David Wu has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/64888 )
Change subject: mb/google/brask/var/kuldax: update overridetree ......................................................................
Update override devicetree based on schematics.
BUG=b:232419765 TEST=FW_NAME=kuldax emerge-brask coreboot
Signed-off-by: David Wu david_wu@quanta.corp-partner.google.com Change-Id: Ib66a97cd76cb169e3f33a4d2d2465db115939d03 --- M src/mainboard/google/brya/variants/kuldax/overridetree.cb 1 file changed, 244 insertions(+), 2 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/88/64888/1
diff --git a/src/mainboard/google/brya/variants/kuldax/overridetree.cb b/src/mainboard/google/brya/variants/kuldax/overridetree.cb index 4f2c04a..a885d69 100644 --- a/src/mainboard/google/brya/variants/kuldax/overridetree.cb +++ b/src/mainboard/google/brya/variants/kuldax/overridetree.cb @@ -1,6 +1,248 @@ chip soc/intel/alderlake + register "serial_io_gspi_mode" = "{ + [PchSerialIoIndexGSPI0] = PchSerialIoDisabled, + [PchSerialIoIndexGSPI1] = PchSerialIoDisabled, + }"
- device domain 0 on - end + device domain 0 on + device ref dtt on + chip drivers/intel/dptf + ## sensor information + register "options.tsr[0].desc" = ""DRAM"" + register "options.tsr[1].desc" = ""Charger""
+ # TODO: below values are initial reference values only + ## Active Policy + register "policies.active" = "{ + [0] = { + .target = DPTF_CPU, + .thresholds = { + TEMP_PCT(85, 90), + TEMP_PCT(80, 80), + TEMP_PCT(75, 70), + } + } + }" + + ## Passive Policy + register "policies.passive" = "{ + [0] = DPTF_PASSIVE(CPU, CPU, 95, 5000), + [1] = DPTF_PASSIVE(CPU, TEMP_SENSOR_0, 75, 5000), + [2] = DPTF_PASSIVE(CHARGER, TEMP_SENSOR_1, 75, 5000), + }" + + ## Critical Policy + register "policies.critical" = "{ + [0] = DPTF_CRITICAL(CPU, 105, SHUTDOWN), + [1] = DPTF_CRITICAL(TEMP_SENSOR_0, 85, SHUTDOWN), + [2] = DPTF_CRITICAL(TEMP_SENSOR_1, 85, SHUTDOWN), + }" + + register "controls.power_limits" = "{ + .pl1 = { + .min_power = 3000, + .max_power = 15000, + .time_window_min = 28 * MSECS_PER_SEC, + .time_window_max = 32 * MSECS_PER_SEC, + .granularity = 200, + }, + .pl2 = { + .min_power = 55000, + .max_power = 55000, + .time_window_min = 28 * MSECS_PER_SEC, + .time_window_max = 32 * MSECS_PER_SEC, + .granularity = 1000, + } + }" + + ## Charger Performance Control (Control, mA) + register "controls.charger_perf" = "{ + [0] = { 255, 1700 }, + [1] = { 24, 1500 }, + [2] = { 16, 1000 }, + [3] = { 8, 500 } + }" + + ## Fan Performance Control (Percent, Speed, Noise, Power) + register "controls.fan_perf" = "{ + [0] = { 90, 6700, 220, 2200, }, + [1] = { 80, 5800, 180, 1800, }, + [2] = { 70, 5000, 145, 1450, }, + [3] = { 60, 4900, 115, 1150, }, + [4] = { 50, 3838, 90, 900, }, + [5] = { 40, 2904, 55, 550, }, + [6] = { 30, 2337, 30, 300, }, + [7] = { 20, 1608, 15, 150, }, + [8] = { 10, 800, 10, 100, }, + [9] = { 0, 0, 0, 50, } + }" + + ## Fan options + register "options.fan.fine_grained_control" = "1" + register "options.fan.step_size" = "2" + + device generic 0 alias dptf_policy on end + end + end + device ref pcie4_0 on + # Enable CPU PCIE RP 1 using CLK 0 + register "cpu_pcie_rp[CPU_RP(1)]" = "{ + .clk_req = 0, + .clk_src = 0, + .flags = PCIE_RP_LTR | PCIE_RP_AER, + }" + end + device ref tcss_dma0 on + chip drivers/intel/usb4/retimer + register "dfp[0].power_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_HIGH(GPP_E4)" + use tcss_usb3_port1 as dfp[0].typec_port + device generic 0 on end + end + end + device ref cnvi_wifi on + chip drivers/wifi/generic + register "wake" = "GPE0_PME_B0" + device generic 0 on end + end + end + device ref i2c0 on + chip drivers/i2c/nau8825 + register "irq_gpio" = "ACPI_GPIO_IRQ_LEVEL_LOW(GPP_A23)" + register "jkdet_enable" = "1" + register "jkdet_pull_enable" = "0" + register "jkdet_pull_up" = "0" + register "jkdet_polarity" = "1" # ActiveLow + register "vref_impedance" = "2" # 