Leroy P Leahy (leroy.p.leahy@intel.com) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/13717
commit e77d2c31d367342e9e8eacbeff371651c2def85e Author: Lee Leahy leroy.p.leahy@intel.com Date: Wed Feb 10 11:12:50 2016 -0800
Documentation: x86 add EDK2 CorebootPayloadPkg and documentation links
Add EDK2 CorebootPayloadPkg build instructions, EDK2 documentation links and EDK2 BIOS build instructions.
TEST=None
Change-Id: I236405914c5fa8e33a7826cc4fa60f6dbf0e7724 Signed-off-by: Lee Leahy leroy.p.leahy@intel.com --- Documentation/Intel/SoC/quark.html | 120 +++++++++++++++++++++++++++++++++---- 1 file changed, 107 insertions(+), 13 deletions(-)
diff --git a/Documentation/Intel/SoC/quark.html b/Documentation/Intel/SoC/quark.html index e8b6c85..bd32b24 100644 --- a/Documentation/Intel/SoC/quark.html +++ b/Documentation/Intel/SoC/quark.html @@ -47,42 +47,136 @@
<hr> -<h1>Quark™ FSP</h1> -<ul> - <li>Intel® Firmware Support Package External Architecture Specification <a target="_blank" href="http://www.intel.com/content/dam/www/public/us/en/documents/technical-specifications/fsp-architecture-spec-v1-1.pdf">V1.1</a></li> - <li>Intel® Quark™ SoC X1000 <a target="_blank" href="http://www.intel.com/content/dam/www/public/us/en/documents/guides/quark-x1000-uefi-firmware-writers-guide.pdf">UEFI Firmware Writer's Guide</a></li> - <li>EDK2 Sources: +<h1>Quark™ EDK2 CorebootPayloadPkg</h1> +<p> +Build Instructions: +</p> +<ol> + <li>Set up <a href="#BuildEnvironment">build environment</a></li> + <li>Build Instructions: + <ul> + <li>Linux: +<pre><code>build -p CorebootPayloadPkg/CorebootPayloadPkgIa32.dsc -a IA32 -t GCC48 -b DEBUG -DDEBUG_PROPERTY_MASK=0x27 -DDEBUG_PRINT_ERROR_LEVEL=0x80000042 +ls Build/CorebootPayloadPkg/DEBUG_GCC48/FV/UEFIPAYLOAD.fd +</code></pre> + </li> + <li>Windows: +<pre><code>build -p CorebootPayloadPkg\CorebootPayloadPkgIa32.dsc -a IA32 -t VS2012x86 -b DEBUG -DDEBUG_PROPERTY_MASK=0x27 -DDEBUG_PRINT_ERROR_LEVEL=0x80000042 +dir Build\CorebootPayloadPkg\DEBUG_VS2012x86\FV\UEFIPAYLOAD.fd +</code></pre> + </li> + </ul> + </li> + <li>Set the following Kconfig values: <ul> + <li>CONFIG_PAYLOAD_ELF=y</li> + <li>CONFIG_PAYLOAD_FILE="path to UEFIPAYLOAD.fd"</li> + </ul> + </li> + <li>Build coreboot</li> + <li>Copy the image build/coreboot.rom into flash</li> +</ol> + + + +<hr> +<h1><a name="BuildEnvironment">Quark™ EDK2 Build Environment</a></h1> +<p> + Use the following steps to setup a build environment: +</p> +<ol> + <li>Get the EDK2 sources: + <ol type="A"> <li>EDK2: git clone <a target="_blank" href="https://github.com/tianocore/edk2.git">https://github.com/tianocore/edk2.git</a></li> <li>EDK2-FatPkg: git clone <a target="_blank" href="https://github.com/tianocore/edk2-FatPkg.git">https://github.com/tianocore/edk2-FatPkg.git</a> FatPkg</li> <li>EDK2-non-osi: git clone <a target="_blank" href="https://github.com/tianocore/edk2-non-osi.git">https://github.com/tianocore/edk2-non-osi.git</a></li> <li>Win32 BaseTools: git clone <a target="_blank" href="https://github.com/tianocore/edk2-BaseTools-win32.git">https://github.com/tianocore/edk2-BaseTools-win32.git</a></li> - </ul> + </ol> </li> - <li>Linux Build Instructions: + <li>Set up a build window: + <ul> + <li>Linux: <pre><code>export WORKSPACE=$PWD export PACKAGES_PATH="$PWD/edk2:$PWD/FatPkg:$PWD/edk2-non-osi" cd edk2 export WORKSPACE=$PWD . edksetup.sh -build -p QuarkPlatformPkg/Quark.dsc -a IA32 -t GCC48 -b DEBUG -DDEBUG_PROPERTY_MASK=0x27 -DDEBUG_PRINT_ERROR_LEVEL=0x80000042 -ls Build/Quark/DEBUG_GCC48/FV/QUARK.fd </code></pre> - </li> - <li>Win32 Build Instructions: + </li> + <li>Windows: <pre><code>set WORKSPACE=%CD% set PACKAGES_PATH=%WORKSPACE%\edk2;%WORKSPACE%\FatPkg;%WORKSPACE%\edk2-non-osi set EDK_TOOLS_BIN=%WORKSPACE%\edk2-BaseTools-win32 cd edk2 edksetup.bat -build -p QuarkPlatformPkg/Quark.dsc -a IA32 -t VS2012x86 -b DEBUG -DDEBUG_PROPERTY_MASK=0x27 -DDEBUG_PRINT_ERROR_LEVEL=0x80000042 </code></pre> + </li> + </ul> + </li> +</ol> + +<p> +EDK2 Documentation: +</p> +<ul> + <li>Build <a target="_blank" href="https://github.com/tianocore-docs/Docs/raw/master/Specifications/Build_Spec_1_26.pdf">V1.26</a></li> + <li>Coding Standards <a target="_blank" href="https://github.com/tianocore-docs/Docs/raw/master/Specifications/CCS_2_1_Draft.pdf">V2.1</a></li> + <li>DEC <a target="_blank" href="https://github.com/tianocore-docs/Docs/raw/master/Specifications/DEC_Spec_1_25.pdf">V1.25</a></li> + <li>DSC <a target="_blank" href="https://github.com/tianocore-docs/Docs/raw/master/Specifications/DSC_Spec_1_26.pdf">V1.26</a></li> + <li>Expression Syntax <a target="_blank" href="https://github.com/tianocore-docs/Docs/raw/master/Specifications/ExpressionSyntax_1.1.pdf">V1.1</a></li> + <li>FDF <a target="_blank" href="https://github.com/tianocore-docs/Docs/raw/master/Specifications/FDF_Spec_1_26.pdf">V1.26</a></li> + <li>INF <a target="_blank" href="https://github.com/tianocore-docs/Docs/raw/master/Specifications/INF_Spec_1_25.pdf">V1.25</a></li> + <li>PCD <a target="_blank" href="https://github.com/tianocore-docs/Docs/raw/master/Specifications/PCD_Infrastructure.pdf">PCD</a>V0.55</li> + <li>UNI <a target="_blank" href="https://github.com/tianocore-docs/Docs/raw/master/Specifications/UNI_File_Spec_v1_2_Errata_A.pdf">V1.2 Errata A</a></li> + <li>VRF <a target="_blank" href="https://github.com/tianocore-docs/Docs/raw/master/Specifications/VFR_1_9.pdf">V1.9</a></li> +</ul> + + + +<hr> +<h1>Quark™ FSP</h1> +<p> +Documentation: +</p> +<ul> + <li>Intel® Firmware Support Package External Architecture Specification <a target="_blank" href="http://www.intel.com/content/dam/www/public/us/en/documents/technical-specifications/fsp-architecture-spec-v1-1.pdf">V1.1</a></li> +</ul> + + + +<hr> +<h1>Quark™ EDK2 BIOS</h1> +<p> +Build Instructions: +</p> +<ol> + <li>Set up <a href="#BuildEnvironment">build environment</a></li> + <li>Build the image: + <ul> + <li>Linux: +<pre><code>build -p QuarkPlatformPkg/Quark.dsc -a IA32 -t GCC48 -b DEBUG -DDEBUG_PROPERTY_MASK=0x27 -DDEBUG_PRINT_ERROR_LEVEL=0x80000042 +ls Build/Quark/DEBUG_GCC48/FV/Quark.fd +</code></pre> + </li> + <li>Windows: +<pre><code>build -p QuarkPlatformPkg/Quark.dsc -a IA32 -t VS2012x86 -b DEBUG -DDEBUG_PROPERTY_MASK=0x27 -DDEBUG_PRINT_ERROR_LEVEL=0x80000042 +dir Build\Quark\DEBUG_VS2012x86\FV\Quark.fd +</code></pre> + </li> + </ul> </li> +</ol> + +<p> +Documentation: +</p> +<ul> + <li>Intel® Quark™ SoC X1000 <a target="_blank" href="http://www.intel.com/content/dam/www/public/us/en/documents/guides/quark-x1000-uefi-firmware-writers-guide.pdf">UEFI Firmware Writer's Guide</a></li> </ul>
<hr> -<p>Modified: 1 February 2016</p> +<p>Modified: 10 February 2016</p> </body> </html> \ No newline at end of file
