Arthur Heymans has submitted this change. ( https://review.coreboot.org/c/coreboot/+/65422?usp=email )
10 is the latest approved patch-set. No files were changed between the latest approved patch-set and the submitted one. )Change subject: allocator_v4: Manually inline some thin functions ......................................................................
Inline functions that are only called once to improve readability. The calling functions still have rather short bodies, and the reader won't have to look down yet another layer to understand what they are doing.
Change-Id: Ib4aa5d61dfa88c804a1aaee028185e00c5fbb923 Signed-off-by: Nico Huber nico.h@gmx.de Reviewed-on: https://review.coreboot.org/c/coreboot/+/65422 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Felix Singer service+coreboot-gerrit@felixsinger.de Reviewed-by: Arthur Heymans arthur@aheymans.xyz --- M src/device/resource_allocator_v4.c 1 file changed, 22 insertions(+), 46 deletions(-)
Approvals: Felix Singer: Looks good to me, but someone else must approve build bot (Jenkins): Verified Arthur Heymans: Looks good to me, approved
diff --git a/src/device/resource_allocator_v4.c b/src/device/resource_allocator_v4.c index d17499c..fb0320a 100644 --- a/src/device/resource_allocator_v4.c +++ b/src/device/resource_allocator_v4.c @@ -268,27 +268,6 @@ } }
-static unsigned char get_alignment_by_resource_type(const unsigned long type) -{ - if (type & IORESOURCE_MEM) - return 12; /* Page-aligned --> log2(4KiB) */ - else if (type & IORESOURCE_IO) - return 0; /* No special alignment required --> log2(1) */ - - die("Unexpected resource type: flags(%lu)!\n", type); -} - -static void update_constraints(struct memranges *ranges, const struct device *dev, - const struct resource *res) -{ - if (!res->size) - return; - - print_fixed_res(dev, res, __func__); - - memranges_create_hole(ranges, res->base, res->size); -} - /* * Scan the entire tree to identify any fixed resources allocated by * any device to ensure that the address map for domain resources are @@ -310,7 +289,10 @@ for (res = dev->resource_list; res != NULL; res = res->next) { if ((res->flags & mask_match) != mask_match) continue; - update_constraints(ranges, dev, res); + if (!res->size) + continue; + print_fixed_res(dev, res, __func__); + memranges_create_hole(ranges, res->base, res->size); }
bus = dev->link_list; @@ -321,28 +303,6 @@ avoid_fixed_resources(ranges, child, mask_match); }
-static void constrain_domain_resources(const struct device *domain, struct memranges *ranges, - unsigned long type) -{ - unsigned long mask_match = type | IORESOURCE_FIXED; - - if (type == IORESOURCE_IO) { - /* - * Don't allow allocations in the VGA I/O range. PCI has special - * cases for that. - */ - memranges_create_hole(ranges, 0x3b0, 0x3df - 0x3b0 + 1); - - /* - * Resource allocator no longer supports the legacy behavior where - * I/O resource allocation is guaranteed to avoid aliases over legacy - * PCI expansion card addresses. - */ - } - - avoid_fixed_resources(ranges, domain, mask_match); -} - /* * This function creates a list of memranges of given type using the * resource that is provided. It applies additional constraints to @@ -356,8 +316,10 @@ const unsigned long type, struct memranges *const ranges) { + /* Align mem resources to 2^12 (4KiB pages) at a minimum, so they + can be memory-mapped individually (e.g. for virtualization guests). */ + const unsigned char alignment = type == IORESOURCE_MEM ? 12 : 0; const unsigned long type_mask = IORESOURCE_TYPE_MASK | IORESOURCE_FIXED; - const unsigned char alignment = get_alignment_by_resource_type(type);
memranges_init_empty_with_alignment(ranges, NULL, 0, alignment);
@@ -368,7 +330,21 @@ memranges_insert(ranges, res->base, res->limit - res->base + 1, type); }
- constrain_domain_resources(domain, ranges, type); + if (type == IORESOURCE_IO) { + /* + * Don't allow allocations in the VGA I/O range. PCI has special + * cases for that. + */ + memranges_create_hole(ranges, 0x3b0, 0x3df - 0x3b0 + 1); + + /* + * Resource allocator no longer supports the legacy behavior where + * I/O resource allocation is guaranteed to avoid aliases over legacy + * PCI expansion card addresses. + */ + } + + avoid_fixed_resources(ranges, domain, type | IORESOURCE_FIXED);
print_resource_ranges(domain, ranges); }
