Eric Lai has submitted this change. ( https://review.coreboot.org/c/coreboot/+/74625 )
Change subject: mb/google/nissa/var/yavilla: Update devicetree based on FW_CONFIG ......................................................................
Update devicetree -Enable USB2 port5 for WWAN -Update OVTI8856 setting -Update USB2/3 Type-A 0/1 port location
Probe devicetree based on FW_CONFIG -pen garage -rear mipi cam -USB WWAN
BUG=b:273791621, b:276369170 BRANCH=firmware-nissa-15217.B TEST=emerge-nissa coreboot
Change-Id: I6cc7be2309483ce016bde57db34af078bd4d46b0 Signed-off-by: Tony Huang tony-huang@quanta.corp-partner.google.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/74625 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Derek Huang derekhuang@google.com --- M src/mainboard/google/brya/variants/yavilla/overridetree.cb 1 file changed, 88 insertions(+), 16 deletions(-)
Approvals: build bot (Jenkins): Verified Derek Huang: Looks good to me, approved
diff --git a/src/mainboard/google/brya/variants/yavilla/overridetree.cb b/src/mainboard/google/brya/variants/yavilla/overridetree.cb index e3d3cac..f7798e7 100644 --- a/src/mainboard/google/brya/variants/yavilla/overridetree.cb +++ b/src/mainboard/google/brya/variants/yavilla/overridetree.cb @@ -1,3 +1,35 @@ +fw_config + field DB_USB 0 1 + option DB_NONE 0 + option DB_1C_1A 1 + option DB_1C 2 + option DB_1C_LTE 3 + end + field WIFI_SAR_ID 2 3 + option SAR_ID_0 0 + end + field STYLUS 9 + option STYLUS_ABSENT 0 + option STYLUS_PRESENT 1 + end + field SD_CARD 10 + option SD_PRESENT 0 + option SD_ABSENT 1 + end + field WFC 11 + option WFC_ABSENT 0 + option WFC_MIPI_OVTI8856 1 + end + field MB_HDMI 12 + option HDMI_ABSENT 0 + option HDMI_PRESENT 1 + end + field MB_USB 15 + option MB_1C 0 + option MB_1C_2A 1 + end +end + chip soc/intel/alderlake register "sagv" = "SaGv_Enabled"
@@ -8,7 +40,7 @@
register "typec_aux_bias_pads[0]" = "{.pad_auxp_dc = GPP_E22, .pad_auxn_dc = GPP_E23}"
- register "usb2_ports[6]" = "USB2_PORT_MID(OC_SKIP)" # USB2 WWAN + register "usb2_ports[4]" = "USB2_PORT_MID(OC_SKIP)" # USB2 WWAN register "usb2_ports[7]" = "USB2_PORT_MID(OC_SKIP)" # Bluetooth port for PCIe WLAN register "usb2_ports[9]" = "USB2_PORT_MID(OC_SKIP)" # Bluetooth port for CNVi WLAN
@@ -110,11 +142,12 @@ register "device_type" = "INTEL_ACPI_CAMERA_CIO2"
register "cio2_num_ports" = "1" - register "cio2_lanes_used" = "{2}" # 2 CSI Camera lanes are used + register "cio2_lanes_used" = "{4}" # 4 CSI Camera lanes are used register "cio2_lane_endpoint[0]" = ""^I2C2.CAM0"" register "cio2_prt[0]" = "1" device generic 0 on end end + probe WFC WFC_MIPI_OVTI8856 end device ref cnvi_wifi on chip drivers/wifi/generic @@ -150,7 +183,9 @@ register "key.linux_code" = "SW_PEN_INSERTED" register "key.linux_input_type" = "EV_SW" register "key.label" = ""pen_eject"" - device generic 0 on end + device generic 0 on + probe STYLUS STYLUS_PRESENT + end end end device ref i2c2 on @@ -162,13 +197,13 @@ register "device_type" = "INTEL_ACPI_CAMERA_SENSOR" register "has_power_resource" = "1"
