Ronald G. Minnich (rminnich@gmail.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/11699
commit 37cd07ad1a305b87360cf49b643b67201d62e638 Author: Ronald G. Minnich rminnich@gmail.com Date: Tue Sep 22 15:53:32 2015 -0700
RISCV: modify arch_prog_run to handle payloads correctly.
Unlike the other stages, the payload requires virtual memory to be set up and also a privelege level change.
Change-Id: Ibbe2a55f7719d917f121a53a17c6d90e6b2ab3d1 Signed-off-by: Ronald G. Minnich rminnich@gmail.com --- src/arch/riscv/boot.c | 14 +++++++++++--- 1 file changed, 11 insertions(+), 3 deletions(-)
diff --git a/src/arch/riscv/boot.c b/src/arch/riscv/boot.c index d07d825..ab4ae95 100644 --- a/src/arch/riscv/boot.c +++ b/src/arch/riscv/boot.c @@ -18,11 +18,19 @@ */
#include <program_loading.h> +#include <vm.h> +#include <arch/encoding.h> +#include <rules.h>
void arch_prog_run(struct prog *prog) { - void (*doit)(void *); + void (*doit)(void *) = prog_entry(prog);
- doit = prog_entry(prog); - doit(prog_entry_arg(prog)); + if (ENV_RAMSTAGE && prog_type(prog) == ASSET_PAYLOAD) { + initVirtualMemory(); + write_csr(mepc, doit); + asm volatile("eret"); + } else { + doit(prog_entry_arg(prog)); + } }
