Nick Vaccaro has submitted this change. ( https://review.coreboot.org/c/coreboot/+/56888 )
Change subject: mb/system76/*: Add CMOS option table ......................................................................
System76 uses several custom CMOS values downstream. Reduce our diff by providing a generic layout with the defaults:
boot_option=Fallback debug_level=Debug power_on_after_fail=Enable
Tested on galp3-c, gaze15, oryp5, oryp6. All boards boot multiple times with USE_OPTION_TABLE selected.
Change-Id: Ie57b0e5713bba8ad46e1a4123a3ddd43e0eea964 Signed-off-by: Tim Crawford tcrawford@system76.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/56888 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Arthur Heymans arthur@aheymans.xyz --- M src/mainboard/system76/gaze15/Kconfig A src/mainboard/system76/gaze15/cmos.default A src/mainboard/system76/gaze15/cmos.layout M src/mainboard/system76/lemp9/Kconfig A src/mainboard/system76/lemp9/cmos.default A src/mainboard/system76/lemp9/cmos.layout M src/mainboard/system76/oryp5/Kconfig A src/mainboard/system76/oryp5/cmos.default A src/mainboard/system76/oryp5/cmos.layout M src/mainboard/system76/oryp6/Kconfig A src/mainboard/system76/oryp6/cmos.default A src/mainboard/system76/oryp6/cmos.layout M src/mainboard/system76/whl-u/Kconfig A src/mainboard/system76/whl-u/cmos.default A src/mainboard/system76/whl-u/cmos.layout 15 files changed, 205 insertions(+), 0 deletions(-)
Approvals: build bot (Jenkins): Verified Arthur Heymans: Looks good to me, approved
diff --git a/src/mainboard/system76/gaze15/Kconfig b/src/mainboard/system76/gaze15/Kconfig index 4ee05ee..2d19fad 100644 --- a/src/mainboard/system76/gaze15/Kconfig +++ b/src/mainboard/system76/gaze15/Kconfig @@ -9,6 +9,8 @@ select EC_SYSTEM76_EC_COLOR_KEYBOARD select HAVE_ACPI_RESUME select HAVE_ACPI_TABLES + select HAVE_CMOS_DEFAULT + select HAVE_OPTION_TABLE select INTEL_GMA_HAVE_VBT select INTEL_LPSS_UART_FOR_CONSOLE select MAINBOARD_HAS_LPC_TPM diff --git a/src/mainboard/system76/gaze15/cmos.default b/src/mainboard/system76/gaze15/cmos.default new file mode 100644 index 0000000..d564953 --- /dev/null +++ b/src/mainboard/system76/gaze15/cmos.default @@ -0,0 +1,3 @@ +boot_option=Fallback +debug_level=Debug +power_on_after_fail=Enable diff --git a/src/mainboard/system76/gaze15/cmos.layout b/src/mainboard/system76/gaze15/cmos.layout new file mode 100644 index 0000000..c0275d6 --- /dev/null +++ b/src/mainboard/system76/gaze15/cmos.layout @@ -0,0 +1,36 @@ +# SPDX-License-Identifier: GPL-2.0-only + +entries + +0 384 r 0 reserved_memory + +# RTC_BOOT_BYTE (coreboot hardcoded) +384 1 e 4 boot_option +388 4 h 0 reboot_counter + +395 4 e 6 debug_level +409 2 e 7 power_on_after_fail +984 16 h 0 check_sum + +enumerations + +4 0 Fallback +4 1 Normal + +6 0 Emergency +6 1 Alert +6 2 Critical +6 3 Error +6 4 Warning +6 5 Notice +6 6 Info +6 7 Debug +6 8 Spew + +7 0 