Aaron Durbin (adurbin@google.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/9436
commit 32e54f40194f76f51ac5fc3dd9b48df5858c5e45 Author: Vadim Bendebury vbendeb@chromium.org Date: Tue Oct 28 18:26:12 2014 -0700
fmap: use CBFS for all other than x86 platforms
The architectiure check in fmap.c is in fact used to delineate between platforms where SPI flash is mapped to memory address space and where it needs to be accessed through CBFS.
In fact cosmos board uses an ARM SOC which also maps SPI flash to processor address space, this will have to be addressed when that SOC's support is introduced, for now let's just presume that all but X86 platforms require CBFS layer to access fmap.
BRANCH=none BUG=chrome-os-partner:31438 TEST=none
Original-Change-Id: Id135dc63278555a7fc5039a568fb28864f7cb8d1 Original-Signed-off-by: Vadim Bendebury vbendeb@chromium.org Original-Reviewed-on: https://chromium-review.googlesource.com/226180 Original-Reviewed-by: Aaron Durbin adurbin@chromium.org
(cherry picked from commit b3c04f84504380066c54a6dec93781a4f25a5fc6) Signed-off-by: Aaron Durbin adurbin@chromium.org
Change-Id: I3a0a70fe583b69b1c9cd8729817bd7062126e1a9 --- src/vendorcode/google/chromeos/fmap.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/src/vendorcode/google/chromeos/fmap.c b/src/vendorcode/google/chromeos/fmap.c index 7c1f626..7c256ce 100644 --- a/src/vendorcode/google/chromeos/fmap.c +++ b/src/vendorcode/google/chromeos/fmap.c @@ -41,7 +41,7 @@ const struct fmap *fmap_find(void) /* wrapping around 0x100000000 */ const struct fmap *fmap = (void *) (CONFIG_FLASHMAP_OFFSET - CONFIG_ROM_SIZE); -#elif CONFIG_ARCH_ARM +#else struct cbfs_media default_media, *media; media = &default_media; init_default_cbfs_media(media);
