Martin Roth has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/43824 )
Change subject: src: Change BOOL CONFIG_ to CONFIG() in comments & strings ......................................................................
The Kconfig lint tool checks for cases of the code using BOOL type Kconfig options directly instead of with CONFIG() and will print out warnings about it. It gets confused by these references in comments and strings. To fix it so that it can find the real issues, just update these as we would with real issues.
Signed-off-by: Martin Roth martin@coreboot.org Change-Id: I5c37f0ee103721c97483d07a368c0b813e3f25c0 --- M src/cpu/intel/model_1067x/mp_init.c M src/device/dram/ddr2.c M src/device/dram/ddr3.c M src/drivers/intel/fsp2_0/include/fsp/debug.h M src/drivers/pc80/rtc/mc146818rtc.c M src/drivers/spi/tpm/tpm.c M src/ec/google/wilco/bootblock.h M src/ec/lenovo/h8/vboot.c M src/include/device/dram/common.h M src/include/device/dram/ddr3.h M src/include/mrc_cache.h M src/include/spi_flash.h M src/mainboard/emulation/qemu-q35/bootblock.c M src/mainboard/intel/harcuvar/romstage.c M src/northbridge/intel/gm45/bootblock.c M src/northbridge/intel/haswell/bootblock.c M src/northbridge/intel/i945/bootblock.c M src/northbridge/intel/sandybridge/bootblock.c M src/security/vboot/vboot_lib.c M src/soc/intel/broadwell/bootblock/systemagent.c M src/soc/intel/common/block/systemagent/systemagent.c M src/soc/intel/common/block/systemagent/systemagent_def.h 22 files changed, 32 insertions(+), 32 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/24/43824/1
diff --git a/src/cpu/intel/model_1067x/mp_init.c b/src/cpu/intel/model_1067x/mp_init.c index 3404e7f..b56d106 100644 --- a/src/cpu/intel/model_1067x/mp_init.c +++ b/src/cpu/intel/model_1067x/mp_init.c @@ -63,7 +63,7 @@ } else { if (!CONFIG(SET_IA32_FC_LOCK_BIT)) printk(BIOS_INFO, - "Overriding CONFIG_SET_IA32_FC_LOCK_BIT to enable SMRR\n"); + "Overriding CONFIG(SET_IA32_FC_LOCK_BIT) to enable SMRR\n"); ia32_ft_ctrl.lo |= (1 << 3) | (1 << 0); wrmsr(IA32_FEATURE_CONTROL, ia32_ft_ctrl); } diff --git a/src/device/dram/ddr2.c b/src/device/dram/ddr2.c index c6d6442..0eba0e3 100644 --- a/src/device/dram/ddr2.c +++ b/src/device/dram/ddr2.c @@ -653,7 +653,7 @@ /** * \brief Print the info in DIMM * -* Print info about the DIMM. Useful to use when CONFIG_DEBUG_RAM_SETUP is +* Print info about the DIMM. Useful to use when CONFIG(DEBUG_RAM_SETUP) is * selected, or for a purely informative output. * * @param dimm pointer to already decoded @ref dimm_attr structure diff --git a/src/device/dram/ddr3.c b/src/device/dram/ddr3.c index 3c433a9..461fb65 100644 --- a/src/device/dram/ddr3.c +++ b/src/device/dram/ddr3.c @@ -593,7 +593,7 @@ /** * \brief Print the info in DIMM * -* Print info about the DIMM. Useful to use when CONFIG_DEBUG_RAM_SETUP is +* Print info about the DIMM. Useful to use when CONFIG(DEBUG_RAM_SETUP) is * selected, or for a purely informative output. * * @param dimm pointer to already decoded @ref dimm_attr structure diff --git a/src/drivers/intel/fsp2_0/include/fsp/debug.h b/src/drivers/intel/fsp2_0/include/fsp/debug.h index ccb66cb..e3d1918 100644 --- a/src/drivers/intel/fsp2_0/include/fsp/debug.h +++ b/src/drivers/intel/fsp2_0/include/fsp/debug.h @@ -24,7 +24,7 @@ void fsp_print_header_info(const struct fsp_header *hdr);
/* Callbacks for displaying UPD parameters - place in a separate file - * that is conditionally build with CONFIG_DISPLAY_UPD_DATA. + * that is conditionally build with CONFIG(DISPLAY_UPD_DATA). */ void soc_display_fspm_upd_params(const FSPM_UPD *fspm_old_upd, const FSPM_UPD *fspm_new_upd); @@ -32,7 +32,7 @@ const FSPS_UPD *fsps_new_upd);
