Stefan Reinauer (stefan.reinauer@coreboot.org) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/3212
commit ec3303cb34b5d00441c3d2791a0fb1e120f74baf Author: Stefan Reinauer reinauer@chromium.org Date: Mon May 6 16:49:56 2013 -0700
hardwaremain: drop boot_complete parameter
it has been unused since 9 years or so, hence drop it.
Change-Id: I0706feb7b3f2ada8ecb92176a94f6a8df53eaaa1 Signed-off-by: Stefan Reinauer reinauer@google.com --- src/arch/x86/lib/c_start.S | 9 --------- src/include/bootstate.h | 2 +- src/lib/hardwaremain.c | 12 +++--------- src/mainboard/emulation/qemu-armv7/ramstage.c | 6 ++---- src/mainboard/google/snow/ramstage.c | 8 +++----- src/northbridge/via/vx800/examples/chipset_init.c | 2 +- 6 files changed, 10 insertions(+), 29 deletions(-)
diff --git a/src/arch/x86/lib/c_start.S b/src/arch/x86/lib/c_start.S index 32af0cc..99a4d92 100644 --- a/src/arch/x86/lib/c_start.S +++ b/src/arch/x86/lib/c_start.S @@ -49,12 +49,6 @@ _start: pushl $0 pushl $0
- /* push the boot_complete flag */ - pushl %ebp - - /* Save the stack location */ - movl %esp, %ebp - /* Initialize the Interrupt Descriptor table */ leal _idt, %edi leal vec0, %ebx @@ -80,9 +74,6 @@ _start: */ post_code(POST_PRE_HARDWAREMAIN) /* post fe */
- /* Restore the stack location */ - movl %ebp, %esp - #if CONFIG_GDB_WAIT call gdb_stub_breakpoint #endif diff --git a/src/include/bootstate.h b/src/include/bootstate.h index f732d1e..21bcfbb 100644 --- a/src/include/bootstate.h +++ b/src/include/bootstate.h @@ -157,7 +157,7 @@ int boot_state_sched_on_exit(struct boot_state_callback *bscb, boot_state_t state);
/* Entry into the boot state machine. */ -void hardwaremain(int boot_complete); +void hardwaremain(void);
/* In order to schedule boot state callbacks at compile-time specify the * entries in an array using the BOOT_STATE_INIT_ENTRIES and diff --git a/src/lib/hardwaremain.c b/src/lib/hardwaremain.c index 8e5481e..227e35e 100644 --- a/src/lib/hardwaremain.c +++ b/src/lib/hardwaremain.c @@ -406,7 +406,7 @@ static void boot_state_schedule_static_entries(void) } }
-void hardwaremain(int boot_complete) +void hardwaremain(void) { timestamp_stash(TS_START_RAMSTAGE); post_code(POST_ENTRY_RAMSTAGE); @@ -416,17 +416,11 @@ void hardwaremain(int boot_complete)
post_code(POST_CONSOLE_READY);
- printk(BIOS_NOTICE, "coreboot-%s%s %s %s...\n", - coreboot_version, coreboot_extra_version, coreboot_build, - (boot_complete)?"rebooting":"booting"); + printk(BIOS_NOTICE, "coreboot-%s%s %s booting...\n", + coreboot_version, coreboot_extra_version, coreboot_build);
post_code(POST_CONSOLE_BOOT_MSG);
- /* If we have already booted attempt a hard reboot */ - if (boot_complete) { - hard_reset(); - } - /* Schedule the static boot state entries. */ boot_state_schedule_static_entries();
diff --git a/src/mainboard/emulation/qemu-armv7/ramstage.c b/src/mainboard/emulation/qemu-armv7/ramstage.c index 24d0d7f..5fce9fa 100644 --- a/src/mainboard/emulation/qemu-armv7/ramstage.c +++ b/src/mainboard/emulation/qemu-armv7/ramstage.c @@ -15,10 +15,8 @@
#include <console/console.h>
-void hardwaremain(int boot_complete); +void hardwaremain(void); void main(void) { - console_init(); - printk(BIOS_INFO, "hello from ramstage\n"); - hardwaremain(0); + hardwaremain(); } diff --git a/src/mainboard/google/snow/ramstage.c b/src/mainboard/google/snow/ramstage.c index 09b51a7..72f830d 100644 --- a/src/mainboard/google/snow/ramstage.c +++ b/src/mainboard/google/snow/ramstage.c @@ -77,12 +77,10 @@ void fill_lb_framebuffer(struct lb_framebuffer *framebuffer) }
-void hardwaremain(int boot_complete); +void hardwaremain(void); void main(void) { - console_init(); - printk(BIOS_INFO, - "hello from ramstage; now with deluxe exception handling.\n"); + /* FIXME this should be moved elsewhere. We don't want ramstage.c */
/* set up coreboot tables */ high_tables_size = CONFIG_COREBOOT_TABLES_SIZE; @@ -114,7 +112,7 @@ void main(void)
power_enable_xclkout();
/* TODO: transplanted DP stuff, clean up once we have something that works */ diff --git a/src/northbridge/via/vx800/examples/chipset_init.c b/src/northbridge/via/vx800/examples/chipset_init.c index 1e06d47..d9b85e4 100644 --- a/src/northbridge/via/vx800/examples/chipset_init.c +++ b/src/northbridge/via/vx800/examples/chipset_init.c @@ -604,7 +604,7 @@ void init_VIA_chipset(void) * In the dev_enumerate() phase, */
-void hardwaremain(int boot_complete) +void hardwaremain(void) { struct lb_memory *lb_mem; #if CONFIG_HAVE_ACPI_RESUME
