Attention is currently required from: EricR Lai. Hello build bot (Jenkins), Tim Wawrzynczak,
https://review.coreboot.org/c/coreboot/+/59385
Change subject: mb/google/brya/var/felwinter: Correct USB3 TCSS setting ......................................................................
Based on Intel Kit#615686, USB3 only needs to disable TBT and DMA per port. And if uses USB3 directly you need to set TcssAuxOri accordingly.
BUG=b:206716691,b:205235144 TEST=USB function work as expected at USB3 only sku.
Signed-off-by: Eric Lai ericr_lai@compal.corp-partner.google.com Change-Id: I303d042d6c80194ff48130fe4e9c04b49ca13ee8 --- M src/mainboard/google/brya/variants/felwinter/overridetree.cb M src/mainboard/google/brya/variants/felwinter/variant.c 2 files changed, 10 insertions(+), 3 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/85/59385/4