/* Callbacks for displaying HOBs - place in a separate file that is - * conditionally build with CONFIG_DISPLAY_HOBS. + * conditionally build with CONFIG(DISPLAY_HOBS). */ const char *soc_get_hob_type_name(const struct hob_header *hob); const char *soc_get_guid_name(const uint8_t *guid); diff --git a/src/drivers/pc80/rtc/mc146818rtc.c b/src/drivers/pc80/rtc/mc146818rtc.c index 3227510..d58a999 100644 --- a/src/drivers/pc80/rtc/mc146818rtc.c +++ b/src/drivers/pc80/rtc/mc146818rtc.c @@ -144,7 +144,7 @@ uint8_t vbnv[VBOOT_VBNV_BLOCK_SIZE];
/* __cmos_init() will clear vbnv contents when a known rtc failure - occurred with !CONFIG_USE_OPTION_TABLE. However, __cmos_init() may + occurred with !CONFIG(USE_OPTION_TABLE). However, __cmos_init() may clear vbnv data for other internal reasons. For that, always back up the vbnv contents and conditionally save them when __cmos_init() indicates CMOS was cleared. */ diff --git a/src/drivers/spi/tpm/tpm.c b/src/drivers/spi/tpm/tpm.c index 24851d1..7dd4397 100644 --- a/src/drivers/spi/tpm/tpm.c +++ b/src/drivers/spi/tpm/tpm.c @@ -41,7 +41,7 @@ static struct tpm2_info tpm_info;
/* - * TODO(vbendeb): make CONFIG_DEBUG_TPM an int to allow different level of + * TODO(vbendeb): make CONFIG(DEBUG_TPM) an int to allow different level of * debug traces. Right now it is either 0 or 1. */ static const int debug_level_ = CONFIG_DEBUG_TPM; diff --git a/src/ec/google/wilco/bootblock.h b/src/ec/google/wilco/bootblock.h index 2db8cfe..8a5b69c 100644 --- a/src/ec/google/wilco/bootblock.h +++ b/src/ec/google/wilco/bootblock.h @@ -9,7 +9,7 @@ * This function performs early initialization of the EC: * * - Enable EC UART passthru for COM1 if serial console support - * is enabled with CONFIG_DRIVERS_UART_8250IO. + * is enabled with CONFIG(DRIVERS_UART_8250IO). */ void wilco_ec_early_init(void);
diff --git a/src/ec/lenovo/h8/vboot.c b/src/ec/lenovo/h8/vboot.c index 97abb9d..b564153 100644 --- a/src/ec/lenovo/h8/vboot.c +++ b/src/ec/lenovo/h8/vboot.c @@ -33,7 +33,7 @@ }
/** - * Only used if CONFIG_CHROMEOS is set. + * Only used if CONFIG(CHROMEOS) is set. * Always zero as the #WP pin of the flash is tied high. */ int get_write_protect_state(void) diff --git a/src/include/device/dram/common.h b/src/include/device/dram/common.h index c1b4f76..9475853 100644 --- a/src/include/device/dram/common.h +++ b/src/include/device/dram/common.h @@ -33,10 +33,10 @@ /** @} */
/** - * \brief Convenience macro for enabling printk with CONFIG_DEBUG_RAM_SETUP + * \brief Convenience macro for enabling printk with CONFIG(DEBUG_RAM_SETUP) * * Use this macro instead of printk(); for verbose RAM initialization messages. - * When CONFIG_DEBUG_RAM_SETUP is not selected, these messages are automatically + * When CONFIG(DEBUG_RAM_SETUP) is not selected, these messages are automatically * disabled. * @{ */ diff --git a/src/include/device/dram/ddr3.h b/src/include/device/dram/ddr3.h index a209e48..74e0ff55 100644 --- a/src/include/device/dram/ddr3.h +++ b/src/include/device/dram/ddr3.h @@ -34,10 +34,10 @@ /** @} */
/** - * \brief Convenience macro for enabling printk with CONFIG_DEBUG_RAM_SETUP + * \brief Convenience macro for enabling printk with CONFIG(DEBUG_RAM_SETUP) * * Use this macro instead of printk(); for verbose RAM initialization messages. - * When CONFIG_DEBUG_RAM_SETUP is not selected, these messages are automatically + * When CONFIG(DEBUG_RAM_SETUP) is not selected, these messages are automatically * disabled. * @{ */ diff --git a/src/include/mrc_cache.h b/src/include/mrc_cache.h index 5131cbc..1cefba9 100644 --- a/src/include/mrc_cache.h +++ b/src/include/mrc_cache.h @@ -14,7 +14,7 @@
