Attention is currently required from: Reka Norman.
Martin L Roth has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/80113?usp=email )
Change subject: util/spd_tools: Update Makefile.inc references to Makefile.mak ......................................................................
Make sure that any new files generated get the Makefile.mak name.
Signed-off-by: Martin Roth gaumless@gmail.com Change-Id: I3880d5911ff8de01751befdffc99ba5a961416f7 --- M util/spd_tools/README.md M util/spd_tools/src/part_id_gen/part_id_gen.go 2 files changed, 11 insertions(+), 11 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/13/80113/1
diff --git a/util/spd_tools/README.md b/util/spd_tools/README.md index bed3460..262c5fe 100644 --- a/util/spd_tools/README.md +++ b/util/spd_tools/README.md @@ -25,7 +25,7 @@ maps each supported platform to one of these sets. * `part_id_gen`: This tool allocates DRAM strap IDs for the different memory parts used by a board. It takes as input a CSV file of the memory parts used - with optional fixed IDs. It generates a Makefile.inc which is used to + with optional fixed IDs. It generates a Makefile.mak which is used to integrate the SPD files generated by `spd_gen` into the coreboot build.
## Tool 1 - `spd_gen` @@ -465,7 +465,7 @@
* 1) The SoC platform which the board is based on, e.g. ADL. * 2) The memory technology used by the board, One of ddr4, lp4x, or lp5. -* 3) The path to the directory where the generated Makefile.inc should be placed. +* 3) The path to the directory where the generated Makefile.mak should be placed. * 4) A CSV file containing a list of the memory parts used by the board, with an optional fixed or exclusive ID for each part and an optional SPD override file. A fixed ID is simply an integer and it ensure that part (and any that share the @@ -503,14 +503,14 @@
* It prints the DRAM hardware strap ID which should be allocated to each memory part in the input file. -* It generates a `Makefile.inc` in the given directory. This is used to +* It generates a `Makefile.mak` in the given directory. This is used to integrate the SPD files generated by `spd_gen` with the coreboot build for the board. * It generates a `dram_id.generated.txt` in the same directory as the - `Makefile.inc`. This lists the part IDs assigned to each memory part, and is + `Makefile.mak`. This lists the part IDs assigned to each memory part, and is useful for itegration with the board schematics.
-Sample `Makefile.inc`: +Sample `Makefile.mak`:
``` # SPDX-License-Identifier: GPL-2.0-or-later @@ -607,9 +607,9 @@ * Update the file containing the memory parts used by board (variant), by adding the new memory part name at the end of the file.
- * Use `part_id_gen` to update the variant's `Makefile.inc` and + * Use `part_id_gen` to update the variant's `Makefile.mak` and `dram_id.generated.txt` with the new part. - * Upload the changes to `Makefile.inc` and `dram_id.generated.txt` for + * Upload the changes to `Makefile.mak` and `dram_id.generated.txt` for review.
## How to add support for a new memory technology diff --git a/util/spd_tools/src/part_id_gen/part_id_gen.go b/util/spd_tools/src/part_id_gen/part_id_gen.go index 699905d..5d1a1f7 100644 --- a/util/spd_tools/src/part_id_gen/part_id_gen.go +++ b/util/spd_tools/src/part_id_gen/part_id_gen.go @@ -20,7 +20,7 @@ * It expects the following inputs: * Name of the SoC platform, e.g. TGL. * Memory technology used by the variant, e.g. lp4x. - * Path to Makefile directory. Makefile.inc generated by this program is placed in this + * Path to Makefile directory. Makefile.mak generated by this program is placed in this * location. * Text file containing a list of memory part names used by the board. Each line in the file * is expected to have one memory part name. @@ -29,7 +29,7 @@ SPDManifestFileName = "parts_spd_manifest.generated.txt" PlatformsManifestFileName = "platforms_manifest.generated.txt" SPDEmptyFileName = "spd-empty.hex" - MakefileName = "Makefile.inc" + MakefileName = "Makefile.mak" DRAMIdFileName = "dram_id.generated.txt" MaxMemoryId = 15 ) @@ -58,7 +58,7 @@ fmt.Printf(" supported platforms: %v\n", supportedPlatforms) fmt.Printf(" mem_technology = Memory technology used by the board\n") fmt.Printf(" supported technologies: %v\n", supportedMemTechs) - fmt.Printf(" makefile_dir = Directory path where generated Makefile.inc should be placed\n") + fmt.Printf(" makefile_dir = Directory path where generated Makefile.mak should be placed\n") fmt.Printf(" mem_parts_used_file = CSV file containing list of memory parts used by the board and optional fixed ids\n\n\n") }
@@ -410,7 +410,7 @@ }
/* - * This function generates Makefile.inc under the variant directory path and adds assigned SPDs + * This function generates Makefile.mak under the variant directory path and adds assigned SPDs * to SPD_SOURCES. */ func genMakefile(partIdList []partIds, makefileDirName string, SPDDir string, partsDir string) error {
