Attention is currently required from: Kapil Porwal, Pranava Y N, Subrata Banik.
Hello Kapil Porwal, Pranava Y N, Subrata Banik,
https://review.coreboot.org/c/coreboot/+/84410?usp=email
Change subject: soc/intel/ptl: Add GPE1 support in pmutil.c ......................................................................
This change is to add the required GPE1 override functions for PTL. The override functions are called in Intel common pmclib.c. NOTE that GPE1 bits are SOC-specific and they are related to GPE0 events.
1. When CONFIG_SOC_INTEL_COMMON_BLOCK_ACPI_HAVE_GPE1 is set, the SOC GPE1 override functions soc_pmc_disable_std_gpe1() and soc_pmc_enable_std_gpe1() are required in order to configure GPE1 bits properly according to the corresponding GPE0 bits. 2. The mapping for GPE1 bits to their readable string is also provided
BUG=b:362310295 TEST=This cannot be tested directly. Build with CONFIG_SOC_INTEL_COMMON_BLOCK_ACPI_HAVE_GPE1 in google/fatcat or inte/ptlrvp. Boot to OS, Check both GPE0 and GPE1 EN bits.
Signed-off-by: Cliff Huang cliff.huang@intel.com Change-Id: Ia79c49d399eff4b2f6978323b2f5e2bb167d8638 --- M src/soc/intel/pantherlake/pmutil.c 1 file changed, 112 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/10/84410/2
