David Wu has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/60766 )
Change subject: mb/google/brya: Create volmar variant ......................................................................
Create the volmar variant of the brya0 reference board by copying the template files to a new directory named for the variant.
(Auto-Generated by create_coreboot_variant.sh version 4.5.0).
BUG=b:213127419 BRANCH=None TEST=util/abuild/abuild -p none -t google/brya -x -a make sure the build includes GOOGLE_VOLMAR
Signed-off-by: David Wu david_wu@quanta.corp-partner.google.com Change-Id: I5ebf62b7a17b075c0e28fb4e8b7c501fc8db3ea3 --- M src/mainboard/google/brya/Kconfig M src/mainboard/google/brya/Kconfig.name A src/mainboard/google/brya/variants/volmar/include/variant/ec.h A src/mainboard/google/brya/variants/volmar/include/variant/gpio.h A src/mainboard/google/brya/variants/volmar/memory/Makefile.inc A src/mainboard/google/brya/variants/volmar/memory/dram_id.generated.txt A src/mainboard/google/brya/variants/volmar/memory/mem_parts_used.txt A src/mainboard/google/brya/variants/volmar/overridetree.cb 8 files changed, 46 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/66/60766/1
diff --git a/src/mainboard/google/brya/Kconfig b/src/mainboard/google/brya/Kconfig index 5169324..c9b335a 100644 --- a/src/mainboard/google/brya/Kconfig +++ b/src/mainboard/google/brya/Kconfig @@ -104,6 +104,7 @@ default 0x3 if BOARD_GOOGLE_TANIKS default 0x0 if BOARD_GOOGLE_NIVVIKS default 0x0 if BOARD_GOOGLE_NEREID + default 0x1 if BOARD_GOOGLE_VOLMAR
config DRIVER_TPM_I2C_ADDR hex @@ -145,6 +146,7 @@ default "Taniks" if BOARD_GOOGLE_TANIKS default "Nivviks" if BOARD_GOOGLE_NIVVIKS default "Nereid" if BOARD_GOOGLE_NEREID + default "Volmar" if BOARD_GOOGLE_VOLMAR
config VARIANT_DIR default "brya0" if BOARD_GOOGLE_BRYA0 @@ -166,6 +168,7 @@ default "taniks" if BOARD_GOOGLE_TANIKS default "nivviks" if BOARD_GOOGLE_NIVVIKS default "nereid" if BOARD_GOOGLE_NEREID + default "volmar" if BOARD_GOOGLE_VOLMAR
config VBOOT select VBOOT_EARLY_EC_SYNC diff --git a/src/mainboard/google/brya/Kconfig.name b/src/mainboard/google/brya/Kconfig.name index e2a4a9e..739d6a5 100644 --- a/src/mainboard/google/brya/Kconfig.name +++ b/src/mainboard/google/brya/Kconfig.name @@ -143,3 +143,7 @@ config BOARD_GOOGLE_NEREID bool "-> Nereid" select BOARD_GOOGLE_BASEBOARD_NISSA + +config BOARD_GOOGLE_VOLMAR + bool "-> Volmar" + select BOARD_GOOGLE_BASEBOARD_BRYA diff --git a/src/mainboard/google/brya/variants/volmar/include/variant/ec.h b/src/mainboard/google/brya/variants/volmar/include/variant/ec.h new file mode 100644 index 0000000..7a2a6ff --- /dev/null +++ b/src/mainboard/google/brya/variants/volmar/include/variant/ec.h @@ -0,0 +1,8 @@ +/* SPDX-License-Identifier: GPL-2.0-or-later */ + +#ifndef __VARIANT_EC_H__ +#define __VARIANT_EC_H__ + +#include <baseboard/ec.h> + +#endif diff --git a/src/mainboard/google/brya/variants/volmar/include/variant/gpio.h b/src/mainboard/google/brya/variants/volmar/include/variant/gpio.h new file mode 100644 index 0000000..c4fe342 --- /dev/null +++ b/src/mainboard/google/brya/variants/volmar/include/variant/gpio.h @@ -0,0 +1,8 @@ +/* SPDX-License-Identifier: GPL-2.0-or-later */ + +#ifndef VARIANT_GPIO_H +#define VARIANT_GPIO_H + +#include <baseboard/gpio.h> + +#endif diff --git a/src/mainboard/google/brya/variants/volmar/memory/Makefile.inc b/src/mainboard/google/brya/variants/volmar/memory/Makefile.inc new file mode 100644 index 0000000..eace2e4 --- /dev/null +++ b/src/mainboard/google/brya/variants/volmar/memory/Makefile.inc @@ -0,0 +1,5 @@ +# SPDX-License-Identifier: GPL-2.0-or-later +# This is an auto-generated file. Do not edit!! +# Add memory parts in mem_parts_used.txt and run spd_tools to regenerate. + +SPD_SOURCES = placeholder diff --git a/src/mainboard/google/brya/variants/volmar/memory/dram_id.generated.txt b/src/mainboard/google/brya/variants/volmar/memory/dram_id.generated.txt new file mode 100644 index 0000000..fa24790 --- /dev/null +++ b/src/mainboard/google/brya/variants/volmar/memory/dram_id.generated.txt @@ -0,0 +1 @@ +DRAM Part Name ID to assign diff --git a/src/mainboard/google/brya/variants/volmar/memory/mem_parts_used.txt b/src/mainboard/google/brya/variants/volmar/memory/mem_parts_used.txt new file mode 100644 index 0000000..9621137 --- /dev/null +++ b/src/mainboard/google/brya/variants/volmar/memory/mem_parts_used.txt @@ -0,0 +1,11 @@ +# This is a CSV file containing a list of memory parts used by this variant. +# One part per line with an optional fixed ID in column 2. +# Only include a fixed ID if it is required for legacy reasons! +# Generated IDs are dependent on the order of parts in this file, +# so new parts must always be added at the end of the file! +# +# Generate an updated Makefile.inc and dram_id.generated.txt by running the +# part_id_gen tool from util/spd_tools. +# See util/spd_tools/README.md for more details and instructions. + +# Part Name diff --git a/src/mainboard/google/brya/variants/volmar/overridetree.cb b/src/mainboard/google/brya/variants/volmar/overridetree.cb new file mode 100644 index 0000000..4f2c04a --- /dev/null +++ b/src/mainboard/google/brya/variants/volmar/overridetree.cb @@ -0,0 +1,6 @@ +chip soc/intel/alderlake + + device domain 0 on + end + +end
