Aaron Durbin (adurbin@chromium.org) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/11172
commit 67beeef7cc61f2617a691bf87a2f103edc77a16f Author: Aaron Durbin adurbin@chromium.org Date: Thu Jul 30 16:52:56 2015 -0500
skylake: fix serial port with new code base
Many Kconfig options changed in coreboot.org since skylake was first started. Fix Kconfig option name changes, and also provide a common option, UART_DEBUG that can be selected to select all the necessary options.
Note: It's still a requirement to manually unset the 8250IO option because that's unconditionally set.
BUG=chrome-os-partner:43419 BUG=chrome-os-partner:43463 BRANCH=None TEST=Built glados. Booted into kernel. Kernel reboots somewhere.
Original-Change-Id: I9e6549ea0f1d6b9ffe64a73856ec87b5bc7b7091 Original-Signed-off-by: Aaron Durbin adurbin@chromium.org Original-Reviewed-on: https://chromium-review.googlesource.com/289951 Original-Reviewed-by: Duncan Laurie dlaurie@chromium.org
Change-Id: I0e6b492d7279cc35d4fb3ac17fd727177adce39d Signed-off-by: Aaron Durbin adurbin@chromium.org --- src/soc/intel/skylake/Kconfig | 12 ++++++--- src/soc/intel/skylake/Makefile.inc | 3 +++ src/soc/intel/skylake/include/soc/iomap.h | 3 +++ src/soc/intel/skylake/romstage/romstage.c | 2 +- src/soc/intel/skylake/romstage/uart.c | 11 ++++++--- src/soc/intel/skylake/uart.c | 9 ++++--- src/soc/intel/skylake/uart_debug.c | 41 +++++++++++++++++++++++++++++++ 7 files changed, 69 insertions(+), 12 deletions(-)
diff --git a/src/soc/intel/skylake/Kconfig b/src/soc/intel/skylake/Kconfig index 92bae39..e2c43f0 100644 --- a/src/soc/intel/skylake/Kconfig +++ b/src/soc/intel/skylake/Kconfig @@ -188,12 +188,16 @@ config SMM_TSEG_SIZE hex default 0x800000
-config TTYS0_BASE - hex - default 0xfe034000 - config VGA_BIOS_ID string default "8086,0406"
+config UART_DEBUG + bool "Enable UART debug port." + default y if CONSOLE_SERIAL + default n + select DRIVERS_UART + select DRIVERS_UART_8250MEM + select DRIVERS_UART_8250MEM_32 + endif diff --git a/src/soc/intel/skylake/Makefile.inc b/src/soc/intel/skylake/Makefile.inc index af299c3..9fa9503 100644 --- a/src/soc/intel/skylake/Makefile.inc +++ b/src/soc/intel/skylake/Makefile.inc @@ -19,6 +19,7 @@ romstage-y += pei_data.c romstage-y += pmutil.c romstage-y += smbus_common.c romstage-y += tsc_freq.c +romstage-$(CONFIG_UART_DEBUG) += uart_debug.c
ramstage-$(CONFIG_HAVE_ACPI_TABLES) += acpi.c ramstage-y += chip.c @@ -46,6 +47,7 @@ ramstage-y += smmrelocate.c ramstage-y += systemagent.c ramstage-y += tsc_freq.c ramstage-y += uart.c +ramstage-$(CONFIG_UART_DEBUG) += uart_debug.c ramstage-y += xhci.c
smm-y += cpu_info.c @@ -57,6 +59,7 @@ smm-y += pmutil.c smm-y += smihandler.c smm-$(CONFIG_SPI_FLASH_SMM) += flash_controller.c smm-y += tsc_freq.c +smm-$(CONFIG_UART_DEBUG) += uart_debug.c
CPPFLAGS_common += -I$(src)/arch/x86/include/ CPPFLAGS_common += -I$(src)/soc/intel/skylake diff --git a/src/soc/intel/skylake/include/soc/iomap.h b/src/soc/intel/skylake/include/soc/iomap.h index c478daf..764e966 100644 --- a/src/soc/intel/skylake/include/soc/iomap.h +++ b/src/soc/intel/skylake/include/soc/iomap.h @@ -27,6 +27,9 @@ #define PCH_PCR_BASE_ADDRESS 0xfd000000 #define PCH_BCR_BASE_SIZE 0x1000000
+#define UART_DEBUG_BASE_ADDRESS 0xfe034000 +#define UART_DEBUG_BASE_SIZE 0x1000 + #define MCH_BASE_ADDRESS 0xfed10000 #define MCH_BASE_SIZE 0x8000
diff --git a/src/soc/intel/skylake/romstage/romstage.c b/src/soc/intel/skylake/romstage/romstage.c index 04ffa3e..af9c78b 100644 --- a/src/soc/intel/skylake/romstage/romstage.c +++ b/src/soc/intel/skylake/romstage/romstage.c @@ -50,7 +50,7 @@ void soc_pre_console_init(struct romstage_params *params) /* System Agent Early Initialization */ systemagent_early_init();
