Attention is currently required from: Benjamin Doron, Felix Held, Lean Sheng Tan, Matt DeVillier, Maximilian Brune.
Hello Felix Held, Julius Werner, Lean Sheng Tan, Matt DeVillier, Maximilian Brune, build bot (Jenkins),
https://review.coreboot.org/c/coreboot/+/84796?usp=email
The following approvals got outdated and were removed: Code-Review+2 by Lean Sheng Tan, Verified+1 by build bot (Jenkins)
Change subject: lib/{fit,fit_payload}.c: Enhance support for FIT images ......................................................................
This is done with the intention of supporting Universal Payload.
Currently, we read an "entry-start" prop. This should be called "entry", awaiting the spec change here https://github.com/UniversalPayload/spec/pull/19.
We also implement support for the "load" prop. Note that this is implemented here as a fdt64_t, which may need to be checked against other implementations.
The selected configuration no longer requires an FDT. In this case, we'll attempt a config matching the board ID, then fallback to the FIT default compat.
Change-Id: I6a21954c0dc5fd820d135e8cd0599ce87903a1c0 Signed-off-by: Benjamin Doron benjamin.doron@9elements.com --- M src/include/fit.h M src/lib/fit.c M src/lib/fit_payload.c 3 files changed, 122 insertions(+), 28 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/96/84796/5