/* * It's up to the caller to decide when to retrieve and stash data. There is - * differentiation on recovery mode CONFIG_HAS_RECOVERY_MRC_CACHE, but that's + * differentiation on recovery mode CONFIG(HAS_RECOVERY_MRC_CACHE), but that's * only for locating where to retrieve and save the data. If a platform doesn't * want to update the data then it shouldn't stash the data for saving. * Similarly, if the platform doesn't need the data for booting because of a diff --git a/src/include/spi_flash.h b/src/include/spi_flash.h index 35b02db..1061e99 100644 --- a/src/include/spi_flash.h +++ b/src/include/spi_flash.h @@ -202,7 +202,7 @@ int chipset_volatile_group_end(const struct spi_flash *flash);
/* Return spi_flash object reference for the boot device. This is only valid - * if CONFIG_BOOT_DEVICE_SPI_FLASH is enabled. */ + * if CONFIG(BOOT_DEVICE_SPI_FLASH) is enabled. */ const struct spi_flash *boot_device_spi_flash(void);
/* Protect a region of spi flash using its controller, if available. Returns diff --git a/src/mainboard/emulation/qemu-q35/bootblock.c b/src/mainboard/emulation/qemu-q35/bootblock.c index fafa03b..efb3a4f 100644 --- a/src/mainboard/emulation/qemu-q35/bootblock.c +++ b/src/mainboard/emulation/qemu-q35/bootblock.c @@ -16,12 +16,12 @@
/* * The "io" variant of the config access is explicitly used to - * setup the PCIEXBAR because CONFIG_MMCONF_SUPPORT is set to + * setup the PCIEXBAR because CONFIG(MMCONF_SUPPORT) is set to * to true. That way all subsequent non-explicit config accesses use * MCFG. This code also assumes that bootblock_northbridge_init() is * the first thing called in the non-asm boot block code. The final * assumption is that no assembly code is using the - * CONFIG_MMCONF_SUPPORT option to do PCI config acceses. + * CONFIG(MMCONF_SUPPORT) option to do PCI config acceses. * * The PCIEXBAR is assumed to live in the memory mapped IO space under * 4GiB. diff --git a/src/mainboard/intel/harcuvar/romstage.c b/src/mainboard/intel/harcuvar/romstage.c index fbad798..0373c01 100644 --- a/src/mainboard/intel/harcuvar/romstage.c +++ b/src/mainboard/intel/harcuvar/romstage.c @@ -12,7 +12,7 @@ /* * Define platform specific Memory Down Configure structure. * - * If CONFIG_ENABLE_FSP_MEMORY_DOWN is enabled, the MEMORY_DOWN_CONFIG + * If CONFIG(ENABLE_FSP_MEMORY_DOWN) is enabled, the MEMORY_DOWN_CONFIG * structure should be customized to match the design. * * .SlotState indicates the memory down state of the specific channel/DIMM. diff --git a/src/northbridge/intel/gm45/bootblock.c b/src/northbridge/intel/gm45/bootblock.c index e74354e..a0e8fc0 100644 --- a/src/northbridge/intel/gm45/bootblock.c +++ b/src/northbridge/intel/gm45/bootblock.c @@ -11,12 +11,12 @@
/* * The "io" variant of the config access is explicitly used to - * setup the PCIEXBAR because CONFIG_MMCONF_SUPPORT is set to + * setup the PCIEXBAR because CONFIG(MMCONF_SUPPORT) is set to * to true. That way all subsequent non-explicit config accesses use * MCFG. This code also assumes that bootblock_northbridge_init() is * the first thing called in the non-asm boot block code. The final * assumption is that no assembly code is using the - * CONFIG_MMCONF_SUPPORT option to do PCI config accesses. + * CONFIG(MMCONF_SUPPORT) option to do PCI config accesses. * * The PCIEXBAR is assumed to live in the memory mapped IO space under * 4GiB. diff --git a/src/northbridge/intel/haswell/bootblock.c b/src/northbridge/intel/haswell/bootblock.c index 41f18be..59c31aa 100644 --- a/src/northbridge/intel/haswell/bootblock.c +++ b/src/northbridge/intel/haswell/bootblock.c @@ -10,11 +10,11 @@
/* * The "io" variant of the config access is explicitly used to setup the PCIEXBAR - * because CONFIG_MMCONF_SUPPORT is set to true. That way, all subsequent + * because CONFIG(MMCONF_SUPPORT) is set to true. That way, all subsequent * non-explicit config accesses use MCFG. This code also assumes that * bootblock_northbridge_init() is the first thing called in the non-asm * boot block code. The final assumption is that no assembly code is using - * the CONFIG_MMCONF_SUPPORT option to do PCI config acceses. + * the CONFIG(MMCONF_SUPPORT) option to do PCI config acceses. * * The PCIEXBAR is assumed to live in the memory mapped IO space under 4GiB. */ diff --git a/src/northbridge/intel/i945/bootblock.c b/src/northbridge/intel/i945/bootblock.c index 9d06120..60051ba 100644 --- a/src/northbridge/intel/i945/bootblock.c +++ b/src/northbridge/intel/i945/bootblock.c @@ -10,10 +10,10 @@
