Patrick Georgi (pgeorgi@google.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/7306
commit c081e28f39a0440c5f850fe8548dbf89c780e9fe Author: Furquan Shaikh furquan@google.com Date: Thu Oct 30 11:53:38 2014 -0700
x86: Update the check for Forbidden global variables
Add a section .illegal_globals to romstage and check that the section does not contain any variables while creating romstage.
[pg: Handle individual AGESA special cases in the linker script instead of whitelisting everything remotely AGESA related in the Makefile.]
Change-Id: I866681f51a44bc21770d32995c281b556a90c153 Signed-off-by: Furquan Shaikh furquan@google.com Signed-off-by: Patrick Georgi pgeorgi@google.com --- src/arch/x86/Makefile.inc | 5 +++-- src/arch/x86/init/romstage.ld | 15 +++++++++++++++ 2 files changed, 18 insertions(+), 2 deletions(-)
diff --git a/src/arch/x86/Makefile.inc b/src/arch/x86/Makefile.inc index 9e67459..a92c55c 100644 --- a/src/arch/x86/Makefile.inc +++ b/src/arch/x86/Makefile.inc @@ -206,9 +206,10 @@ romstage-libs ?= $(objcbfs)/romstage_null.debug: $$(romstage-objs) $(objgenerated)/romstage_null.ld $$(romstage-libs) @printf " LINK $(subst $(obj)/,,$(@))\n" $(LD_romstage) -nostdlib -nostartfiles -static -o $@ -L$(obj) $(COMPILER_RT_FLAGS_romstage) --start-group $(romstage-objs) $(romstage-libs) $(COMPILER_RT_romstage) --end-group -T $(objgenerated)/romstage_null.ld - $(NM_romstage) $@ | grep -q " [DdBb] "; if [ $$? -eq 0 ]; then \ + $(OBJCOPY_romstage) --only-section .illegal_globals $(@) $(objcbfs)/romstage_null.offenders && \ + $(NM_romstage) $(objcbfs)/romstage_null.offenders | grep -q ""; if [ $$? -eq 0 ]; then \ echo "Forbidden global variables in romstage:"; \ - $(NM_romstage) $@ | grep " [DdBb] "; test "$(CONFIG_CPU_AMD_AGESA)" = y; \ + $(NM_romstage) $(objcbfs)/romstage_null.offenders; false; \ else true; fi
$(objcbfs)/romstage.debug: $$(romstage-objs) $(objgenerated)/romstage.ld $$(romstage-libs) diff --git a/src/arch/x86/init/romstage.ld b/src/arch/x86/init/romstage.ld index d6eb511..99bcc8e 100644 --- a/src/arch/x86/init/romstage.ld +++ b/src/arch/x86/init/romstage.ld @@ -65,5 +65,20 @@ SECTIONS preram_cbmem_console = .; }
+ /* Global variables are not allowed in romstage + * This section is checked during stage creation to ensure + * that there are no global variables present + */ + + . = 0xffffff00; + .illegal_globals . : { + *(EXCLUDE_FILE (*/libagesa.*.a: */buildOpts.romstage.o */agesawrapper.romstage.o */cpu/amd/agesa/*.romstage.o */vendorcode/amd/agesa/* */vendorcode/amd/cimx/*) .data) + *(.data.*) + *(.bss) + *(.bss.*) + *(.sbss) + *(.sbss.*) + } + _bogus = ASSERT((SIZEOF(.car.data) + CONFIG_CONSOLE_PRERAM_BUFFER_SIZE <= CONFIG_DCACHE_RAM_SIZE), "Cache as RAM area is too full"); }
