Edward O'Callaghan (eocallaghan@alterapraxis.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/5509
commit abe920cd3b6a790162f5c65d13e891fc891c6fcb Author: Edward O'Callaghan eocallaghan@alterapraxis.com Date: Tue Apr 15 20:45:13 2014 +1000
jetway/nf81-t56n-lf: Move pc80 driver from rom to ram stage
NOTFORMERGE
Avoid #including .c files from pc80 driver by migrating i825{4,9} init's from romstage to ramstage.
Change-Id: I4cd87317fb44cd2bda09f3df1c0635cdc87943e2 Signed-off-by: Edward O'Callaghan eocallaghan@alterapraxis.com --- src/mainboard/jetway/nf81-t56n-lf/mainboard.c | 11 +++++++++++ src/mainboard/jetway/nf81-t56n-lf/romstage.c | 13 ++----------- 2 files changed, 13 insertions(+), 11 deletions(-)
diff --git a/src/mainboard/jetway/nf81-t56n-lf/mainboard.c b/src/mainboard/jetway/nf81-t56n-lf/mainboard.c index b3c9e3d..7904a01 100644 --- a/src/mainboard/jetway/nf81-t56n-lf/mainboard.c +++ b/src/mainboard/jetway/nf81-t56n-lf/mainboard.c @@ -31,6 +31,9 @@ #include <southbridge/amd/cimx/sb800/SBPLATFORM.h> #include <southbridge/amd/sb800/sb800.h>
+#include <pc80/i8254.h> +#include <pc80/i8259.h> + void set_pcie_reset(void); void set_pcie_dereset(void);
@@ -58,6 +61,14 @@ static void mainboard_enable(device_t dev) { printk(BIOS_INFO, "Mainboard " CONFIG_MAINBOARD_PART_NUMBER " Enable.\n");
+ /* Initialize i8259 pic */ + post_code(0x43); + setup_i8259 (); + + /* Initialize i8254 timers */ + post_code(0x44); + setup_i8254 (); + /* * The mainboard is the first place that we get control in ramstage. Check * for S3 resume and call the approriate AGESA/CIMx resume functions. diff --git a/src/mainboard/jetway/nf81-t56n-lf/romstage.c b/src/mainboard/jetway/nf81-t56n-lf/romstage.c index 3406edf..7ee20c3 100644 --- a/src/mainboard/jetway/nf81-t56n-lf/romstage.c +++ b/src/mainboard/jetway/nf81-t56n-lf/romstage.c @@ -42,9 +42,8 @@ #include <southbridge/amd/cimx/sb800/SBPLATFORM.h> #include "superio/fintek/f71869ad/f71869ad.h"
-/* FIXME: should not include .c files */ -#include "drivers/pc80/i8254.c" -#include "drivers/pc80/i8259.c" +#include <pc80/i8254.h> +#include <pc80/i8259.h>
void disable_cache_as_ram(void); /* cache_as_ram.inc */ void cache_as_ram_main(unsigned long bist, unsigned long cpu_init_detectedx); @@ -175,14 +174,6 @@ void cache_as_ram_main(unsigned long bist, unsigned long cpu_init_detectedx) } #endif /* CONFIG_HAVE_ACPI_RESUME */
- /* Initialize i8259 pic */ - post_code(0x43); - setup_i8259 (); - - /* Initialize i8254 timers */ - post_code(0x44); - setup_i8254 (); - post_code(0x50); copy_and_run(); printk(BIOS_ERR, "Error: copy_and_run() returned!\n");
