Angel Pons has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/43230 )
Change subject: nb/intel/i945: Drop dead code ......................................................................
This code is not even being build-tested. Drop it before it grows moss.
Change-Id: I5e33526a02872c14e9fa37a485d2f93dea8b088f Signed-off-by: Angel Pons th3fanbus@gmail.com --- M src/northbridge/intel/i945/early_init.c M src/northbridge/intel/i945/raminit.c 2 files changed, 1 insertion(+), 45 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/30/43230/1
diff --git a/src/northbridge/intel/i945/early_init.c b/src/northbridge/intel/i945/early_init.c index f388330..a8c160a 100644 --- a/src/northbridge/intel/i945/early_init.c +++ b/src/northbridge/intel/i945/early_init.c @@ -364,7 +364,7 @@ printk(BIOS_DEBUG, "timeout!\n"); else printk(BIOS_DEBUG, "done..\n"); -#if 1 + /* Enable Active State Power Management (ASPM) L0 state */
reg32 = DMIBAR32(DMILCAP); @@ -387,7 +387,6 @@
if (activate_aspm) DMIBAR32(DMILCTL) |= (3 << 0); -#endif
/* Last but not least, some additional steps */ reg32 = MCHBAR32(FSBSNPCTL); @@ -771,10 +770,6 @@
/* Initialize slot power limit for root ports */ pci_write_config32(PCI_DEV(0, 0x1c, 0), 0x54, 0x00000060); -#if 0 - pci_write_config32(PCI_DEV(0, 0x1c, 4), 0x54, 0x00480ce0); - pci_write_config32(PCI_DEV(0, 0x1c, 5), 0x54, 0x00500ce0); -#endif
pci_write_config32(PCI_DEV(0, 0x1c, 0), 0xd8, 0x00110000); } diff --git a/src/northbridge/intel/i945/raminit.c b/src/northbridge/intel/i945/raminit.c index 1c7a1f0..cfe4d8f 100644 --- a/src/northbridge/intel/i945/raminit.c +++ b/src/northbridge/intel/i945/raminit.c @@ -194,19 +194,6 @@ return (!reg8); }
-/* TODO check if we ever need this function */ -#if 0 -static int sdram_capabilities_MEM4G_disable(void) -{ - u8 reg8; - - reg8 = pci_read_config8(PCI_DEV(0, 0x00, 0), 0xe5); /* CAPID0 + 5 */ - reg8 &= (1 << 0); - - return (reg8 != 0); -} -#endif - #define GFX_FREQUENCY_CAP_166MHZ 0x04 #define GFX_FREQUENCY_CAP_200MHZ 0x03 #define GFX_FREQUENCY_CAP_250MHZ 0x02 @@ -2198,11 +2185,7 @@ reg16 |= (4 << 11); MCHBAR16(CPCTL) = reg16;
-#if 0 - if ((MCHBAR32(ECO) & (1 << 16)) != 0) { -#else if (i945_silicon_revision() != 0) { -#endif switch (sysinfo->fsb_frequency) { case 667: MCHBAR32(HGIPMC2) = 0x0d590d59; @@ -2253,13 +2236,6 @@ else MCHBAR32(ECO) |= (1 << 16);
-#if 0 - - if (i945_silicon_revision() == 0) - MCHBAR32(FSBPMC3) &= ~(1 << 29); - else - MCHBAR32(FSBPMC3) |= (1 << 29); -#endif MCHBAR32(FSBPMC3) &= ~(1 << 29);
MCHBAR32(FSBPMC3) |= (1 << 21); @@ -2288,19 +2264,6 @@
pci_or_config8(PCI_DEV(0, 0x2, 0), 0xc1, 1 << 2);
-#ifdef C2_SELF_REFRESH_DISABLE - - if (integrated_graphics) { - printk(BIOS_DEBUG, "C2 self-refresh with IGD\n"); - MCHBAR16(MIPMC4) = 0x0468; - MCHBAR16(MIPMC5) = 0x046c; - MCHBAR16(MIPMC6) = 0x046c; - } else { - MCHBAR16(MIPMC4) = 0x6468; - MCHBAR16(MIPMC5) = 0x646c; - MCHBAR16(MIPMC6) = 0x646c; - } -#else if (integrated_graphics) { MCHBAR16(MIPMC4) = 0x04f8; MCHBAR16(MIPMC5) = 0x04fc; @@ -2311,8 +2274,6 @@ MCHBAR16(MIPMC6) = 0x64fc; }
-#endif - reg32 = MCHBAR32(PMCFG); reg32 &= ~(3 << 17); reg32 |= (2 << 17);
Michael Niewöhner has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/43230 )
Patch Set 2: Code-Review+1
Patch Set 2: Code-Review+2
Angel Pons has submitted this change. ( https://review.coreboot.org/c/coreboot/+/43230 )
Change-Id: I5e33526a02872c14e9fa37a485d2f93dea8b088f Signed-off-by: Angel Pons th3fanbus@gmail.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/43230 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Michael Niewöhner --- M src/northbridge/intel/i945/early_init.c M src/northbridge/intel/i945/raminit.c 2 files changed, 1 insertion(+), 45 deletions(-)
Approvals: build bot (Jenkins): Verified Michael Niewöhner: Looks good to me, approved