Disable +7 1 Enable +7 2 Keep + +checksums + +checksum 392 983 984 diff --git a/src/mainboard/system76/lemp9/Kconfig b/src/mainboard/system76/lemp9/Kconfig index ddb819b..2a547fd 100644 --- a/src/mainboard/system76/lemp9/Kconfig +++ b/src/mainboard/system76/lemp9/Kconfig @@ -8,6 +8,8 @@ select EC_SYSTEM76_EC_BAT_THRESHOLDS select HAVE_ACPI_RESUME select HAVE_ACPI_TABLES + select HAVE_CMOS_DEFAULT + select HAVE_OPTION_TABLE select HAVE_SMI_HANDLER select HAVE_SPD_IN_CBFS select INTEL_GMA_HAVE_VBT diff --git a/src/mainboard/system76/lemp9/cmos.default b/src/mainboard/system76/lemp9/cmos.default new file mode 100644 index 0000000..d564953 --- /dev/null +++ b/src/mainboard/system76/lemp9/cmos.default @@ -0,0 +1,3 @@ +boot_option=Fallback +debug_level=Debug +power_on_after_fail=Enable diff --git a/src/mainboard/system76/lemp9/cmos.layout b/src/mainboard/system76/lemp9/cmos.layout new file mode 100644 index 0000000..c0275d6 --- /dev/null +++ b/src/mainboard/system76/lemp9/cmos.layout @@ -0,0 +1,36 @@ +# SPDX-License-Identifier: GPL-2.0-only + +entries + +0 384 r 0 reserved_memory + +# RTC_BOOT_BYTE (coreboot hardcoded) +384 1 e 4 boot_option +388 4 h 0 reboot_counter + +395 4 e 6 debug_level +409 2 e 7 power_on_after_fail +984 16 h 0 check_sum + +enumerations + +4 0 Fallback +4 1 Normal + +6 0 Emergency +6 1 Alert +6 2 Critical +6 3 Error +6 4 Warning +6 5 Notice +6 6 Info +6 7 Debug +6 8 Spew + +7 0 Disable +7 1 Enable +7 2 Keep + +checksums + +checksum 392 983 984 diff --git a/src/mainboard/system76/oryp5/Kconfig b/src/mainboard/system76/oryp5/Kconfig index 5b95c98..fa4ec7f 100644 --- a/src/mainboard/system76/oryp5/Kconfig +++ b/src/mainboard/system76/oryp5/Kconfig @@ -10,6 +10,8 @@ select EC_SYSTEM76_EC_COLOR_KEYBOARD select HAVE_ACPI_RESUME select HAVE_ACPI_TABLES + select HAVE_CMOS_DEFAULT + select HAVE_OPTION_TABLE select INTEL_GMA_HAVE_VBT select INTEL_LPSS_UART_FOR_CONSOLE select MAINBOARD_HAS_LPC_TPM diff --git a/src/mainboard/system76/oryp5/cmos.default b/src/mainboard/system76/oryp5/cmos.default new file mode 100644 index 0000000..d564953 --- /dev/null +++ b/src/mainboard/system76/oryp5/cmos.default @@ -0,0 +1,3 @@ +boot_option=Fallback +debug_level=Debug +power_on_after_fail=Enable diff --git a/src/mainboard/system76/oryp5/cmos.layout b/src/mainboard/system76/oryp5/cmos.layout new file mode 100644 index 0000000..c0275d6 --- /dev/null +++ b/src/mainboard/system76/oryp5/cmos.layout @@ -0,0 +1,36 @@ +# SPDX-License-Identifier: GPL-2.0-only + +entries + +0 384 r 0 reserved_memory + +# RTC_BOOT_BYTE (coreboot hardcoded) +384 1 e 4 boot_option +388 4 h 0 reboot_counter + +395 4 e 6 debug_level +409 2 e 7 power_on_after_fail +984 16 h 0 check_sum + +enumerations + +4 0 Fallback +4 1 Normal + +6 0 Emergency +6 1 Alert +6 2 Critical +6 3 Error +6 4 Warning +6 5 Notice +6 6 Info +6 7 Debug +6 8 Spew + +7 0 Disable +7 1 Enable +7 2 Keep + +checksums + +checksum 