Stefan Reinauer (stefan.reinauer@coreboot.org) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/9220
commit 05b9e07b6617c67c65d34b412831407499b9a8fe Author: Duncan Laurie dlaurie@chromium.org Date: Mon Sep 29 08:35:29 2014 -0700
samus: Fix and clean up GPIOs and EC info/events
- Define specific GPIOs in gpio.h instaed of smihandler.c - Add battery status event to SCI list - Remove old proto board version defines and SPD index usage - Do not disable cmd_pwr training now that it works on EVT board
BUG=chrome-os-partner:32196,chrome-os-partner:29117 BRANCH=samus TEST=build and boot on samus
Change-Id: I50f1599aa4266ed61749cc7f4229a9384b498df2 Signed-off-by: Stefan Reinauer reinauer@chromium.org Original-Commit-Id: 0e3ebcb8659c92874d3ca89fa3a6795c9b6eebfa Original-Change-Id: I53cf8d80ed7f675c10fa04e8fe8b879a4af9b21f Original-Signed-off-by: Duncan Laurie dlaurie@chromium.org Original-Reviewed-on: https://chromium-review.googlesource.com/220321 Original-Reviewed-by: Aaron Durbin adurbin@chromium.org --- src/mainboard/google/samus/ec.h | 5 +---- src/mainboard/google/samus/gpio.h | 2 ++ src/mainboard/google/samus/romstage.c | 7 ------- src/mainboard/google/samus/smihandler.c | 17 +++++++---------- src/mainboard/google/samus/spd/spd.c | 4 ---- src/mainboard/google/samus/spd/spd.h | 1 - 6 files changed, 10 insertions(+), 26 deletions(-)
diff --git a/src/mainboard/google/samus/ec.h b/src/mainboard/google/samus/ec.h index 612d591..1ba1677 100644 --- a/src/mainboard/google/samus/ec.h +++ b/src/mainboard/google/samus/ec.h @@ -22,10 +22,6 @@
#include <ec/google/chromeec/ec_commands.h>
-#define SAMUS_EC_BOARD_PROTO1_9 0 -#define SAMUS_EC_BOARD_PROTO2_A 1 -#define SAMUS_EC_BOARD_PROTO2_B 2 - #define EC_SCI_GPI 36 /* GPIO36 is EC_SCI# */ #define EC_SMI_GPI 34 /* GPIO34 is EC_SMI# */
@@ -37,6 +33,7 @@ EC_HOST_EVENT_MASK(EC_HOST_EVENT_BATTERY_LOW) |\ EC_HOST_EVENT_MASK(EC_HOST_EVENT_BATTERY_CRITICAL) |\ EC_HOST_EVENT_MASK(EC_HOST_EVENT_BATTERY) |\ + EC_HOST_EVENT_MASK(EC_HOST_EVENT_BATTERY_STATUS) |\ EC_HOST_EVENT_MASK(EC_HOST_EVENT_THERMAL_THRESHOLD) |\ EC_HOST_EVENT_MASK(EC_HOST_EVENT_THERMAL_OVERLOAD) |\ EC_HOST_EVENT_MASK(EC_HOST_EVENT_THROTTLE_START) |\ diff --git a/src/mainboard/google/samus/gpio.h b/src/mainboard/google/samus/gpio.h index b7ddcb0..29966df 100644 --- a/src/mainboard/google/samus/gpio.h +++ b/src/mainboard/google/samus/gpio.h @@ -24,6 +24,8 @@
#define SAMUS_GPIO_PP3300_AUTOBAHN_EN 23 #define SAMUS_GPIO_SSD_RESET_L 47 +#define SAMUS_GPIO_WLAN_DISABLE_L 42 +#define SAMUS_GPIO_LTE_DISABLE_L 59
static const struct gpio_config mainboard_gpio_config[] = { PCH_GPIO_UNUSED, /* 0: UNUSED */ diff --git a/src/mainboard/google/samus/romstage.c b/src/mainboard/google/samus/romstage.c index 44d712e..0d1e451 100644 --- a/src/mainboard/google/samus/romstage.c +++ b/src/mainboard/google/samus/romstage.c @@ -55,13 +55,6 @@ void mainboard_romstage_entry(struct romstage_params *rp) mainboard_fill_spd_data(&pei_data); rp->pei_data = &pei_data;
