Lee Leahy (leroy.p.leahy@intel.com) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/16001
commit 7efd4deebf9c5fa6702484dd4c9333e06e794748 Author: Lee Leahy leroy.p.leahy@intel.com Date: Sun Jul 31 11:53:28 2016 -0700
arch/x86: Enable postcar console
Add a Kconfig value to enable the console during postcar. Add a call to console_init at the beginning of the postcar stage in exit_car.S.
Change-Id: I66e2ec83344129ede2c7d6e5627c8062e28f50ad Signed-off-by: Lee Leahy leroy.p.leahy@intel.com --- src/arch/x86/exit_car.S | 5 +++++ src/console/Kconfig | 7 +++++++ src/console/init.c | 2 +- src/include/console/console.h | 3 ++- 4 files changed, 15 insertions(+), 2 deletions(-)
diff --git a/src/arch/x86/exit_car.S b/src/arch/x86/exit_car.S index a51d662..13c2390 100644 --- a/src/arch/x86/exit_car.S +++ b/src/arch/x86/exit_car.S @@ -26,6 +26,11 @@ stack_top: .text .global _start _start: +#if IS_ENABLED(CONFIG_POSTCAR_CONSOLE) + /* Enable the console */ + call console_init +#endif /* CONFIG_POSTCAR_CONSOLE */ + /* chipset_teardown_car() is expected to disable cache-as-ram. */ call chipset_teardown_car
diff --git a/src/console/Kconfig b/src/console/Kconfig index 90fb426..e945c25 100644 --- a/src/console/Kconfig +++ b/src/console/Kconfig @@ -7,6 +7,13 @@ config BOOTBLOCK_CONSOLE help Use console during the bootblock if supported
+config POSTCAR_CONSOLE + bool "Enable console output during postcar." + depends on POSTCAR_STAGE + default n + help + Use console during the postcar if supported + config SQUELCH_EARLY_SMP bool "Squelch AP CPUs from early console." default y diff --git a/src/console/init.c b/src/console/init.c index 8f40abb..189079b 100644 --- a/src/console/init.c +++ b/src/console/init.c @@ -30,7 +30,7 @@ int console_log_level(int msg_level) return (console_loglevel >= msg_level); }
-void console_init(void) +asmlinkage void console_init(void) { #if !defined(__PRE_RAM__) console_loglevel = CONFIG_DEFAULT_CONSOLE_LOGLEVEL; diff --git a/src/include/console/console.h b/src/include/console/console.h index ddb5c052..dcd5fe9 100644 --- a/src/include/console/console.h +++ b/src/include/console/console.h @@ -18,6 +18,7 @@
#include <stdint.h> #include <rules.h> +#include <arch/cpu.h> #include <console/post_codes.h> #include <commonlib/loglevel.h>
@@ -51,7 +52,7 @@ void __attribute__ ((noreturn)) die(const char *msg); (ENV_SMM && CONFIG_DEBUG_SMI))
#if __CONSOLE_ENABLE__ -void console_init(void); +asmlinkage void console_init(void); int console_log_level(int msg_level); int do_printk(int msg_level, const char *fmt, ...) __attribute__((format(printf, 2, 3))); void do_putchar(unsigned char byte);
