Lee Leahy (leroy.p.leahy@intel.com) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/16004
commit 138aa01b2f26d131ec9c6e2f5e7107babf9f7dd4 Author: Lee Leahy leroy.p.leahy@intel.com Date: Sat Jul 30 18:21:53 2016 -0700
soc/intel/quark: Support access to CPU CR registers
Add support to access CR0 and CR4.
TEST=Build and run on Galileo Gen2.
Change-Id: I8084b7824ae9fbcd55e11a7b5eec142591a7e279 Signed-off-by: Lee Leahy leroy.p.leahy@intel.com --- src/soc/intel/quark/include/soc/reg_access.h | 23 ++++++++++++++++ src/soc/intel/quark/reg_access.c | 39 ++++++++++++++++++++++++++++ 2 files changed, 62 insertions(+)
diff --git a/src/soc/intel/quark/include/soc/reg_access.h b/src/soc/intel/quark/include/soc/reg_access.h index a07bd22..62b0ac0 100644 --- a/src/soc/intel/quark/include/soc/reg_access.h +++ b/src/soc/intel/quark/include/soc/reg_access.h @@ -19,6 +19,7 @@ #define __SIMPLE_DEVICE__
#include <arch/io.h> +#include <cpu/x86/cr.h> #include <cpu/x86/msr.h> #include <delay.h> #include <fsp/util.h> @@ -38,6 +39,7 @@ enum { PCIE_RESET, GPE0_REGS, HOST_BRIDGE, + CPU_CR, };
enum { @@ -49,6 +51,27 @@ enum { _REG_SCRIPT_ENCODE_RAW(REG_SCRIPT_COMMAND_##cmd_, SOC_TYPE, \ size_, reg_, mask_, value_, timeout_, reg_set_)
+/* CPU CRx register access macros */ +#define REG_CPU_CR_ACCESS(cmd_, reg_, mask_, value_, timeout_) \ + SOC_ACCESS(cmd_, reg_, REG_SCRIPT_SIZE_32, mask_, value_, timeout_, \ + CPU_CR) +#define REG_CPU_CR_READ(reg_) \ + REG_CPU_CR_ACCESS(READ, reg_, 0, 0, 0) +#define REG_CPU_CR_WRITE(reg_, value_) \ + REG_CPU_CR_ACCESS(WRITE, reg_, 0, value_, 0) +#define REG_CPU_CR_AND(reg_, value_) \ + REG_CPU_CR_RMW(reg_, value_, 0) +#define REG_CPU_CR_RMW(reg_, mask_, value_) \ + REG_CPU_CR_ACCESS(RMW, reg_, mask_, value_, 0) +#define REG_CPU_CR_RXW(reg_, mask_, value_) \ + REG_CPU_CR_ACCESS(RXW, reg_, mask_, value_, 0) +#define REG_CPU_CR_OR(reg_, value_) \ + REG_CPU_CR_RMW(reg_, 0xffffffff, value_) +#define REG_CPU_CR_POLL(reg_, mask_, value_, timeout_) \ + REG_CPU_CR_ACCESS(POLL, reg_, mask_, value_, timeout_) +#define REG_CPU_CR_XOR(reg_, value_) \ + REG_CPU_CR_RXW(reg_, 0xffffffff, value_) + /* GPE0 controller register access macros */ #define REG_GPE0_ACCESS(cmd_, reg_, mask_, value_, timeout_) \ SOC_ACCESS(cmd_, reg_, REG_SCRIPT_SIZE_32, mask_, value_, timeout_, \ diff --git a/src/soc/intel/quark/reg_access.c b/src/soc/intel/quark/reg_access.c index 7383ddd..fe4de0b 100644 --- a/src/soc/intel/quark/reg_access.c +++ b/src/soc/intel/quark/reg_access.c @@ -144,6 +144,35 @@ void port_reg_write(uint8_t port, uint32_t offset, uint32_t value) mcr_write(QUARK_OPCODE_WRITE, port, offset); }
+static CRx_TYPE reg_cpu_cr_read(uint32_t reg_address) +{ + /* Read the CPU CRx register */ + switch(reg_address) { + case 0: + return read_cr0(); + + case 4: + return read_cr4(); + } + die("ERROR - Unsupported CPU register!\n"); + return 0; +} + +static void reg_cpu_cr_write(uint32_t reg_address, CRx_TYPE value) +{ + /* Write the CPU CRx register */ + switch(reg_address) { + default: + die("ERROR - Unsupported CPU register!\n"); + + case 0: + write_cr0(value); + + case 4: + write_cr4(value); + } +} + static uint32_t reg_gpe0_read(uint32_t reg_address) { /* Read the GPE0 register */ @@ -281,6 +310,11 @@ static uint64_t reg_read(struct reg_script_context *ctx) ctx->display_features = REG_SCRIPT_DISPLAY_NOTHING; return 0;
+ case CPU_CR: + ctx->display_prefix = "CPU CR"; + value = reg_cpu_cr_read(step->reg); + break; + case GPE0_REGS: ctx->display_prefix = "GPE0"; value = reg_gpe0_read(step->reg); @@ -336,6 +370,11 @@ static void reg_write(struct reg_script_context *ctx) ctx->display_features = REG_SCRIPT_DISPLAY_NOTHING; return;
+ case CPU_CR: + ctx->display_prefix = "CPU CR"; + reg_cpu_cr_write(step->reg, step->value); + break; + case GPE0_REGS: ctx->display_prefix = "GPE0"; reg_gpe0_write(step->reg, (uint32_t)step->value);