/* * The "io" variant of the config access is explicitly used to setup the PCIEXBAR - * because CONFIG_MMCONF_SUPPORT is set to true. That way all subsequent non-explicit + * because CONFIG(MMCONF_SUPPORT) is set to true. That way all subsequent non-explicit * config accesses use MCFG. This code also assumes that bootblock_northbridge_init() is * the first thing called in the non-asm boot block code. The final assumption is that - * no assembly code is using the CONFIG_MMCONF_SUPPORT option to do PCI config accesses. + * no assembly code is using the CONFIG(MMCONF_SUPPORT) option to do PCI config accesses. * * The PCIEXBAR is assumed to live in the memory mapped IO space under 4GiB. */ diff --git a/src/northbridge/intel/sandybridge/bootblock.c b/src/northbridge/intel/sandybridge/bootblock.c index 37ef025..dad61f9 100644 --- a/src/northbridge/intel/sandybridge/bootblock.c +++ b/src/northbridge/intel/sandybridge/bootblock.c @@ -10,11 +10,11 @@
/* * The "io" variant of the config access is explicitly used to setup the - * PCIEXBAR because CONFIG_MMCONF_SUPPORT is set to to true. That way, all + * PCIEXBAR because CONFIG(MMCONF_SUPPORT) is set to to true. That way, all * subsequent non-explicit config accesses use MCFG. This code also assumes * that bootblock_northbridge_init() is the first thing called in the non-asm * boot block code. The final assumption is that no assembly code is using the - * CONFIG_MMCONF_SUPPORT option to do PCI config accesses. + * CONFIG(MMCONF_SUPPORT) option to do PCI config accesses. * * The PCIEXBAR is assumed to live in the memory mapped IO space under 4GiB. */ diff --git a/src/security/vboot/vboot_lib.c b/src/security/vboot/vboot_lib.c index 3ff1523..06fd6d7 100644 --- a/src/security/vboot/vboot_lib.c +++ b/src/security/vboot/vboot_lib.c @@ -6,8 +6,8 @@
/* * vboot callbacks implemented by coreboot -- necessary for making general API - * calls when CONFIG_VBOOT_LIB is enabled. For callbacks specific to verstage - * (CONFIG_VBOOT), please see vboot_logic.c. + * calls when CONFIG(VBOOT_LIB) is enabled. For callbacks specific to verstage + * CONFIG(VBOOT), please see vboot_logic.c. */
void vb2ex_printf(const char *func, const char *fmt, ...) diff --git a/src/soc/intel/broadwell/bootblock/systemagent.c b/src/soc/intel/broadwell/bootblock/systemagent.c index ef55699..5edfaee 100644 --- a/src/soc/intel/broadwell/bootblock/systemagent.c +++ b/src/soc/intel/broadwell/bootblock/systemagent.c @@ -11,12 +11,12 @@
/* * The "io" variant of the config access is explicitly used to - * setup the PCIEXBAR because CONFIG_MMCONF_SUPPORT is set to + * setup the PCIEXBAR because CONFIG(MMCONF_SUPPORT) is set to * to true. That way all subsequent non-explicit config accesses use * MCFG. This code also assumes that bootblock_northbridge_init() is * the first thing called in the non-asm boot block code. The final * assumption is that no assembly code is using the - * CONFIG_MMCONF_SUPPORT option to do PCI config accesses. + * CONFIG(MMCONF_SUPPORT) option to do PCI config accesses. * * The PCIEXBAR is assumed to live in the memory mapped IO space under * 4GiB. diff --git a/src/soc/intel/common/block/systemagent/systemagent.c b/src/soc/intel/common/block/systemagent/systemagent.c index e6bbfc7..e5abbfd 100644 --- a/src/soc/intel/common/block/systemagent/systemagent.c +++ b/src/soc/intel/common/block/systemagent/systemagent.c @@ -226,7 +226,7 @@
