Naman Govil (namangov@gmail.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/10674
commit ad10786c7af498e12f6dfe15391177919d083a30 Author: Naman Govil namangov@gmail.com Date: Thu Dec 25 11:10:15 2014 +0800
arm64: fix cpu_set_bsp() error
src/arch/arm64/c_entry.c: In function 'arm64_init': src/arch/arm64/c_entry.c:52:2: error: implicit declaration of function 'cpu_set_bsp' [-Werror=implicit-function-declaration] cpu_set_bsp(); ^
BUG=none TEST=emerge-oak coreboot BRANCH=none Taken from Change 257370 Chromium tree by HC Yen hc.yen@mediatek.com https://chromium-review.googlesource.com/#/c/257370/ Change-Id: Iecb413d1496f45e84c7856340656c5327d885454 Signed-off-by: Naman Govil namangov@gmail.com --- src/arch/arm64/c_entry.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/src/arch/arm64/c_entry.c b/src/arch/arm64/c_entry.c index d51bfcc..a4d4773 100644 --- a/src/arch/arm64/c_entry.c +++ b/src/arch/arm64/c_entry.c @@ -49,7 +49,9 @@ static void seed_stack(void)
static void arm64_init(void) { +#if !defined(__PRE_RAM__) cpu_set_bsp(); +#endif seed_stack(); arm64_soc_init(); main();
