Furquan Shaikh has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/34118 )
Change subject: soc/intel/icelake: Use SA_DEV_ROOT instead of PCH_DEV_PMC ......................................................................
PMC device gets hidden from PCI bus after FSP-S call. Thus, it gets removed from the root bus as leftover unused device. With change 903b40a8a46 ("soc/intel: Replace uses of dev_find_slot()"), all uses of dev_find_slot() were replaced by pcidev_path_on_root() which relies on scanning of root bus to find the requested device. Since PMC device is removed from the root bus, pcidev_path_on_root() returns NULL for it thus resulting in configuration being skipped for the PMC ultimately resulting in S3 failures.
Since the PCH_DEV_PMC was just used to get to chip config, this change replaces the use of PCH_DEV_PMC with SA_DEV_ROOT.
BUG=b:136861224
Change-Id: Id68db8382b7b98e8e2e4a65ded1a6fb3bd057051 Signed-off-by: Furquan Shaikh furquan@google.com --- M src/soc/intel/icelake/finalize.c M src/soc/intel/icelake/pmc.c 2 files changed, 7 insertions(+), 2 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/18/34118/1
diff --git a/src/soc/intel/icelake/finalize.c b/src/soc/intel/icelake/finalize.c index e061cda..b838c19 100644 --- a/src/soc/intel/icelake/finalize.c +++ b/src/soc/intel/icelake/finalize.c @@ -69,8 +69,13 @@ * * Disabling ACPI PM timer is necessary for XTAL OSC shutdown. * Disabling ACPI PM timer also switches off TCO + * + * SA_DEV_ROOT device is used here instead of PCH_DEV_PMC since it is + * just required to get to chip config. PCH_DEV_PMC is hidden by this + * point and hence removed from the root bus. pcidev_path_on_root thus + * returns NULL for PCH_DEV_PMC device. */ - dev = PCH_DEV_PMC; + dev = SA_DEV_ROOT; config = dev->chip_info; pmcbase = pmc_mmio_regs(); if (config->PmTimerDisabled) { diff --git a/src/soc/intel/icelake/pmc.c b/src/soc/intel/icelake/pmc.c index 8f61d70..25913a8 100644 --- a/src/soc/intel/icelake/pmc.c +++ b/src/soc/intel/icelake/pmc.c @@ -136,7 +136,7 @@
static void pmc_init(void *unused) { - struct device *dev = PCH_DEV_PMC; + struct device *dev = SA_DEV_ROOT; config_t *config = dev->chip_info;
rtc_init();
Kyösti Mälkki has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/34118 )
Patch Set 1: Code-Review+2
Subrata Banik has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/34118 )
Patrick Georgi has submitted this change and it was merged. ( https://review.coreboot.org/c/coreboot/+/34118 )
BUG=b:136861224
Change-Id: Id68db8382b7b98e8e2e4a65ded1a6fb3bd057051 Signed-off-by: Furquan Shaikh furquan@google.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/34118 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Kyösti Mälkki kyosti.malkki@gmail.com Reviewed-by: Subrata Banik subrata.banik@intel.com --- M src/soc/intel/icelake/finalize.c M src/soc/intel/icelake/pmc.c 2 files changed, 7 insertions(+), 2 deletions(-)
Approvals: build bot (Jenkins): Verified Kyösti Mälkki: Looks good to me, approved Subrata Banik: Looks good to me, approved
rtc_init();