/* * Add IMR ranges that hang off the host bridge/memory - * controller device in case CONFIG_SA_ENABLE_IMR is selected by SoC. + * controller device in case CONFIG(SA_ENABLE_IMR) is selected by SoC. */ static void sa_add_imr_resources(struct device *dev, int *resource_cnt) { diff --git a/src/soc/intel/common/block/systemagent/systemagent_def.h b/src/soc/intel/common/block/systemagent/systemagent_def.h index a7823c3..149e9b6 100644 --- a/src/soc/intel/common/block/systemagent/systemagent_def.h +++ b/src/soc/intel/common/block/systemagent/systemagent_def.h @@ -40,7 +40,7 @@ #define MCH_PAIR 0x5418
/* - * IMR register in case CONFIG_SA_ENABLE_IMR is selected by SoC. + * IMR register in case CONFIG(SA_ENABLE_IMR) is selected by SoC. * * IMR registers are found under MCHBAR. */
build bot (Jenkins) has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/43824 )
Patch Set 1:
https://review.coreboot.org/c/coreboot/+/43824/1/src/northbridge/intel/i945/... File src/northbridge/intel/i945/bootblock.c:
https://review.coreboot.org/c/coreboot/+/43824/1/src/northbridge/intel/i945/... PS1, Line 16: * no assembly code is using the CONFIG(MMCONF_SUPPORT) option to do PCI config accesses. line over 96 characters
Angel Pons has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/43824 )
Patch Set 1: Code-Review+1
Aaron Durbin has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/43824 )
Patch Set 1: Code-Review+2
Patrick Georgi has submitted this change. ( https://review.coreboot.org/c/coreboot/+/43824 )
Signed-off-by: Martin Roth martin@coreboot.org Change-Id: I5c37f0ee103721c97483d07a368c0b813e3f25c0 Reviewed-on: https://review.coreboot.org/c/coreboot/+/43824 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Aaron Durbin adurbin@chromium.org Reviewed-by: Angel Pons th3fanbus@gmail.com --- M src/cpu/intel/model_1067x/mp_init.c M src/device/dram/ddr2.c M src/device/dram/ddr3.c M src/drivers/intel/fsp2_0/include/fsp/debug.h M src/drivers/pc80/rtc/mc146818rtc.c M src/drivers/spi/tpm/tpm.c M src/ec/google/wilco/bootblock.h M src/ec/lenovo/h8/vboot.c M src/include/device/dram/common.h M src/include/device/dram/ddr3.h M src/include/mrc_cache.h M src/include/spi_flash.h M src/mainboard/emulation/qemu-q35/bootblock.c M src/mainboard/intel/harcuvar/romstage.c M src/northbridge/intel/gm45/bootblock.c M src/northbridge/intel/haswell/bootblock.c M src/northbridge/intel/i945/bootblock.c M src/northbridge/intel/sandybridge/bootblock.c M src/security/vboot/vboot_lib.c M src/soc/intel/broadwell/bootblock/systemagent.c M src/soc/intel/common/block/systemagent/systemagent.c M src/soc/intel/common/block/systemagent/systemagent_def.h 22 files changed, 32 insertions(+), 32 deletions(-)
Approvals: build bot (Jenkins): Verified Aaron Durbin: Looks good to me, approved Angel Pons: Looks good to me, approved
/* * The "io" variant of the config access is explicitly used to - * setup the PCIEXBAR because CONFIG_MMCONF_SUPPORT is set to + * setup the PCIEXBAR because CONFIG(MMCONF_SUPPORT) is set to * to true. That way all subsequent non-explicit config accesses use * MCFG. This code also assumes that bootblock_northbridge_init() is * the first thing called in the non-asm boot block code. The final * assumption is that no assembly code is using the - * CONFIG_MMCONF_SUPPORT option to do PCI config accesses. + * CONFIG(MMCONF_SUPPORT) option to do PCI config accesses. * * The PCIEXBAR is assumed to live in the memory mapped IO space under * 4GiB. diff --git a/src/soc/intel/common/block/systemagent/systemagent.c b/src/soc/intel/common/block/systemagent/systemagent.c index 72d611a..e12e07c 100644 --- a/src/soc/intel/common/block/systemagent/systemagent.c +++ b/src/soc/intel/common/block/systemagent/systemagent.c @@ -226,7 +226,7 @@
