Attention is currently required from: Caveh Jalali, Eric Lai, Kapil Porwal, Subrata Banik, Tarun Tuli.
Hello Eric Lai, Kapil Porwal, Subrata Banik, Tarun Tuli,
https://review.coreboot.org/c/coreboot/+/75827?usp=email
The following approvals got outdated and were removed: Code-Review+2 by Eric Lai
Change subject: mb/google/rex: Set AUX orientation at SoC to follow cable for anx7452 ......................................................................
This configures the SoC to flip the orientation of the AUX pins to follow the orientation of the cable when using the anx7452 retimer. This is necessary when there is no external retimer/mux or the retimer/mux does not implement the flip. The anx7452 retimer does not appear to support this feature, so let the SoC do the flip.
BUG=b:267589042,b:281006910 TEST=verified DP-ALT mode works on rex using both cable orientations
Change-Id: Ibb9f442d2afd81fb5dde4bca97c15457837f9f4a Signed-off-by: Caveh Jalali caveh@chromium.org --- M src/mainboard/google/rex/variants/rex0/variant.c 1 file changed, 17 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/27/75827/2