- /* - * Disable use of PEI saved data to work around memory issues. - */ - if (cpu_family_model() == BROADWELL_FAMILY_ULT) { - pei_data.disable_cmd_pwr = 1; - } - /* Initalize memory */ romstage_common(rp);
diff --git a/src/mainboard/google/samus/smihandler.c b/src/mainboard/google/samus/smihandler.c index 932d606..a97f426 100644 --- a/src/mainboard/google/samus/smihandler.c +++ b/src/mainboard/google/samus/smihandler.c @@ -31,10 +31,7 @@ #include <broadwell/pm.h> #include <broadwell/smm.h> #include "ec.h" - -#define GPIO_SSD_RESET_L 47 -#define GPIO_WLAN_DISABLE_L 42 -#define GPIO_LTE_DISABLE_L 59 +#include "gpio.h"
int mainboard_io_trap_handler(int smif) { @@ -104,11 +101,11 @@ void mainboard_smi_sleep(u8 slp_typ) }
/* Put SSD in reset to prevent leak. */ - set_gpio(GPIO_SSD_RESET_L, 0); + set_gpio(SAMUS_GPIO_SSD_RESET_L, 0); /* Prevent leak from standby rail to WLAN rail in S3. */ - set_gpio(GPIO_WLAN_DISABLE_L, 0); + set_gpio(SAMUS_GPIO_WLAN_DISABLE_L, 0); /* Disable LTE */ - set_gpio(GPIO_LTE_DISABLE_L, 0); + set_gpio(SAMUS_GPIO_LTE_DISABLE_L, 0);
/* Enable wake events */ google_chromeec_set_wake_mask(MAINBOARD_EC_S3_WAKE_EVENTS); @@ -122,11 +119,11 @@ void mainboard_smi_sleep(u8 slp_typ) }
/* Put SSD in reset to prevent leak. */ - set_gpio(GPIO_SSD_RESET_L, 0); + set_gpio(SAMUS_GPIO_SSD_RESET_L, 0); /* Prevent leak from standby rail to WLAN rail in S5. */ - set_gpio(GPIO_WLAN_DISABLE_L, 0); + set_gpio(SAMUS_GPIO_WLAN_DISABLE_L, 0); /* Disable LTE */ - set_gpio(GPIO_LTE_DISABLE_L, 0); + set_gpio(SAMUS_GPIO_LTE_DISABLE_L, 0);
/* Enable wake events */ google_chromeec_set_wake_mask(MAINBOARD_EC_S5_WAKE_EVENTS); diff --git a/src/mainboard/google/samus/spd/spd.c b/src/mainboard/google/samus/spd/spd.c index 00e694e..0051fee 100644 --- a/src/mainboard/google/samus/spd/spd.c +++ b/src/mainboard/google/samus/spd/spd.c @@ -93,10 +93,6 @@ void mainboard_fill_spd_data(struct pei_data *pei_data) int spd_file_len; struct cbfs_file *spd_file;
- /* Proto2B boards use a different GPIO for SPD index bit 3 */ - if (google_chromeec_get_board_version() <= SAMUS_EC_BOARD_PROTO2_A) - spd_bits[3] = SPD_GPIO_BIT3_OLD; - spd_gpio[0] = get_gpio(spd_bits[0]); spd_gpio[1] = get_gpio(spd_bits[1]); spd_gpio[2] = get_gpio(spd_bits[2]); diff --git a/src/mainboard/google/samus/spd/spd.h b/src/mainboard/google/samus/spd/spd.h index 4b2f3aa..27d1469 100644 --- a/src/mainboard/google/samus/spd/spd.h +++ b/src/mainboard/google/samus/spd/spd.h @@ -37,7 +37,6 @@ #define SPD_GPIO_BIT1 68 #define SPD_GPIO_BIT2 67 #define SPD_GPIO_BIT3 65 -#define SPD_GPIO_BIT3_OLD 66
struct pei_data; void mainboard_fill_spd_data(struct pei_data *pei_data);