125kOhm + register "micbias_voltage" = "6" # 2.754 + register "sar_threshold_num" = "4" + register "sar_threshold[0]" = "0x0C" + register "sar_threshold[1]" = "0x1C" + register "sar_threshold[2]" = "0x38" + register "sar_threshold[3]" = "0x60" + register "sar_hysteresis" = "1" + register "sar_voltage" = "6" + register "sar_compare_time" = "0" # 500ns + register "sar_sampling_time" = "0" # 2us + register "short_key_debounce" = "2" # 100ms + register "jack_insert_debounce" = "7" # 512ms + register "jack_eject_debounce" = "7" # 512ms + device i2c 1a on end + end + end + device ref pcie_rp7 on + chip drivers/net + register "wake" = "GPE0_DW0_07" + register "led_feature" = "0xe0" + register "customized_led0" = "0x23f" + register "customized_led2" = "0x028" + register "enable_aspm_l1_2" = "1" + device pci 00.0 on end + end + end # RTL8125 Ethernet NIC + device ref pcie_rp8 on + chip soc/intel/common/block/pcie/rtd3 + register "enable_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_HIGH(GPP_H13)" + register "reset_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_LOW(GPP_D18)" + register "srcclk_pin" = "3" + device generic 0 on end + end + end #PCIE8 SD card + device ref gspi1 off end + device ref pch_espi on + chip ec/google/chromeec + use conn0 as mux_conn[0] + device pnp 0c09.0 on end + end + end + device ref pmc hidden + chip drivers/intel/pmc_mux + device generic 0 on + chip drivers/intel/pmc_mux/conn + use usb2_port1 as usb2_port + use tcss_usb3_port1 as usb3_port + device generic 0 alias conn0 on end + end + end + end + end + device ref tcss_xhci on + chip drivers/usb/acpi + device ref tcss_root_hub on + chip drivers/usb/acpi + register "desc" = ""USB3 Type-C Port C0 (MLB)"" + register "type" = "UPC_TYPE_C_USB2_SS_SWITCH" + register "group" = "ACPI_PLD_GROUP(1, 1)" + device ref tcss_usb3_port1 on end + end + end + end + end + device ref xhci on + chip drivers/usb/acpi + device ref xhci_root_hub on + chip drivers/usb/acpi + register "desc" = ""USB2 Type-C Port C0 (MLB)"" + register "type" = "UPC_TYPE_C_USB2_SS_SWITCH" + register "group" = "ACPI_PLD_GROUP(1, 1)" + device ref usb2_port1 on end + end + chip drivers/usb/acpi + register "desc" = ""USB2 Type-A Port A3 (MLB)"" + register "type" = "UPC_TYPE_A" + register "group" = "ACPI_PLD_GROUP(5, 1)" + device ref usb2_port6 on end + end + chip drivers/usb/acpi + register "desc" = ""USB2 Type-A Port A2 (MLB)"" + register "type" = "UPC_TYPE_A" + register "group" = "ACPI_PLD_GROUP(6, 1)" + device ref usb2_port7 on end + end + chip drivers/usb/acpi + register "desc" = ""USB2 Type-A Port A1 (MLB)"" + register "type" = "UPC_TYPE_A" + register "group" = "ACPI_PLD_GROUP(4, 1)" + device ref usb2_port8 on end + end + chip drivers/usb/acpi + register "desc" = ""USB2 Type-A Port A0 (MLB)"" + register "type" = "UPC_TYPE_A" + register "group" = "ACPI_PLD_GROUP(1, 2)" + device ref usb2_port9 on end + end + chip drivers/usb/acpi + register "desc" = ""USB2 Bluetooth"" + register "type" = "UPC_TYPE_INTERNAL" + register "reset_gpio" = + "ACPI_GPIO_OUTPUT_ACTIVE_LOW(GPP_D4)" + device ref usb2_port10 on end + end + chip drivers/usb/acpi + register "desc" = ""USB3 Type-A Port A0 (MLB)"" + register "type" = "UPC_TYPE_USB3_A" + register "group" = "ACPI_PLD_GROUP(1, 2)" + device ref usb3_port1 on end + end + chip drivers/usb/acpi + register "desc" = ""USB3 Type-A Port A1 (MLB)"" + register "type" = "UPC_TYPE_USB3_A" + register "group" = "ACPI_PLD_GROUP(4, 1)" + device ref usb3_port2 on end + end + chip drivers/usb/acpi + register "desc" = ""USB3 Type-A Port A2 (MLB)"" + register "type" = "UPC_TYPE_USB3_A" + register "group" = "ACPI_PLD_GROUP(6, 1)" + device ref usb3_port3 on end + end + chip drivers/usb/acpi + register "desc" = ""USB3 Type-A Port A3 (MLB)"" + register "type" = "UPC_TYPE_USB3_A" + register "group" = "ACPI_PLD_GROUP(5, 1)" + device ref usb3_port4 on end + end + end + end + end + end end
