Edward O'Callaghan (eocallaghan@alterapraxis.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/6462
commit 8bc2f8b54de98a735596e875f01192c896027e1b Author: Edward O'Callaghan eocallaghan@alterapraxis.com Date: Sat Aug 2 14:51:30 2014 +1000
cpu/x86/smm/Makefile.inc: Correct SMM linkage under clang builds
Ensure that the SMM build stage links properly using the compiler-rt runtime under a Clang build.
Change-Id: Iead28c46d63f5bbb27757b7dc66fe06b4813d03c Signed-off-by: Edward O'Callaghan eocallaghan@alterapraxis.com --- src/cpu/x86/smm/Makefile.inc | 9 +++++++++ 1 file changed, 9 insertions(+)
diff --git a/src/cpu/x86/smm/Makefile.inc b/src/cpu/x86/smm/Makefile.inc index ff4023b..ef6b80e 100644 --- a/src/cpu/x86/smm/Makefile.inc +++ b/src/cpu/x86/smm/Makefile.inc @@ -83,11 +83,20 @@ endif
smm-y += smihandler.c
+ifeq ($(CONFIG_COMPILER_LLVM_CLANG),y) +$(obj)/cpu/x86/smm/smm.o: $$(smm-objs) $(LIBCLANG_RT_FILE_NAME_smm) + $(LD_smm) -nostdlib -r -o $@ --start-group $(smm-objs) $(LIBCLANG_RT_FILE_NAME_smm) --end-group +else $(obj)/cpu/x86/smm/smm.o: $$(smm-objs) $(LIBGCC_FILE_NAME_smm) $(CC_smm) $(CFLAGS_smm) -nostdlib -r -o $@ -Wl,--wrap,__divdi3 -Wl,--wrap,__udivdi3 -Wl,--wrap,__moddi3 -Wl,--wrap,__umoddi3 -Wl,--start-group $(smm-objs) $(LIBGCC_FILE_NAME_smm) -Wl,--end-group +endif
$(obj)/cpu/x86/smm/smm_wrap: $(obj)/cpu/x86/smm/smm.o $(src)/cpu/x86/smm/$(SMM_LDSCRIPT) $(obj)/ldoptions +ifeq ($(CONFIG_COMPILER_LLVM_CLANG),y) + $(LD_smm) $(SMM_LDFLAGS) -nostdlib -nostartfiles -static -o $(obj)/cpu/x86/smm/smm.elf -T $(src)/cpu/x86/smm/$(SMM_LDSCRIPT) $(obj)/cpu/x86/smm/smm.o +else $(CC_smm) $(CFLAGS_smm) $(SMM_LDFLAGS) -nostdlib -nostartfiles -static -o $(obj)/cpu/x86/smm/smm.elf -T $(src)/cpu/x86/smm/$(SMM_LDSCRIPT) $(obj)/cpu/x86/smm/smm.o +endif $(NM_smm) -n $(obj)/cpu/x86/smm/smm.elf | sort > $(obj)/cpu/x86/smm/smm.map $(OBJCOPY_smm) -O binary $(obj)/cpu/x86/smm/smm.elf $(obj)/cpu/x86/smm/smm