- if (IS_ENABLED(CONFIG_CONSOLE_UART8250MEM_32)) + if (IS_ENABLED(CONFIG_UART_DEBUG)) pch_uart_init(); }
diff --git a/src/soc/intel/skylake/romstage/uart.c b/src/soc/intel/skylake/romstage/uart.c index afc8c63..4dad8f6 100644 --- a/src/soc/intel/skylake/romstage/uart.c +++ b/src/soc/intel/skylake/romstage/uart.c @@ -19,6 +19,7 @@ */
#include <arch/io.h> +#include <console/uart.h> #include <device/pci_def.h> #include <stdint.h> #include <soc/pci_devs.h> @@ -33,7 +34,7 @@ void pch_uart_init(void) { device_t dev = PCH_DEV_UART2; u32 tmp; - u8 *base = (u8 *)CONFIG_TTYS0_BASE; + u8 *base = (void *)uart_platform_base(CONFIG_UART_FOR_CONSOLE);
/* Set configured UART2 base address */ pci_write_config32(dev, PCI_BASE_ADDRESS_0, (u32)base); @@ -49,7 +50,11 @@ void pch_uart_init(void) SIO_REG_PPR_RESETS_IDMA; write32(base + SIO_REG_PPR_RESETS, tmp);
- /* Set M and N divisor inputs and enable clock */ + /* + * Set M and N divisor inputs and enable clock. + * Main reference frequency to UART is: + * 120MHz * M / N = 120MHz * 48 / 3125 = 1843200Hz + */ tmp = read32(base + SIO_REG_PPR_CLOCK); tmp |= SIO_REG_PPR_CLOCK_EN | SIO_REG_PPR_CLOCK_UPDATE | (SIO_REG_PPR_CLOCK_N_DIV << 16) | @@ -57,7 +62,7 @@ void pch_uart_init(void) write32(base + SIO_REG_PPR_CLOCK, tmp);
/* Put UART2 in byte access mode for 16550 compatibility */ - if (!IS_ENABLED(CONFIG_CONSOLE_SERIAL8250MEM_32)) + if (!IS_ENABLED(CONFIG_DRIVERS_UART_8250MEM_32)) pcr_andthenor32(PID_SERIALIO, R_PCH_PCR_SERIAL_IO_GPPRVRW7, 0, SIO_PCH_LEGACY_UART2);
diff --git a/src/soc/intel/skylake/uart.c b/src/soc/intel/skylake/uart.c index 9304118..c93f5c0 100644 --- a/src/soc/intel/skylake/uart.c +++ b/src/soc/intel/skylake/uart.c @@ -18,11 +18,11 @@ * Foundation, Inc. */
-#include <console/uart.h> #include <device/device.h> #include <device/pci.h> #include <device/pci_ids.h> #include <stdlib.h> +#include <soc/iomap.h> #include <soc/pci_devs.h> #include <soc/ramstage.h>
@@ -36,10 +36,11 @@ static void pch_uart_read_resources(struct device *dev) pci_dev_read_resources(dev);
/* Set the configured UART base address for the debug port */ - if (IS_ENABLED(CONFIG_CONSOLE_SERIAL8250MEM_32) && - pch_uart_is_debug(dev)) { + if (IS_ENABLED(CONFIG_UART_DEBUG) && pch_uart_is_debug(dev)) { struct resource *res = find_resource(dev, PCI_BASE_ADDRESS_0); - res->size = 0x1000; + /* Need to set the base and size for the resource allocator. */ + res->base = UART_DEBUG_BASE_ADDRESS; + res->size = UART_DEBUG_BASE_SIZE; res->flags = IORESOURCE_MEM | IORESOURCE_ASSIGNED | IORESOURCE_FIXED; } diff --git a/src/soc/intel/skylake/uart_debug.c b/src/soc/intel/skylake/uart_debug.c new file mode 100644 index 0000000..0328507 --- /dev/null +++ b/src/soc/intel/skylake/uart_debug.c @@ -0,0 +1,41 @@ +/* + * This file is part of the coreboot project. + * + * Copyright 2015 Google Inc. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc. + */ + +#include <stddef.h> +#include <console/uart.h> +#include <soc/iomap.h> +#include <soc/serialio.h> + +unsigned int uart_platform_refclk(void) +{ + /* + * Set M and N divisor inputs and enable clock. + * Main reference frequency to UART is: + * 120MHz * M / N = 120MHz * 48 / 3125 = 1843200Hz + * The different order below is to handle integer math overflow. + */ + return 120 * MHz / SIO_REG_PPR_CLOCK_N_DIV * SIO_REG_PPR_CLOCK_M_DIV; +} + +uintptr_t uart_platform_base(int idx) +{ + /* Same base address for all debug port usage. In reality UART2 + * is currently only supported. */ + return UART_DEBUG_BASE_ADDRESS; +}
