Isaac Christensen (isaac.christensen@se-eng.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/6602
commit c9e797127a40ee41332386c3d9673b8e4c39d954 Author: Furquan Shaikh furquan@google.com Date: Tue Aug 6 13:48:12 2013 -0700
Falco: Patch to enable correct port clock selection for dp
This is required only for haswell since the register configs have changed. Also, created mainboard specific header file
Original-Change-Id: I61bf8d7cef1f204735a2f72225c48d6e44a99945 Signed-off-by: Furquan Shaikh furquan@google.com
Conflicts: src/mainboard/google/slippy/gma.c src/mainboard/google/slippy/i915io.c
Conflicts: src/mainboard/google/slippy/gma.c Change-Id: I77f2542ca8228358f59aafd99c0d13168ab47fb5 Reviewed-on: https://gerrit.chromium.org/gerrit/66853 Reviewed-by: Aaron Durbin adurbin@chromium.org Commit-Queue: Furquan Shaikh furquan@chromium.org Tested-by: Furquan Shaikh furquan@chromium.org (cherry picked from commit 77f9d1ddd4376e2a290d466f0669a43997492c8e) Signed-off-by: Isaac Christensen isaac.christensen@se-eng.com --- src/mainboard/google/slippy/gma.c | 25 ++++++++++++++++++++++++- src/mainboard/google/slippy/i915io.c | 5 ++--- src/mainboard/google/slippy/mainboard.h | 25 +++++++++++++++++++++++++ 3 files changed, 51 insertions(+), 4 deletions(-)
diff --git a/src/mainboard/google/slippy/gma.c b/src/mainboard/google/slippy/gma.c index 7c95e40..839fa4d 100644 --- a/src/mainboard/google/slippy/gma.c +++ b/src/mainboard/google/slippy/gma.c @@ -43,6 +43,7 @@ #include <cpu/x86/msr.h> #include <edid.h> #include <drivers/intel/gma/i915.h> +#include "mainboard.h"
/* * Here is the rough outline of how we bring up the display: @@ -228,7 +229,6 @@ int intel_dp_bw_code_to_link_rate(u8 link_bw) } }
-void mainboard_train_link(struct intel_dp *intel_dp); void mainboard_train_link(struct intel_dp *intel_dp) { u8 read_val; @@ -281,6 +281,29 @@ static void test_gfx(struct intel_dp *dp) static void test_gfx(struct intel_dp *dp) {} #endif
+ +void mainboard_set_port_clk_dp(struct intel_dp *intel_dp) +{ + u32 ddi_pll_sel = 0; + + switch (intel_dp->link_bw) { + case DP_LINK_BW_1_62: + ddi_pll_sel = PORT_CLK_SEL_LCPLL_810; + break; + case DP_LINK_BW_2_7: + ddi_pll_sel = PORT_CLK_SEL_LCPLL_1350; + break; + case DP_LINK_BW_5_4: + ddi_pll_sel = PORT_CLK_SEL_LCPLL_2700; + break; + default: + printk(BIOS_ERR, "invalid link bw %d\n", intel_dp->link_bw); + return; + } + + gtt_write(PORT_CLK_SEL(intel_dp->port), ddi_pll_sel); +} + int i915lightup(unsigned int pphysbase, unsigned int pmmio, unsigned int pgfx, unsigned int init_fb) { diff --git a/src/mainboard/google/slippy/i915io.c b/src/mainboard/google/slippy/i915io.c index 7fbffb6..aae7f29 100644 --- a/src/mainboard/google/slippy/i915io.c +++ b/src/mainboard/google/slippy/i915io.c @@ -26,6 +26,7 @@ #include <delay.h> #include <drivers/intel/gma/i915.h> #include <arch/io.h> +#include "mainboard.h"
/* these variables will be removed when the proper support is finished in src/drivers/intel/gma/intel_dp.c */ int index; @@ -33,8 +34,6 @@ u32 auxout; u8 auxin[20]; u8 msg[32];
-extern void mainboard_train_link(struct intel_dp *intel_dp); - /* this function will either be renamed or subsumed into ./gma.c:i915_lightup */ void runio(struct intel_dp *dp);
@@ -71,7 +70,7 @@ void runio(struct intel_dp *dp) gtt_write(PIPECONF(dp->transcoder),0x00000000); gtt_write(PCH_TRANSCONF(dp->pipe),0x00000000);
- gtt_write(PORT_CLK_SEL(dp->port),PORT_CLK_SEL_LCPLL_1350); + mainboard_set_port_clk_dp(dp); gtt_write(DSPSTRIDE(dp->plane),dp->stride); gtt_write(DSPCNTR(dp->plane),DISPLAY_PLANE_ENABLE|DISPPLANE_RGBX888); gtt_write(DEIIR,0x00000080); diff --git a/src/mainboard/google/slippy/mainboard.h b/src/mainboard/google/slippy/mainboard.h new file mode 100644 index 0000000..f47fffd --- /dev/null +++ b/src/mainboard/google/slippy/mainboard.h @@ -0,0 +1,25 @@ +/* +* This file is part of the coreboot project. +* +* Copyright 2013 Google Inc. +* +* This program is free software; you can redistribute it and/or modify +* it under the terms of the GNU General Public License as published by +* the Free Software Foundation; version 2 of the License. +* +* This program is distributed in the hope that it will be useful, +* but WITHOUT ANY WARRANTY; without even the implied warranty of +* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +* GNU General Public License for more details. +* +* You should have received a copy of the GNU General Public License +* along with this program; if not, write to the Free Software +* Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA +*/ + +#ifndef __MAINBOARD_H_ +#define __MAINBOARD_H_ +void mainboard_train_link(struct intel_dp *intel_dp); +void mainboard_set_port_clk_dp(struct intel_dp *intel_dp); + +#endif
