Attention is currently required from: Wisley Chen. Hello Wisley Chen,
https://review.coreboot.org/c/coreboot/+/60435
Change subject: mb/google/brya/anahera: Correct WWAN power sequence ......................................................................
Correct the WWAN power sequence to meet spec
BUG=none TEST=build
Signed-off-by: Wisley Chen wisley.chen@quanta.corp-partner.google.com Change-Id: Iab221fd03c637c82f6ce5c8278d432decf1b30c6 --- M src/mainboard/google/brya/Kconfig.name M src/mainboard/google/brya/variants/anahera/gpio.c M src/mainboard/google/brya/variants/anahera/include/variant/gpio.h M src/mainboard/google/brya/variants/anahera4es/gpio.c M src/mainboard/google/brya/variants/anahera4es/include/variant/gpio.h 5 files changed, 40 insertions(+), 2 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/35/60435/1
diff --git a/src/mainboard/google/brya/Kconfig.name b/src/mainboard/google/brya/Kconfig.name index 794bfe7..8bfc61b 100644 --- a/src/mainboard/google/brya/Kconfig.name +++ b/src/mainboard/google/brya/Kconfig.name @@ -117,6 +117,7 @@ select DRIVERS_GENESYSLOGIC_GL9763E select DRIVERS_GFX_GENERIC select SOC_INTEL_ENABLE_USB4_PCIE_RESOURCES + select HAVE_WWAN_POWER_SEQUENCE
config BOARD_GOOGLE_ANAHERA4ES bool "-> Anahera4ES" @@ -124,6 +125,7 @@ select DRIVERS_GENESYSLOGIC_GL9763E select DRIVERS_GFX_GENERIC select SOC_INTEL_ENABLE_USB4_PCIE_RESOURCES + select HAVE_WWAN_POWER_SEQUENCE
config BOARD_GOOGLE_VELL bool "-> Vell" diff --git a/src/mainboard/google/brya/variants/anahera/gpio.c b/src/mainboard/google/brya/variants/anahera/gpio.c index caf23c2..ae83a13 100644 --- a/src/mainboard/google/brya/variants/anahera/gpio.c +++ b/src/mainboard/google/brya/variants/anahera/gpio.c @@ -57,6 +57,8 @@ PAD_NC(GPP_E3, NONE), /* E7 : PROC_GP1 ==> NC */ PAD_NC(GPP_E7, NONE), + /* E16 : RSVD_TP ==> WWAN_RST_L */ + PAD_CFG_GPO(GPP_E16, 1, DEEP), /* F19 : SRCCLKREQ6# ==> EMMC_CLKREQ_ODL */ PAD_CFG_NF(GPP_F19, NONE, DEEP, NF1),
@@ -90,11 +92,17 @@ PAD_NC(GPP_S6, NONE), /* S7 : SNDW3_DATA ==> NC */ PAD_NC(GPP_S7, NONE), - + /* + * E0 : SATAXPCIE0 ==> WWAN_PERST_L + * Drive high here, so that PERST_L is sequenced after RST_L + */ + PAD_CFG_GPO(GPP_E0, 1, DEEP), };
/* Early pad configuration in bootblock */ static const struct pad_config early_gpio_table[] = { + /* A12 : SATAXPCIE1 ==> EN_PPVAR_WWAN */ + PAD_CFG_GPO(GPP_A12, 1, DEEP), /* A13 : PMC_I2C_SCL ==> GSC_PCH_INT_ODL */ PAD_CFG_GPI_APIC(GPP_A13, NONE, PLTRST, LEVEL, INVERT), /* B7 : ISH_12C1_SDA ==> PCH_I2C_TPM_SDA */ @@ -124,6 +132,8 @@ PAD_CFG_GPO(GPP_E16, 0, DEEP), /* F18 : THC1_SPI2_INT# ==> EC_IN_RW_OD */ PAD_CFG_GPI(GPP_F18, NONE, DEEP), + /* F21 : EXT_PWR_GATE2# ==> WWAN_FCPO_L (updated in romstage) */ + PAD_CFG_GPO(GPP_F21, 0, DEEP), /* H10 : UART0_RXD ==> UART_PCH_RX_DBG_TX */ PAD_CFG_NF(GPP_H10, NONE, DEEP, NF2), /* H11 : UART0_TXD ==> UART_PCH_TX_DBG_RX */ @@ -143,6 +153,8 @@ static const struct pad_config romstage_gpio_table[] = { /* B4 : PROC_GP3 ==> SSD_PERST_L */ PAD_CFG_GPO(GPP_B4, 1, DEEP), + /* F21 : EXT_PWR_GATE2# ==> WWAN_FCPO_L (set here for correct power sequencing) */ + PAD_CFG_GPO(GPP_F21, 1, DEEP), };
const struct pad_config *variant_gpio_override_table(size_t *num) diff --git a/src/mainboard/google/brya/variants/anahera/include/variant/gpio.h b/src/mainboard/google/brya/variants/anahera/include/variant/gpio.h index c4fe342..99d09b2 100644 --- a/src/mainboard/google/brya/variants/anahera/include/variant/gpio.h +++ b/src/mainboard/google/brya/variants/anahera/include/variant/gpio.h @@ -5,4 +5,10 @@
#include <baseboard/gpio.h>
+#define WWAN_FCPO GPP_F21 +#define WWAN_RST GPP_E16 +#define WWAN_PERST GPP_E0 +#define T1_OFF_MS 16 +#define T2_OFF_MS 2 + #endif diff --git a/src/mainboard/google/brya/variants/anahera4es/gpio.c b/src/mainboard/google/brya/variants/anahera4es/gpio.c index caf23c2..ae83a13 100644 --- a/src/mainboard/google/brya/variants/anahera4es/gpio.c +++ b/src/mainboard/google/brya/variants/anahera4es/gpio.c @@ -57,6 +57,8 @@ PAD_NC(GPP_E3, NONE), /* E7 : PROC_GP1 ==> NC */ PAD_NC(GPP_E7, NONE), + /* E16 : RSVD_TP ==> WWAN_RST_L */ + PAD_CFG_GPO(GPP_E16, 1, DEEP), /* F19 : SRCCLKREQ6# ==> EMMC_CLKREQ_ODL */ PAD_CFG_NF(GPP_F19, NONE, DEEP, NF1),
const struct pad_config *variant_gpio_override_table(size_t *num) diff --git a/src/mainboard/google/brya/variants/anahera4es/include/variant/gpio.h b/src/mainboard/google/brya/variants/anahera4es/include/variant/gpio.h index c4fe342..99d09b2 100644 --- a/src/mainboard/google/brya/variants/anahera4es/include/variant/gpio.h +++ b/src/mainboard/google/brya/variants/anahera4es/include/variant/gpio.h @@ -5,4 +5,10 @@
