Stefan Reinauer (stefan.reinauer@coreboot.org) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/4220
commit 40be588a90a724a0c76af1eb00bc22e3e49769c8 Author: Duncan Laurie dlaurie@chromium.org Date: Mon Jun 3 10:45:08 2013 -0700
haswell boards: Enable VIRTUAL_DEV_SWITCH
This config option was not enabled which was preventing the user from enabling developer mode from recovery mode.
With this enabled we can disable the "dev mode by default" behavior and let people enable it by entering recovery mode.
This will make the firmware behave like a typical chromeos device.
Peppy is left in "default dev mode" until after bringup.
1) boot slippy in normal mode by default 2) enter recovery mode with servo button 3) Ctrl+D on USB keyboard to enter developer mode 4) boot slippy in developer mode
Change-Id: I414c0d10dd0489e3c89798f75a2872a43297c8d8 Signed-off-by: Duncan Laurie dlaurie@chromium.org Reviewed-on: https://gerrit.chromium.org/gerrit/57350 Reviewed-by: Aaron Durbin adurbin@chromium.org --- src/mainboard/google/falco/Kconfig | 1 + src/mainboard/google/falco/chromeos.c | 2 +- src/mainboard/google/peppy/Kconfig | 1 + src/mainboard/google/slippy/Kconfig | 1 + src/mainboard/google/slippy/chromeos.c | 2 +- 5 files changed, 5 insertions(+), 2 deletions(-)
diff --git a/src/mainboard/google/falco/Kconfig b/src/mainboard/google/falco/Kconfig index 3a08086..3c0c576 100644 --- a/src/mainboard/google/falco/Kconfig +++ b/src/mainboard/google/falco/Kconfig @@ -10,6 +10,7 @@ config BOARD_SPECIFIC_OPTIONS # dummy select BOARD_ROMSIZE_KB_8192 select EC_GOOGLE_CHROMEEC select EC_SOFTWARE_SYNC + select VIRTUAL_DEV_SWITCH select HAVE_ACPI_TABLES select HAVE_OPTION_TABLE select HAVE_ACPI_RESUME diff --git a/src/mainboard/google/falco/chromeos.c b/src/mainboard/google/falco/chromeos.c index 1b70fde..51d625b 100644 --- a/src/mainboard/google/falco/chromeos.c +++ b/src/mainboard/google/falco/chromeos.c @@ -83,7 +83,7 @@ void fill_lb_gpios(struct lb_gpios *gpios) /* The dev-switch is virtual */ int get_developer_mode_switch(void) { - return 1; + return 0; }
/* There are actually two recovery switches. One is the magic keyboard chord, diff --git a/src/mainboard/google/peppy/Kconfig b/src/mainboard/google/peppy/Kconfig index 5eb8b95..74a04fb 100644 --- a/src/mainboard/google/peppy/Kconfig +++ b/src/mainboard/google/peppy/Kconfig @@ -10,6 +10,7 @@ config BOARD_SPECIFIC_OPTIONS # dummy select BOARD_ROMSIZE_KB_8192 select EC_GOOGLE_CHROMEEC select EC_SOFTWARE_SYNC + select VIRTUAL_DEV_SWITCH select HAVE_ACPI_TABLES select HAVE_OPTION_TABLE select HAVE_ACPI_RESUME diff --git a/src/mainboard/google/slippy/Kconfig b/src/mainboard/google/slippy/Kconfig index a53ac00..aaea947 100644 --- a/src/mainboard/google/slippy/Kconfig +++ b/src/mainboard/google/slippy/Kconfig @@ -10,6 +10,7 @@ config BOARD_SPECIFIC_OPTIONS # dummy select BOARD_ROMSIZE_KB_8192 select EC_GOOGLE_CHROMEEC select EC_SOFTWARE_SYNC + select VIRTUAL_DEV_SWITCH select HAVE_ACPI_TABLES select HAVE_OPTION_TABLE select HAVE_ACPI_RESUME diff --git a/src/mainboard/google/slippy/chromeos.c b/src/mainboard/google/slippy/chromeos.c index 1b70fde..51d625b 100644 --- a/src/mainboard/google/slippy/chromeos.c +++ b/src/mainboard/google/slippy/chromeos.c @@ -83,7 +83,7 @@ void fill_lb_gpios(struct lb_gpios *gpios) /* The dev-switch is virtual */ int get_developer_mode_switch(void) { - return 1; + return 0; }
