f701057d7018f2ed9c3ba49a643c4bca13f00 Signed-off-by: Stefan Reinauer reinauer@chromium.org Original-Commit-Id: c109481d9503916e19ed300c1a3f085e0d2b5c51 Original-Change-Id: I3214399f8156b5ea2ef709ce77e3915cea1523a3 Original-Signed-off-by: Lee Leahy Leroy.P.Leahy@intel.com Original-Reviewed-on: https://chromium-review.googlesource.com/248300 Original-Reviewed-by: Aaron Durbin adurbin@chromium.org Original-Commit-Queue: Leroy P Leahy leroy.p.leahy@intel.com Original-Tested-by: Leroy P Leahy leroy.p.leahy@intel.com --- src/arch/x86/Kconfig | 3 +++ src/arch/x86/include/bootblock_common.h | 4 ++++ 2 files changed, 7 insertions(+)
diff --git a/src/arch/x86/Kconfig b/src/arch/x86/Kconfig index f7da89a..29f0514 100644 --- a/src/arch/x86/Kconfig +++ b/src/arch/x86/Kconfig @@ -84,6 +84,9 @@ config BOOTBLOCK_MAINBOARD_INIT config BOOTBLOCK_NORTHBRIDGE_INIT string
+config BOOTBLOCK_RESETS + string + config HAVE_CMOS_DEFAULT def_bool n
diff --git a/src/arch/x86/include/bootblock_common.h b/src/arch/x86/include/bootblock_common.h index b4100b7..939ba08 100644 --- a/src/arch/x86/include/bootblock_common.h +++ b/src/arch/x86/include/bootblock_common.h @@ -2,6 +2,10 @@ #include <cpu/x86/lapic/boot_cpu.c> #include <pc80/mc146818rtc.h>
+#ifdef CONFIG_BOOTBLOCK_RESETS +#include CONFIG_BOOTBLOCK_RESETS +#endif + #ifdef CONFIG_BOOTBLOCK_CPU_INIT #include CONFIG_BOOTBLOCK_CPU_INIT #endif
