Karthik Ramasubramanian has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/43279 )
Change subject: mb/google/dedede: Add ability to provide override GPIO table ......................................................................
For variants with slightly different GPIO configuration, add support to pass an override GPIO configuration table.
BUG=None TEST=Build and boot the waddledee mainboard.
Change-Id: I2f1c6dc2ea5499bff96a471c4461339ef01ee19a Signed-off-by: Karthikeyan Ramasubramanian kramasub@google.com --- M src/mainboard/google/dedede/mainboard.c M src/mainboard/google/dedede/variants/baseboard/gpio.c M src/mainboard/google/dedede/variants/baseboard/include/baseboard/variants.h 3 files changed, 17 insertions(+), 6 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/79/43279/1
diff --git a/src/mainboard/google/dedede/mainboard.c b/src/mainboard/google/dedede/mainboard.c index fe89527..cb84e1f 100644 --- a/src/mainboard/google/dedede/mainboard.c +++ b/src/mainboard/google/dedede/mainboard.c @@ -22,11 +22,15 @@
static void mainboard_init(void *chip_info) { - const struct pad_config *pads; - size_t num; + const struct pad_config *base_pads; + const struct pad_config *override_pads; + size_t base_num, override_num;
- pads = variant_gpio_table(&num); - gpio_configure_pads(pads, num); + base_pads = variant_base_gpio_table(&base_num); + override_pads = variant_override_gpio_table(&override_num); + + gpio_configure_pads_with_override(base_pads, base_num, + override_pads, override_num); }
static void mainboard_dev_init(struct device *dev) diff --git a/src/mainboard/google/dedede/variants/baseboard/gpio.c b/src/mainboard/google/dedede/variants/baseboard/gpio.c index 71c0c14..1284bc5 100644 --- a/src/mainboard/google/dedede/variants/baseboard/gpio.c +++ b/src/mainboard/google/dedede/variants/baseboard/gpio.c @@ -420,12 +420,18 @@ PAD_CFG_GPI(GPP_S0, NONE, DEEP), };
-const struct pad_config *__weak variant_gpio_table(size_t *num) +const struct pad_config *__weak variant_base_gpio_table(size_t *num) { *num = ARRAY_SIZE(gpio_table); return gpio_table; }
+const struct pad_config *__weak variant_override_gpio_table(size_t *num) +{ + *num = 0; + return NULL; +} + const struct pad_config *__weak variant_early_gpio_table(size_t *num) { *num = ARRAY_SIZE(early_gpio_table); diff --git a/src/mainboard/google/dedede/variants/baseboard/include/baseboard/variants.h b/src/mainboard/google/dedede/variants/baseboard/include/baseboard/variants.h index 5d8355b..1f40443 100644 --- a/src/mainboard/google/dedede/variants/baseboard/include/baseboard/variants.h +++ b/src/mainboard/google/dedede/variants/baseboard/include/baseboard/variants.h @@ -13,10 +13,11 @@ /* The next set of functions return the gpio table and fill in the number of * entries for each table. */
-const struct pad_config *variant_gpio_table(size_t *num); +const struct pad_config *variant_base_gpio_table(size_t *num); const struct pad_config *variant_early_gpio_table(size_t *num); const struct pad_config *variant_sleep_gpio_table(size_t *num); const struct cros_gpio *variant_cros_gpios(size_t *num); +const struct pad_config *variant_override_gpio_table(size_t *num);
/** * Get board's Hardware features as defined in FW_CONFIG
Furquan Shaikh has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/43279 )
Patch Set 1: Code-Review+2
Tim Wawrzynczak has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/43279 )
https://review.coreboot.org/c/coreboot/+/43279/1/src/mainboard/google/dedede... File src/mainboard/google/dedede/variants/baseboard/gpio.c:
https://review.coreboot.org/c/coreboot/+/43279/1/src/mainboard/google/dedede... PS1, Line 423: __weak nit: I prefer __weak to be at the beginning of the line but I guess that's personal preference, I see it both ways in the codebase.
Patrick Georgi has submitted this change. ( https://review.coreboot.org/c/coreboot/+/43279 )
Change-Id: I2f1c6dc2ea5499bff96a471c4461339ef01ee19a Signed-off-by: Karthikeyan Ramasubramanian kramasub@google.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/43279 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Furquan Shaikh furquan@google.com Reviewed-by: Tim Wawrzynczak twawrzynczak@chromium.org --- M src/mainboard/google/dedede/mainboard.c M src/mainboard/google/dedede/variants/baseboard/gpio.c M src/mainboard/google/dedede/variants/baseboard/include/baseboard/variants.h 3 files changed, 17 insertions(+), 6 deletions(-)
Approvals: build bot (Jenkins): Verified Furquan Shaikh: Looks good to me, approved Tim Wawrzynczak: Looks good to me, approved
