Aaron Durbin (adurbin@google.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/5005
commit 83edd1bb8ce2d406aab7fce0e9a93b9df08e673a Author: Aaron Durbin adurbin@chromium.org Date: Tue Dec 10 17:09:40 2013 -0800
reg_script: add reg_script_run_on_dev()
The reg_script library has proven to be useful. It's also shown that many scripts operate on devices. However, certain code paths run the same script on multiple, but different, devices. In order to make that easier introduce reg_script_run_on_dev() which takes a device as a parameter. That way, chained reg_scripts are not scrictly needed to run the same script on multiple devices.
BUG=None BRANCH=None TEST=Built.
Change-Id: I273499af4d303ebd7dc19e9b635ca23cf9bb2225 Signed-off-by: Aaron Durbin adurbin@chromium.org Reviewed-on: https://chromium-review.googlesource.com/179540 Reviewed-by: Duncan Laurie dlaurie@chromium.org --- src/include/reg_script.h | 1 + src/lib/reg_script.c | 9 +++++++-- 2 files changed, 8 insertions(+), 2 deletions(-)
diff --git a/src/include/reg_script.h b/src/include/reg_script.h index 81a4648..72e1e96 100644 --- a/src/include/reg_script.h +++ b/src/include/reg_script.h @@ -334,5 +334,6 @@ struct reg_script { _REG_SCRIPT_ENCODE_RAW(REG_SCRIPT_COMMAND_END, 0, 0, 0, 0, 0, 0, 0)
void reg_script_run(const struct reg_script *script); +void reg_script_run_on_dev(device_t dev, const struct reg_script *step);
#endif /* REG_SCRIPT_H */ diff --git a/src/lib/reg_script.c b/src/lib/reg_script.c index a331b14..7d03463 100644 --- a/src/lib/reg_script.c +++ b/src/lib/reg_script.c @@ -468,11 +468,16 @@ static void reg_script_run_next(struct reg_script_context *prev_ctx, reg_script_run_with_context(&ctx); }
-void reg_script_run(const struct reg_script *step) +void reg_script_run_on_dev(device_t dev, const struct reg_script *step) { struct reg_script_context ctx;
- reg_script_set_dev(&ctx, EMPTY_DEV); + reg_script_set_dev(&ctx, dev); reg_script_set_step(&ctx, step); reg_script_run_with_context(&ctx); } + +void reg_script_run(const struct reg_script *step) +{ + reg_script_run_on_dev(EMPTY_DEV, step); +}
