Justin TerAvest has uploaded this change for review. ( https://review.coreboot.org/23520
Change subject: mb/google/kahlee: Fix grunt I2C rise/fall times ......................................................................
I2C bus rise/fall times were measured as follows. Signals were generated with: - bus 0: manual i2c driver in depthcharge - bus 2,3: i2cdetect -r <bus_number> and then measured manually with an oscilloscope.
BUG=b:72442912
Change-Id: I291e144249271ec34a93417398e54e68b8e21e23 Signed-off-by: Justin TerAvest teravest@chromium.org --- M src/mainboard/google/kahlee/variants/grunt/devicetree.cb 1 file changed, 9 insertions(+), 9 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/20/23520/1
diff --git a/src/mainboard/google/kahlee/variants/grunt/devicetree.cb b/src/mainboard/google/kahlee/variants/grunt/devicetree.cb index 9665a78..7ffc0ac 100644 --- a/src/mainboard/google/kahlee/variants/grunt/devicetree.cb +++ b/src/mainboard/google/kahlee/variants/grunt/devicetree.cb @@ -21,11 +21,11 @@ register "uma_mode" = "UMAMODE_SPECIFIED_SIZE" register "uma_size" = "128 * MiB"
- # TODO(teravest): Fix speeds here. + # Enable I2C0 for audio, USB3 hub at 400kHz register "i2c[0]" = "{ .speed = I2C_SPEED_FAST, - .rise_time_ns = 104, - .fall_time_ns = 52, + .rise_time_ns = 95, + .fall_time_ns = 3, }"
# Enable I2C1 for H1 at 400kHz @@ -36,18 +36,18 @@ .fall_time_ns = 4, }"
- # TODO(teravest): Fix speeds here. + # Enable I2C2 for trackpad, pen at 400kHz register "i2c[2]" = "{ .speed = I2C_SPEED_FAST, - .rise_time_ns = 104, - .fall_time_ns = 52, + .rise_time_ns = 117, + .fall_time_ns = 113, }"
- # TODO(teravest): Fix speeds here. + # Enable I2C3 for touchscreen at 400kHz register "i2c[3]" = "{ .speed = I2C_SPEED_FAST, - .rise_time_ns = 104, - .fall_time_ns = 52, + .rise_time_ns = 82, + .fall_time_ns = 67, }"
device cpu_cluster 0 on