392 983 984 diff --git a/src/mainboard/system76/oryp6/Kconfig b/src/mainboard/system76/oryp6/Kconfig index 2ebe4c8..4f17e55 100644 --- a/src/mainboard/system76/oryp6/Kconfig +++ b/src/mainboard/system76/oryp6/Kconfig @@ -10,6 +10,8 @@ select EC_SYSTEM76_EC_COLOR_KEYBOARD select HAVE_ACPI_RESUME select HAVE_ACPI_TABLES + select HAVE_CMOS_DEFAULT + select HAVE_OPTION_TABLE select INTEL_GMA_HAVE_VBT select MAINBOARD_HAS_LPC_TPM select MAINBOARD_HAS_TPM2 diff --git a/src/mainboard/system76/oryp6/cmos.default b/src/mainboard/system76/oryp6/cmos.default new file mode 100644 index 0000000..d564953 --- /dev/null +++ b/src/mainboard/system76/oryp6/cmos.default @@ -0,0 +1,3 @@ +boot_option=Fallback +debug_level=Debug +power_on_after_fail=Enable diff --git a/src/mainboard/system76/oryp6/cmos.layout b/src/mainboard/system76/oryp6/cmos.layout new file mode 100644 index 0000000..c0275d6 --- /dev/null +++ b/src/mainboard/system76/oryp6/cmos.layout @@ -0,0 +1,36 @@ +# SPDX-License-Identifier: GPL-2.0-only + +entries + +0 384 r 0 reserved_memory + +# RTC_BOOT_BYTE (coreboot hardcoded) +384 1 e 4 boot_option +388 4 h 0 reboot_counter + +395 4 e 6 debug_level +409 2 e 7 power_on_after_fail +984 16 h 0 check_sum + +enumerations + +4 0 Fallback +4 1 Normal + +6 0 Emergency +6 1 Alert +6 2 Critical +6 3 Error +6 4 Warning +6 5 Notice +6 6 Info +6 7 Debug +6 8 Spew + +7 0 Disable +7 1 Enable +7 2 Keep + +checksums + +checksum 392 983 984 diff --git a/src/mainboard/system76/whl-u/Kconfig b/src/mainboard/system76/whl-u/Kconfig index 1b8130a..95f861a 100644 --- a/src/mainboard/system76/whl-u/Kconfig +++ b/src/mainboard/system76/whl-u/Kconfig @@ -9,6 +9,8 @@ select EC_SYSTEM76_EC_COLOR_KEYBOARD if BOARD_SYSTEM76_DARP5 select HAVE_ACPI_RESUME select HAVE_ACPI_TABLES + select HAVE_CMOS_DEFAULT + select HAVE_OPTION_TABLE select INTEL_GMA_HAVE_VBT select INTEL_LPSS_UART_FOR_CONSOLE select MAINBOARD_HAS_LPC_TPM diff --git a/src/mainboard/system76/whl-u/cmos.default b/src/mainboard/system76/whl-u/cmos.default new file mode 100644 index 0000000..d564953 --- /dev/null +++ b/src/mainboard/system76/whl-u/cmos.default @@ -0,0 +1,3 @@ +boot_option=Fallback +debug_level=Debug +power_on_after_fail=Enable diff --git a/src/mainboard/system76/whl-u/cmos.layout b/src/mainboard/system76/whl-u/cmos.layout new file mode 100644 index 0000000..c0275d6 --- /dev/null +++ b/src/mainboard/system76/whl-u/cmos.layout @@ -0,0 +1,36 @@ +# SPDX-License-Identifier: GPL-2.0-only + +entries + +0 384 r 0 reserved_memory + +# RTC_BOOT_BYTE (coreboot hardcoded) +384 1 e 4 boot_option +388 4 h 0 reboot_counter + +395 4 e 6 debug_level +409 2 e 7 power_on_after_fail +984 16 h 0 check_sum + +enumerations + +4 0 Fallback +4 1 Normal + +6 0 Emergency +6 1 Alert +6 2 Critical +6 3 Error +6 4 Warning +6 5 Notice +6 6 Info +6 7 Debug +6 8 Spew + +7 0 Disable +7 1 Enable +7 2 Keep + +checksums + +checksum 392 983 984