- register "ssdb.lanes_used" = "2" + register "ssdb.lanes_used" = "4" register "ssdb.link_used" = "1" register "ssdb.vcm_type" = "0x0C" register "vcm_name" = ""VCM0"" register "num_freq_entries" = "2" - register "link_freq[0]" = "720000000" - register "link_freq[1]" = "360000000" + register "link_freq[0]" = "360000000" + register "link_freq[1]" = "180000000" register "remote_name" = ""IPU0""
#Controls @@ -194,7 +229,9 @@ register "off_seq.ops[2]" = "SEQ_OPS_GPIO_DISABLE(1, 0)" register "off_seq.ops[3]" = "SEQ_OPS_GPIO_DISABLE(0, 0)"
- device i2c 10 on end + device i2c 36 on + probe WFC WFC_MIPI_OVTI8856 + end end chip drivers/intel/mipi_camera register "acpi_uid" = "3" @@ -205,7 +242,9 @@ register "pr0" = ""\_SB.PCI0.I2C2.CAM0.PRIC"" register "vcm_compat" = ""dongwoon,dw9714""
- device i2c 0C on end + device i2c 0C on + probe WFC WFC_MIPI_OVTI8856 + end end chip drivers/intel/mipi_camera register "acpi_hid" = "ACPI_DT_NAMESPACE_HID" @@ -222,7 +261,9 @@ register "nvm_width" = "0x10" register "nvm_compat" = ""atmel,24c08""
- device i2c 50 on end + device i2c 50 on + probe WFC WFC_MIPI_OVTI8856 + end end end device ref i2c3 on @@ -353,20 +394,22 @@ register "desc" = ""USB2 Type-A Port A0 (MLB)"" register "type" = "UPC_TYPE_A" register "use_custom_pld" = "true" - register "custom_pld" = "ACPI_PLD_TYPE_A(LEFT, RIGHT, ACPI_PLD_GROUP(3, 1))" + register "custom_pld" = "ACPI_PLD_TYPE_A(RIGHT, RIGHT, ACPI_PLD_GROUP(3, 1))" device ref usb2_port3 on end end chip drivers/usb/acpi - register "desc" = ""USB2 Type-A Port A1 (DB)"" + register "desc" = ""USB2 Type-A Port A1 (MLB)"" register "type" = "UPC_TYPE_A" register "use_custom_pld" = "true" - register "custom_pld" = "ACPI_PLD_TYPE_A(RIGHT, RIGHT, ACPI_PLD_GROUP(4, 1))" + register "custom_pld" = "ACPI_PLD_TYPE_A(RIGHT, LEFT, ACPI_PLD_GROUP(4, 1))" device ref usb2_port4 on end end chip drivers/usb/acpi register "desc" = ""USB2 WWAN"" register "type" = "UPC_TYPE_INTERNAL" - device ref usb2_port5 on end + device ref usb2_port5 on + probe DB_USB DB_1C_LTE + end end chip drivers/usb/acpi register "desc" = ""USB2 UFC"" @@ -391,20 +434,22 @@ register "desc" = ""USB3 Type-A Port A0 (MLB)"" register "type" = "UPC_TYPE_USB3_A" register "use_custom_pld" = "true" - register "custom_pld" = "ACPI_PLD_TYPE_A(LEFT, RIGHT, ACPI_PLD_GROUP(3, 1))" + register "custom_pld" = "ACPI_PLD_TYPE_A(RIGHT, RIGHT, ACPI_PLD_GROUP(3, 1))" device ref usb3_port1 on end end chip drivers/usb/acpi register "desc" = ""USB3 Type-A Port A1 (DB)"" register "type" = "UPC_TYPE_USB3_A" register "use_custom_pld" = "true" - register "custom_pld" = "ACPI_PLD_TYPE_A(RIGHT, RIGHT, ACPI_PLD_GROUP(4, 1))" + register "custom_pld" = "ACPI_PLD_TYPE_A(RIGHT, LEFT, ACPI_PLD_GROUP(4, 1))" device ref usb3_port2 on end end chip drivers/usb/acpi register "desc" = ""USB3 WWAN"" register "type" = "UPC_TYPE_INTERNAL" - device ref usb3_port3 on end + device ref usb3_port3 on + probe DB_USB DB_1C_LTE + end end end end
