Aaron Durbin has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/44643 )
Change subject: mb/google/zork: provide full range backlight settings to kernel ......................................................................
Utilize the SOC_AMD_COMMON_BLOCK_GRAPHICS_ATIF option to provide full range backlight settings to the kernel.
BUG=b:163583825
Change-Id: I3c337fad38e668488800f4d6bc583a82a93659d3 Signed-off-by: Aaron Durbin adurbin@chromium.org --- M src/mainboard/google/zork/Kconfig 1 file changed, 1 insertion(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/43/44643/1
diff --git a/src/mainboard/google/zork/Kconfig b/src/mainboard/google/zork/Kconfig index 24c49c1..b452365 100644 --- a/src/mainboard/google/zork/Kconfig +++ b/src/mainboard/google/zork/Kconfig @@ -12,6 +12,7 @@ def_bool y select SOC_AMD_COMMON_BLOCK_USE_ESPI select SOC_AMD_PICASSO + select SOC_AMD_COMMON_BLOCK_GRAPHICS_ATIF select VGA_BIOS select BOARD_ROMSIZE_KB_16384 select DRIVERS_AMD_I2S_MACHINE_DEV
Furquan Shaikh has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/44643 )
Patch Set 1: Code-Review+2
Hello build bot (Jenkins), Furquan Shaikh,
BUG=b:163583825
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/43/44643/2
Aaron Durbin has submitted this change. ( https://review.coreboot.org/c/coreboot/+/44643 )
BUG=b:163583825
Change-Id: I3c337fad38e668488800f4d6bc583a82a93659d3 Signed-off-by: Aaron Durbin adurbin@chromium.org Reviewed-on: https://review.coreboot.org/c/coreboot/+/44643 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Furquan Shaikh furquan@google.com --- M src/mainboard/google/zork/Kconfig 1 file changed, 1 insertion(+), 0 deletions(-)
